[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Ludovic LANGE ll-ovmsdev at lange.nom.fr
Sat Feb 18 07:53:40 HKT 2023
Hi Michael,
I'm sorry to read that you're facing those issues.
It's almost certain that my sdkconfig, after being changed back and
forth to disable certain modules that would not compile, is now not in a
"pristine" state, and that's certainly why your build and mine do not
activate the same compilation paths.
I'll be interested in getting your sdkconfig file to see what is left to
fix to have it properly compile.
(In the meantime I have forced the compilation of this part of the
module, fixed the compilation errors you were likely to have, and
force-pushed those fixes on the 2 branches experimental-esp-idf-v5 and
experimental-esp-idf-build-workflow)
Regarding the linking error, I'm not sure why you have it, as it's looks
like it is part of the mbedtls of ESP-IDF 5.0 - I'll see if I can
reproduce it when I have your sdkconfig.
Ludovic
Le 17/02/2023 à 22:54, Michael Balzer a écrit :
> Ludovic,
> using the docker image I managed to make some progress.
> I can now start the build process, but then run into printf format
> errors on main/ovms_module.cpp, e.g.
> /project/main/ovms_module.cpp: In function 'void
> print_blocks(OvmsWriter*, TaskHandle_t, bool)':
> /project/main/ovms_module.cpp:438:37: error: format '%d' expects
> argument of type 'int', but argument 4 has type 'uint32_t' {aka 'long
> unsigned int'} [-Werror=format=]
> I'm here:
> commit 19e36125c6e0597c901eb82a546ef82c1dea8a1e (HEAD ->
> experimental-esp-idf-v5, llange/experimental-esp-idf-v5)
> Author: Ludovic LANGE <llange at users.noreply.github.com>
> I thought maybe you've sorted that out in your new build branch, but
> apparently that has the same error, which leaves me wondering how the
> automated build can work…
> I see you don't have CONFIG_FREERTOS_USE_TRACE_FACILITY in your new
> "sdkconfig.defaults.esp5", so the module isn't included in your build.
> But you also have CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=y, which
> automatically enables CONFIG_FREERTOS_USE_TRACE_FACILITY in my setup.
> Disabling both options, I just almost got through, just a final linker
> error:
> /project/components/zip/libzip/lib/zip_crypto_mbedtls.c:124: undefined
> reference to `mbedtls_pkcs5_pbkdf2_hmac'
> I assume there are more differences in your new branch / sdkconfig,
> I'll try that one next.
> Am 10.02.23 um 09:37 schrieb Ludovic LANGE:
>> Hi,
>> Just as a curiosity, I setup GitHub to build the v5 branch with
>> "GitHub actions".
>> You can find the latest runs here :
>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions
>> The configuration file is here :
>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-build-workflow/.github/workflows/build-ovms.yml
>> /Note: It's a specific branch because I had to add some configuration
>> files (default sdkconfig options for example), change the reference
>> to wolfssl submodule, add a patch for our mongoose version, ... ; but
>> in the future I could make a PR for this feature if we find it useful./
>> /(I also would like to experiment a little bit with static code
>> analysis, unit tests, etc...)/
>> Le 06/02/2023 à 15:23, Ludovic LANGE a écrit :
>>> Hi again,
>>> Additionally, I've just verified that the official docker image for
>>> ESP-IDF (doc:
>>> https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-guides/tools/idf-docker-image.html
>>> ) is able to build the branch.
>>> The only thing to add to the image is the "dos2unix" utility ("apt
>>> update && apt-get install dos2unix"), after that you'll be able to
>>> build the image.
>>> Do not forget to update your sdkconfig (enabling FreeRTOS
>>> compatibility and unchecking SSL for mongoose) before building, and
>>> to do the patches for mongoose / wolfssl as described here:
>>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-v5/README.md
>>> Then "idf.py build" should work - at least !
>>> I've used the `docker run --rm -v $PWD:/project -w /project -it
>>> espressif/idf:|release-v5.0|` command to have a shell prompt (launch
>>> that in your source file path)
>>> Then install dos2unix, launch menuconfig, then build.
>>> Tell me how it works for you.
>>> (You may have some component build failure ; depending on the
>>> sdkconfig flags, I'm still trying to document it)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230218/9bcba5b2/attachment-0001.htm>
