[Ovmsdev] Firmware release 3.3.003 to MAIN / 3.3.004 preparation
Mon Jan 16 17:25:14 HKT 2023
Valet mode stuff and extra units are extra features and I expect to hold
them back till next release.
//.ichael
On Mon, 16 Jan 2023, 5:05 pm Michael Geddes, <frog at bunyip.wheelycreek.net>
wrote:
> Nothing outstanding in the units code.
> There are some extra SI units to add but they are just completeness rather
> needed.
> I do have a few issues I am nearly done with on ioniq 5 to do with range
> and charge time estimation.
> Also I have a small tweak for the battery monitor to trigger gathering
> info as it occasionally doesn't trigger and gives a flatbed warning!
> There's also a tweak to Valet mode I'm working on.. Adding a  geofence..
> And also allowing it to be turned on in vehicle.cpp without explicit
> hardware support (I'm happy to simply
> allow the metric to be set in ioniq 5 code).  This gives geofence plus the
> existing boot and bonnet detection.
> On Mon, 16 Jan 2023, 4:07 pm Michael Balzer, <dexter at expeedo.de> wrote:
>> We missed releasing 3.3.003 to /main. It's been in /eap since 09/22,
>> /main still has 3.3.002 (since 03/22).
>> Mark, would you please go ahead on this with api.openvehicles.com? I'll
>> follow with ovms.dexters-web.de.
>> Regarding 3.3.004:
>> Thanks to all contributors we have three new vehicles in the queue:
>> - Renault Zoe Phase 2 initial support by Carsten Schmiemann →
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/732
>> - Hyundai Ioniq 5 initial support by Michael Geddes →
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/762
>> - Mini Cooper SE initial support by Vincent Barat →
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/789
>> Michael Geddes has also done a lot of great work on implementing full
>> user metrics unit support at the module. This already works very well
>> and stable in the shell, and the web UI extension now is also ready for
>> inclusion (Michael, unless you've got some open todo I missed?) →
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/795
>> To get the new vehicle support into /main ASAP, I suggest heading for
>> the 3.3.004 release now, including Michael's user unit support.
>> Please report any open issues that need to be addressed for the 3.3.004
>> release.
>> Thanks & regards
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230116/c9bd6b03/attachment.htm>
