[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Ludovic LANGE
ll-ovmsdev at lange.nom.fr
Fri Feb 10 16:37:23 HKT 2023
Hi,
Just as a curiosity, I setup GitHub to build the v5 branch with "GitHub
actions".
You can find the latest runs here :
https://github.com/llange/Open-Vehicle-Monitoring-System-3/actions
The configuration file is here :
https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-build-workflow/.github/workflows/build-ovms.yml
/Note: It's a specific branch because I had to add some configuration
files (default sdkconfig options for example), change the reference to
wolfssl submodule, add a patch for our mongoose version, ... ; but in
the future I could make a PR for this feature if we find it useful./
/(I also would like to experiment a little bit with static code
analysis, unit tests, etc...)/
Le 06/02/2023 à 15:23, Ludovic LANGE a écrit :
> Hi again,
> Additionally, I've just verified that the official docker image for
> ESP-IDF (doc:
> https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-guides/tools/idf-docker-image.html
> ) is able to build the branch.
> The only thing to add to the image is the "dos2unix" utility ("apt
> update && apt-get install dos2unix"), after that you'll be able to
> build the image.
> Do not forget to update your sdkconfig (enabling FreeRTOS
> compatibility and unchecking SSL for mongoose) before building, and to
> do the patches for mongoose / wolfssl as described here:
> https://github.com/llange/Open-Vehicle-Monitoring-System-3/blob/experimental-esp-idf-v5/README.md
> Then "idf.py build" should work - at least !
> I've used the `docker run --rm -v $PWD:/project -w /project -it
> espressif/idf:|release-v5.0|` command to have a shell prompt (launch
> that in your source file path)
> Then install dos2unix, launch menuconfig, then build.
> Tell me how it works for you.
> (You may have some component build failure ; depending on the
> sdkconfig flags, I'm still trying to document it)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230210/e98a4ac6/attachment.htm>
