[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Sun Feb 19 01:32:13 HKT 2023
Doing the watchdog init ourselves avoids the issue.
To do so, we need to change line 38 in ovms_main to…
#if !CONFIG_ESP_TASK_WDT_INIT
…and disable that config option.
Am 18.02.23 um 10:12 schrieb Michael Balzer:
> Ludovic,
> the issue is bound to the docker image version, I was using
> "espressif/idf", which is "latest".
> The build works using the same sdkconfig with
> "espressif/idf:release-v5.0" (and again fails at that mbedtls module
> when switching back to the "latest" image).
> So to build the current experimental state, I recommend using the
> docker image and basically doing the steps Ludovic formalized in the
> github action:
> ### SETUP ###
> cd ~/esp/Open-Vehicle-Monitoring-System-3
> # setup branch:
> git remote add llange
> git at github.com:llange/Open-Vehicle-Monitoring-System-3.git
> git branch -t experimental-esp-idf-build-workflow
> llange/experimental-esp-idf-build-workflow
> # switch to branch:
> git checkout experimental-esp-idf-build-workflow
> git submodule update --init --recursive
> # apply mongoose patch:
> git apply --directory=vehicle/OVMS.V3/components/mongoose/mongoose
> vehicle/OVMS.V3/support/mongoose-espv5.patch
> # install v5 sdkconfig defaults:
> cp vehicle/OVMS.V3/support/sdkconfig.defaults.esp5
> vehicle/OVMS.V3/sdkconfig.defaults
> # install v5 idf components:
> cp vehicle/OVMS.V3/support/idf_component.yml.esp5
> vehicle/OVMS.V3/main/idf_component.yml
> ### BUILD ###
> cd ~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3
> # launch docker shell:
> docker run --rm -v $PWD:/project -w /project -it
> # init docker image (needs to be done on every start):
> apt-get update && apt-get install -y dos2unix
> # OPTION 1: start with default config:
> rm vehicle/OVMS.V3/sdkconfig
> # NOTE: this will build for ESP32 >= rev3, excluding the SPIRAM bug
> workarounds
> # OPTION 2: update your existing sdkconfig:
> idf.py menuconfig
> # → press '/'
> # … enable FREERTOS_ENABLE_BACKWARD_COMPATIBILITY
> # … disable FREERTOS_ASSERT_ON_UNTESTED_FUNCTION
> # … disable MG_ENABLE_SSL
> # build:
> idf.py build
> # flash & start USB monitor:
> idf.py app-flash && idf.py monitor
> The build boots & works, issues you described excluded.
> An issue I didn't expect:
> I (0) cpu_start: Starting scheduler on APP CPU.
> E (0) task_wdt: esp_task_wdt_add(747): TWDT was never initialized
> E (10) task_wdt: esp_task_wdt_add(747): TWDT was never initialized
> …and then repeated 4x per second:
> E (3130) task_wdt: esp_task_wdt_reset(783): task not found
> I'll try to find the cause, as we cannot silent these ("early"
> logging) they make using the shell challenging.
> But, besides that, it has Wifi & cellular connectivity, so looks very
> promising -- nice work, Ludovic!
> Am 18.02.23 um 00:53 schrieb Ludovic LANGE:
>> Hi Michael,
>> I'm sorry to read that you're facing those issues.
>> It's almost certain that my sdkconfig, after being changed back and
>> forth to disable certain modules that would not compile, is now not
>> in a "pristine" state, and that's certainly why your build and mine
>> do not activate the same compilation paths.
>> I'll be interested in getting your sdkconfig file to see what is left
>> to fix to have it properly compile.
>> (In the meantime I have forced the compilation of this part of the
>> module, fixed the compilation errors you were likely to have, and
>> force-pushed those fixes on the 2 branches experimental-esp-idf-v5
>> and experimental-esp-idf-build-workflow)
>> Regarding the linking error, I'm not sure why you have it, as it's
>> looks like it is part of the mbedtls of ESP-IDF 5.0 - I'll see if I
>> can reproduce it when I have your sdkconfig.
>> Ludovic
>> Le 17/02/2023 à 22:54, Michael Balzer a écrit :
>>> Ludovic,
>>> using the docker image I managed to make some progress.
>>> I can now start the build process, but then run into printf format
>>> errors on main/ovms_module.cpp, e.g.
>>> /project/main/ovms_module.cpp: In function 'void
>>> print_blocks(OvmsWriter*, TaskHandle_t, bool)':
>>> /project/main/ovms_module.cpp:438:37: error: format '%d' expects
>>> argument of type 'int', but argument 4 has type 'uint32_t' {aka
>>> 'long unsigned int'} [-Werror=format=]
>>> I'm here:
>>> commit 19e36125c6e0597c901eb82a546ef82c1dea8a1e (HEAD ->
>>> experimental-esp-idf-v5, llange/experimental-esp-idf-v5)
>>> Author: Ludovic LANGE <llange at users.noreply.github.com>
>>> I thought maybe you've sorted that out in your new build branch, but
>>> apparently that has the same error, which leaves me wondering how
>>> the automated build can work…
>>> I see you don't have CONFIG_FREERTOS_USE_TRACE_FACILITY in your new
>>> "sdkconfig.defaults.esp5", so the module isn't included in your
>>> build. But you also have CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=y,
>>> which automatically enables CONFIG_FREERTOS_USE_TRACE_FACILITY in my
>>> setup.
>>> Disabling both options, I just almost got through, just a final
>>> linker error:
>>> /project/components/zip/libzip/lib/zip_crypto_mbedtls.c:124:
>>> undefined reference to `mbedtls_pkcs5_pbkdf2_hmac'
>>> I assume there are more differences in your new branch / sdkconfig,
>>> I'll try that one next.
>>> Am 10.02.23 um 09:37 schrieb Ludovic LANGE:
>>>> Hi,
>>>> Just as a curiosity, I setup GitHub to build the v5 branch with
>>>> "GitHub actions".
>>>> You can find the latest runs here :
>>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions
>>>> The configuration file is here :
>>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-build-workflow/.github/workflows/build-ovms.yml
>>>> /Note: It's a specific branch because I had to add some
>>>> configuration files (default sdkconfig options for example), change
>>>> the reference to wolfssl submodule, add a patch for our mongoose
>>>> version, ... ; but in the future I could make a PR for this feature
>>>> if we find it useful./
>>>> /(I also would like to experiment a little bit with static code
>>>> analysis, unit tests, etc...)/
>>>> Regards,
>>>> Le 06/02/2023 à 15:23, Ludovic LANGE a écrit :
>>>>> Hi again,
>>>>> Additionally, I've just verified that the official docker image
>>>>> for ESP-IDF (doc:
>>>>> https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-guides/tools/idf-docker-image.html
>>>>> ) is able to build the branch.
>>>>> The only thing to add to the image is the "dos2unix" utility ("apt
>>>>> update && apt-get install dos2unix"), after that you'll be able to
>>>>> build the image.
>>>>> Do not forget to update your sdkconfig (enabling FreeRTOS
>>>>> compatibility and unchecking SSL for mongoose) before building,
>>>>> and to do the patches for mongoose / wolfssl as described here:
>>>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-v5/README.md
>>>>> Then "idf.py build" should work - at least !
>>>>> I've used the `docker run --rm -v $PWD:/project -w /project -it
>>>>> espressif/idf:|release-v5.0|` command to have a shell prompt
>>>>> (launch that in your source file path)
>>>>> Then install dos2unix, launch menuconfig, then build.
>>>>> Tell me how it works for you.
>>>>> (You may have some component build failure ; depending on the
>>>>> sdkconfig flags, I'm still trying to document it)
>>>>> Regards,
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230218/61f5b856/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230218/61f5b856/attachment-0001.sig>
