[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Sat Feb 18 05:54:56 HKT 2023
Ludovic,
using the docker image I managed to make some progress.
I can now start the build process, but then run into printf format
errors on main/ovms_module.cpp, e.g.
/project/main/ovms_module.cpp: In function 'void
print_blocks(OvmsWriter*, TaskHandle_t, bool)':
/project/main/ovms_module.cpp:438:37: error: format '%d' expects
argument of type 'int', but argument 4 has type 'uint32_t' {aka 'long
unsigned int'} [-Werror=format=]
I'm here:
commit 19e36125c6e0597c901eb82a546ef82c1dea8a1e (HEAD ->
experimental-esp-idf-v5, llange/experimental-esp-idf-v5)
Author: Ludovic LANGE <llange at users.noreply.github.com>
I thought maybe you've sorted that out in your new build branch, but
apparently that has the same error, which leaves me wondering how the
automated build can work…
I see you don't have CONFIG_FREERTOS_USE_TRACE_FACILITY in your new
"sdkconfig.defaults.esp5", so the module isn't included in your build.
But you also have CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=y, which
automatically enables CONFIG_FREERTOS_USE_TRACE_FACILITY in my setup.
Disabling both options, I just almost got through, just a final linker
error:
/project/components/zip/libzip/lib/zip_crypto_mbedtls.c:124: undefined
reference to `mbedtls_pkcs5_pbkdf2_hmac'
I assume there are more differences in your new branch / sdkconfig, I'll
try that one next.
Am 10.02.23 um 09:37 schrieb Ludovic LANGE:
> Hi,
> Just as a curiosity, I setup GitHub to build the v5 branch with
> "GitHub actions".
> You can find the latest runs here :
> https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions
> The configuration file is here :
> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-build-workflow/.github/workflows/build-ovms.yml
> /Note: It's a specific branch because I had to add some configuration
> files (default sdkconfig options for example), change the reference to
> wolfssl submodule, add a patch for our mongoose version, ... ; but in
> the future I could make a PR for this feature if we find it useful./
> /(I also would like to experiment a little bit with static code
> analysis, unit tests, etc...)/
> Le 06/02/2023 à 15:23, Ludovic LANGE a écrit :
>> Hi again,
>> Additionally, I've just verified that the official docker image for
>> ESP-IDF (doc:
>> https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-guides/tools/idf-docker-image.html
>> ) is able to build the branch.
>> The only thing to add to the image is the "dos2unix" utility ("apt
>> update && apt-get install dos2unix"), after that you'll be able to
>> build the image.
>> Do not forget to update your sdkconfig (enabling FreeRTOS
>> compatibility and unchecking SSL for mongoose) before building, and
>> to do the patches for mongoose / wolfssl as described here:
>> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-v5/README.md
>> Then "idf.py build" should work - at least !
>> I've used the `docker run --rm -v $PWD:/project -w /project -it
>> espressif/idf:|release-v5.0|` command to have a shell prompt (launch
>> that in your source file path)
>> Then install dos2unix, launch menuconfig, then build.
>> Tell me how it works for you.
>> (You may have some component build failure ; depending on the
>> sdkconfig flags, I'm still trying to document it)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230217/4a63f76a/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230217/4a63f76a/attachment.sig>
