[Ovmsdev] ESP-IDF v4 / v5 - baby steps
Ludovic LANGE ll-ovmsdev at lange.nom.fr
Sun Feb 19 23:29:01 HKT 2023
Hi Michael,
Hi list,
Thanks Michael for having taken the time to reproduce the build, and
thus making this branch go from the state of "urban legend" to "has been
confirmed at least once" :-)
I hope more of you will be able to follow the instructions of Michael,
that are very clear and should ease your work when wanting to test this
branch.
Ideally, I wanted that some of you having both the time (...) and a
vehicle to test would be able to use this build as a daily driver,
hoping that the known missing parts would not be a showstopper. Let me
know, and also if you have some spare cycles you can check
https://github.com/wolfSSL/wolfssl/issues/6028 in order to help fix some
remaining issues on this library we depend on.
In the meantime, I believe we can try to integrate (part of) this branch
in master. I already started to distillate some parts of this in
multiples MRs here
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pulls?q=is%3Aopen+is%3Apr+author%3Allange+draft%3Afalse
; which could be merged without -I hope, but the review will confirm-
any impact nor regression to the current master branch.
Let me know if I should continue in that direction, and sorry for
sounding impatient about it :-)
Le 18/02/2023 à 10:12, Michael Balzer a écrit :
> Ludovic,
> the issue is bound to the docker image version, I was using
> "espressif/idf", which is "latest".
> The build works using the same sdkconfig with
> "espressif/idf:release-v5.0" (and again fails at that mbedtls module
> when switching back to the "latest" image).
> So to build the current experimental state, I recommend using the
> docker image and basically doing the steps Ludovic formalized in the
> github action:
> ### SETUP ###
> cd ~/esp/Open-Vehicle-Monitoring-System-3
> # setup branch:
> git remote add llange
> git at github.com:llange/Open-Vehicle-Monitoring-System-3.git
> git branch -t experimental-esp-idf-build-workflow
> llange/experimental-esp-idf-build-workflow
> # switch to branch:
> git checkout experimental-esp-idf-build-workflow
> git submodule update --init --recursive
> # apply mongoose patch:
> git apply --directory=vehicle/OVMS.V3/components/mongoose/mongoose
> vehicle/OVMS.V3/support/mongoose-espv5.patch
> # install v5 sdkconfig defaults:
> cp vehicle/OVMS.V3/support/sdkconfig.defaults.esp5
> vehicle/OVMS.V3/sdkconfig.defaults
> # install v5 idf components:
> cp vehicle/OVMS.V3/support/idf_component.yml.esp5
> vehicle/OVMS.V3/main/idf_component.yml
> ### BUILD ###
> cd ~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3
> # launch docker shell:
> docker run --rm -v $PWD:/project -w /project -it
> # init docker image (needs to be done on every start):
> apt-get update && apt-get install -y dos2unix
> # OPTION 1: start with default config:
> rm vehicle/OVMS.V3/sdkconfig
> # NOTE: this will build for ESP32 >= rev3, excluding the SPIRAM bug
> workarounds
> # OPTION 2: update your existing sdkconfig:
> idf.py menuconfig
> # → press '/'
> #   … enable FREERTOS_ENABLE_BACKWARD_COMPATIBILITY
> #   … disable FREERTOS_ASSERT_ON_UNTESTED_FUNCTION
> #   … disable MG_ENABLE_SSL
> # build:
> idf.py build
> # flash & start USB monitor:
> idf.py app-flash && idf.py monitor
> The build boots & works, issues you described excluded.
> An issue I didn't expect:
> I (0) cpu_start: Starting scheduler on APP CPU.
> E (0) task_wdt: esp_task_wdt_add(747): TWDT was never initialized
>> E (10) task_wdt: esp_task_wdt_add(747): TWDT was never initialized
> …and then repeated 4x per second:
> E (3130) task_wdt: esp_task_wdt_reset(783): task not found
> I'll try to find the cause, as we cannot silent these ("early"
> logging) they make using the shell challenging.
> But, besides that, it has Wifi & cellular connectivity, so looks very
> promising -- nice work, Ludovic!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230219/8bc75289/attachment.htm>
