[Ovmsdev] Coulomb metrics !?
    Michael Geddes
    Mon Jan  9 12:30:59 HKT 2023
Hi all,
I've just found the total power used/recovered metrics (after realising in
the I5 code that I was retrieving but not updating the appropriate metrics).
Anyway, I then noticed the following:
v.b.coulomb.used
v.b.coulomb.used.total
v.b.coulomb.recd
v.b.coulomb.recd.total
The weird thing is that these are all in Amp Hours, which is not coulombs
(coulombs is "amp seconds").
I'm going to submit a patch-request that adds kC  (kilocoulombs) since that
keeps the numbers reasonable, as well as megajoules (related to kwh)
I was wondering whether it's worth having the above values stored as
'kilocoulombs' rather than 'Amp Hours'!?  But I realise that this would
have potentially bad affects as the raw metric values available on servers
etc would change.  *sigh*
Is there anything that can be done?
//.ichael
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230109/6f12ad1b/attachment.htm>
