[Ovmsdev] Replacement ovms!
Peter peter at peterwww.com
Sun Jan 8 11:27:20 HKT 2023
If you order from UK, I might take the GSM module off your hands (I'm
located in Perth, WA).
The 3G module I got with my OVMS back in early 2021 only worked quite
patchy for about a week when I first received it, and never again since. I
hope it's a hardware issue with the module, not with the OVMS. I haven't
spent much time on diagnosing it though. In any case 4G would be a lot more
future proof, but when I looked recently I was put off by the available
options in terms of price/shipping.
Cheers,
Peter
On Sun, 8 Jan 2023 at 09:48, Michael Geddes <frog at bunyip.wheelycreek.net>
wrote:
> So I've had this issue with the HUD not powering up when connected to the
> OVMS and then I just had an issue with a bad file in /store causing
> continuous reboots and thought I'd get a replacement base unit. I already
> got a small refund from the old distributor because of the faulty hud
> power.
> The problem is that the shipping cost is stupid expensive. US $180 for
> base module (no GSM) then $205 for shipping!..  =AUD $560 from medlock.
> Going for the UK site I have to get it as a kit with cables, but
> at £166.93 + £19.97 shipping... Which at AUD $328 is a lot cheaper... What
> the actual f? And I get 2 antennas I don't need and a SIM I can't use as
> well as the GSM module that I was going to either transfer over or get an
> in-car wifi solution.
> What on earth is going on!?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230108/2179f518/attachment.htm>
