[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Sat Feb 18 17:12:23 HKT 2023
Ludovic,
the issue is bound to the docker image version, I was using
"espressif/idf", which is "latest".
The build works using the same sdkconfig with
"espressif/idf:release-v5.0" (and again fails at that mbedtls module
when switching back to the "latest" image).
So to build the current experimental state, I recommend using the docker
image and basically doing the steps Ludovic formalized in the github action:
### SETUP ###
cd ~/esp/Open-Vehicle-Monitoring-System-3
# setup branch:
git remote add llange
git at github.com:llange/Open-Vehicle-Monitoring-System-3.git
git branch -t experimental-esp-idf-build-workflow
llange/experimental-esp-idf-build-workflow
# switch to branch:
git checkout experimental-esp-idf-build-workflow
git submodule update --init --recursive
# apply mongoose patch:
git apply --directory=vehicle/OVMS.V3/components/mongoose/mongoose
vehicle/OVMS.V3/support/mongoose-espv5.patch
# install v5 sdkconfig defaults:
cp vehicle/OVMS.V3/support/sdkconfig.defaults.esp5
vehicle/OVMS.V3/sdkconfig.defaults
# install v5 idf components:
cp vehicle/OVMS.V3/support/idf_component.yml.esp5
vehicle/OVMS.V3/main/idf_component.yml
### BUILD ###
cd ~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3
# launch docker shell:
docker run --rm -v $PWD:/project -w /project -it espressif/idf:release-v5.0
# init docker image (needs to be done on every start):
apt-get update && apt-get install -y dos2unix
# OPTION 1: start with default config:
rm vehicle/OVMS.V3/sdkconfig
# NOTE: this will build for ESP32 >= rev3, excluding the SPIRAM bug
workarounds
# OPTION 2: update your existing sdkconfig:
idf.py menuconfig
# → press '/'
# … enable FREERTOS_ENABLE_BACKWARD_COMPATIBILITY
# … disable FREERTOS_ASSERT_ON_UNTESTED_FUNCTION
# … disable MG_ENABLE_SSL
# build:
idf.py build
# flash & start USB monitor:
idf.py app-flash && idf.py monitor
The build boots & works, issues you described excluded.
An issue I didn't expect:
I (0) cpu_start: Starting scheduler on APP CPU.
E (0) task_wdt: esp_task_wdt_add(747): TWDT was never initialized
E (10) task_wdt: esp_task_wdt_add(747): TWDT was never initialized
…and then repeated 4x per second:
E (3130) task_wdt: esp_task_wdt_reset(783): task not found
I'll try to find the cause, as we cannot silent these ("early" logging)
they make using the shell challenging.
But, besides that, it has Wifi & cellular connectivity, so looks very
promising -- nice work, Ludovic!
Am 18.02.23 um 00:53 schrieb Ludovic LANGE:
> Hi Michael,
> I'm sorry to read that you're facing those issues.
> It's almost certain that my sdkconfig, after being changed back and
> forth to disable certain modules that would not compile, is now not in
> a "pristine" state, and that's certainly why your build and mine do
> not activate the same compilation paths.
> I'll be interested in getting your sdkconfig file to see what is left
> to fix to have it properly compile.
> (In the meantime I have forced the compilation of this part of the
> module, fixed the compilation errors you were likely to have, and
> force-pushed those fixes on the 2 branches experimental-esp-idf-v5 and
> experimental-esp-idf-build-workflow)
> Regarding the linking error, I'm not sure why you have it, as it's
> looks like it is part of the mbedtls of ESP-IDF 5.0 - I'll see if I
> can reproduce it when I have your sdkconfig.
> Ludovic
> Le 17/02/2023 à 22:54, Michael Balzer a écrit :
>> Ludovic,
>> using the docker image I managed to make some progress.
>> I can now start the build process, but then run into printf format
>> errors on main/ovms_module.cpp, e.g.
>> /project/main/ovms_module.cpp: In function 'void
>> print_blocks(OvmsWriter*, TaskHandle_t, bool)':
>> /project/main/ovms_module.cpp:438:37: error: format '%d' expects
>> argument of type 'int', but argument 4 has type 'uint32_t' {aka 'long
>> unsigned int'} [-Werror=format=]
>> I'm here:
>> commit 19e36125c6e0597c901eb82a546ef82c1dea8a1e (HEAD ->
>> experimental-esp-idf-v5, llange/experimental-esp-idf-v5)
>> Author: Ludovic LANGE <llange at users.noreply.github.com>
>> I thought maybe you've sorted that out in your new build branch, but
>> apparently that has the same error, which leaves me wondering how the
>> automated build can work…
>> I see you don't have CONFIG_FREERTOS_USE_TRACE_FACILITY in your new
>> "sdkconfig.defaults.esp5", so the module isn't included in your
>> build. But you also have CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=y,
>> which automatically enables CONFIG_FREERTOS_USE_TRACE_FACILITY in my
>> setup.
>> Disabling both options, I just almost got through, just a final
>> linker error:
>> /project/components/zip/libzip/lib/zip_crypto_mbedtls.c:124:
>> undefined reference to `mbedtls_pkcs5_pbkdf2_hmac'
>> I assume there are more differences in your new branch / sdkconfig,
>> I'll try that one next.
>> Am 10.02.23 um 09:37 schrieb Ludovic LANGE:
>>> Hi,
>>> Just as a curiosity, I setup GitHub to build the v5 branch with
>>> "GitHub actions".
>>> You can find the latest runs here :
>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions
>>> The configuration file is here :
>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-build-workflow/.github/workflows/build-ovms.yml
>>> /Note: It's a specific branch because I had to add some
>>> configuration files (default sdkconfig options for example), change
>>> the reference to wolfssl submodule, add a patch for our mongoose
>>> version, ... ; but in the future I could make a PR for this feature
>>> if we find it useful./
>>> /(I also would like to experiment a little bit with static code
>>> analysis, unit tests, etc...)/
>>> Le 06/02/2023 à 15:23, Ludovic LANGE a écrit :
>>>> Hi again,
>>>> Additionally, I've just verified that the official docker image for
>>>> ESP-IDF (doc:
>>>> https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-guides/tools/idf-docker-image.html
>>>> ) is able to build the branch.
>>>> The only thing to add to the image is the "dos2unix" utility ("apt
>>>> update && apt-get install dos2unix"), after that you'll be able to
>>>> build the image.
>>>> Do not forget to update your sdkconfig (enabling FreeRTOS
>>>> compatibility and unchecking SSL for mongoose) before building, and
>>>> to do the patches for mongoose / wolfssl as described here:
>>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-v5/README.md
>>>> Then "idf.py build" should work - at least !
>>>> I've used the `docker run --rm -v $PWD:/project -w /project -it
>>>> espressif/idf:|release-v5.0|` command to have a shell prompt
>>>> (launch that in your source file path)
>>>> Then install dos2unix, launch menuconfig, then build.
>>>> Tell me how it works for you.
>>>> (You may have some component build failure ; depending on the
>>>> sdkconfig flags, I'm still trying to document it)
>>>> Regards,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230218/d7ba7b34/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230218/d7ba7b34/attachment-0001.sig>
