[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Sat Feb 25 00:34:32 HKT 2023
Ludovic,
I've merged all your PRs, including the two "touchy" ones. I've seen no
issues but a couple of bug fixes included.
I still need to test these with idf5 (i.e. the new idf5 branch state),
idf3 builds & runs fine.
The IDF version switches of course don't add readability, as expected.
But if they can be kept that small, I don't see any problems.
I would opt for excluding the IDF 4 branches, to aid in keeping these as
small as possible. I don't see any advantage in IDF 4 over 5 -- do you?
Am 22.02.23 um 17:23 schrieb Ludovic LANGE:
> Hi Mark,
> You're certainly right : WolfSSH writes here
> https://github.com/wolfSSL/wolfssh : "wolfSSH is dependent on
> wolfCrypt, found as a part of wolfSSL".
> So it seems we need to bundle it still, and it's a good thing we
> managed to have it more or less compile with ESP-IDF 5+ (a few bugs
> are still being ironed out - especially the OPENSSL compatibility
> layer, which may not be used if mongoose does use mbedTLS instead).
> Regarding the integration, I tried (my best :-)) to have it build on
> both ESP-IDF 3, ESP-IDF 5 (and also ESP-IDF 4 with a small patch to
> the ESP-IDF build system itself). Of course I need help for testing /
> reproducing the builds and I'm grateful to those of you sparing some
> time to do exactly that.
> I have another round of PRs waiting for some peer-review :
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pulls?q=is%3Aopen+is%3Apr+author%3Allange+draft%3Afalse
> -> @List, do not hesitate to have a look - especially for the ones
> that are a little bit touchy:
>   * https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/831
>     is trying to guess whether the multiple switch case falls-through
>     are wanted, or not. It impacts the code of multiple people, so it
>     would be interesting if those people could have a look at it.
>   * https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/835
>     is also a big piece and would benefit from a peer-review.
> Thanks in advance !
> Le 20/02/2023 à 08:07, Mark Webb-Johnson a écrit :
>> Michael, Ludovic,
>>> Actually one of the next things I wanted to try/determine is why you
>>> want/need to use wolfSSL instead of mbedTLS, which we've been using
>>> since wolfSSL failed so miserably about the Let's encrypt root
>>> certificate transition. Is there an issue with mbedTLS in idf5?
>> My memory was that wolfssh required wolfssl? But I may be mistaken.
>>> We still need to decide on the integration way. Mark's suggestion
>>> was doing the idf5 transition in a separate branch that will later
>>> become the new "master". That would keep the idf3 build clean from
>>> any regressions, but need merging any work done on that branch into
>>> the idf5 branch, which may become a lot of additional work,
>>> depending on the time needed to finish the transition.
>> If this can cleanly be applied to the existing work, to allow
>> building under either v3 or v5 IDF, that would be ideal. IMHO, the
>> separate branch would only be required if the changes were very
>> extensive and breaking to v3.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230224/cafbc079/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230224/cafbc079/attachment.sig>
