[Ovmsdev] Firmware release 3.3.003 to MAIN / 3.3.004 preparation
    Michael Geddes
    Mon Jan 16 17:05:30 HKT 2023
Nothing outstanding in the units code.
There are some extra SI units to add but they are just completeness rather
needed.
I do have a few issues I am nearly done with on ioniq 5 to do with range
and charge time estimation.
Also I have a small tweak for the battery monitor to trigger gathering info
as it occasionally doesn't trigger and gives a flatbed warning!
There's also a tweak to Valet mode I'm working on.. Adding a  geofence..
And also allowing it to be turned on in vehicle.cpp without explicit
hardware support (I'm happy to simply
allow the metric to be set in ioniq 5 code).  This gives geofence plus the
existing boot and bonnet detection.
On Mon, 16 Jan 2023, 4:07 pm Michael Balzer, <dexter at expeedo.de> wrote:
> We missed releasing 3.3.003 to /main. It's been in /eap since 09/22,
> /main still has 3.3.002 (since 03/22).
> Mark, would you please go ahead on this with api.openvehicles.com? I'll
> follow with ovms.dexters-web.de.
> Regarding 3.3.004:
> Thanks to all contributors we have three new vehicles in the queue:
> - Renault Zoe Phase 2 initial support by Carsten Schmiemann →
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/732
> - Hyundai Ioniq 5 initial support by Michael Geddes →
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/762
> - Mini Cooper SE initial support by Vincent Barat →
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/789
> Michael Geddes has also done a lot of great work on implementing full
> user metrics unit support at the module. This already works very well
> and stable in the shell, and the web UI extension now is also ready for
> inclusion (Michael, unless you've got some open todo I missed?) →
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/795
> To get the new vehicle support into /main ASAP, I suggest heading for
> the 3.3.004 release now, including Michael's user unit support.
> Please report any open issues that need to be addressed for the 3.3.004
> release.
> Thanks & regards
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230116/28deb765/attachment.htm>
