[Ovmsdev] Modem - Last Error: User Interrupt
Thu Aug 3 03:00:11 HKT 2023
It still would be better to find the actual cause of the modem issue though.
Am 02.08.23 um 20:58 schrieb Michael Balzer:
> Chris & Pierre,
> cron jobs can easily be implemented by attaching event scripts to the
> standard "clock.*" events.
> → https://docs.openvehicles.com/en/latest/userguide/events.html
> For a daily job running at 01:00, all you need is a simple script for
> "clock.0100".
> For jobs running at specific time conditions, make the event script a
> javascript, e.g. along something like this:
> (function(){
> const now = new Date();
> const day = now.getDay(); // Sunday - Saturday : 0 - 6
> if (day == 3) {
> print("now performing the wednesday job…");
> A plugin providing a simple UI to manage cron jobs should be easy to
> create.
> Am 21.07.23 um 21:53 schrieb Chris van der Meijden:
>> Wifi still works for me. I did some lazy search on how to implement a
>> cronjob script within OVMS without success. So my "workaroud" for now
>> is to type a preventive
>> module reset
>> in the "Messages" command line within the app every morning (as long
>> as I'm still connected to my wifi).
>> This is a great example of "Turnschuhadmin" (sneaker admin) ...
>> Feature request: A simple cron implementation for scripting.
>> Or a hint on where to find such a feature within OVMS, if it already
>> exists.
>> Regards
>> Chris
>> Am Freitag, dem 21.07.2023 um 21:23 +0200 schrieb pi.uhl at bluewin.ch:
>>> At the moment I have the same problem with at least 3 customers of
>>> mine. WLAN doesn't work anymore either. The only solution is
>>> powerless and afterwards it works again for some time. I would
>>> appreciate to install a watchdog which makes a reset every 24 hours.
>>> Regards
>>> Pierre Uhl
>>> *Von:*OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *Im Auftrag
>>> von *Chris van der Meijden
>>> *Gesendet:* Samstag, 15. Juli 2023 15:33
>>> *An:* ovmsdev at lists.openvehicles.com
>>> *Betreff:* Re: [Ovmsdev] Modem - Last Error: User Interrupt
>>> With the constantly PoweringOn state my odyssee started with the
>>> 5360 Modem.
>>> I recently changed to the 7600 and could not see anything obvious
>>> about "neglected" contacts.
>>> If this thing has no solution I'll write a script that does a reboot
>>> every 24 hours.
>>> Nothing we can't handle with a nice workaround ...
>>> Am Samstag, dem 15.07.2023 um 14:35 +0200 schrieb sharkcow:
>>>> Funny coincindence: my 5360 modem stopped working a few days ago
>>>> (constantly in state PoweringOn). I tried rebooting & a different
>>>> firmware to no avail. Just took the module out of the car, opened
>>>> it and
>>>> it ran fine on my workbench and then also back in the car... maybe just
>>>> some bad contacts that needed some "love" :)
>>>> Am 14.07.23 um 19:47 schrieb Chris van der Meijden:
>>>>> After I upgraded my modem to a SIM7600 (and replaced my SIM card) I
>>>>> hoped the GSM would be running well again.
>>>>> I'm sorry to say that I still have issues. Every few days GSM will
>>>>> disconnect with "Last Error: User Interrupt". When it disconnects this
>>>>> way it won't connect anymore. Not even when I change location. Only
>>>>> after a "module reset" the connection comes back for another few days.
>>>>> The antenna I use is the internal antenna of the car. I had no issues
>>>>> like this last year. Same antenna then.
>>>>> Am I alone with this behauviour?
>>>>> Any ideas?
>>>>> Thanx
>>>>> Chris
>>>>> cellular status
>>>>> MODEM Status
>>>>> Model: SIM7600
>>>>> Network Registration: RegisteredHome
>>>>> Provider: congstar
>>>>> Signal: -77 dBm
>>>>> Mode: GSM;Online
>>>>> State: NetLoss
>>>>> Mux: Status up
>>>>> PPP: Not connected
>>>>> GPS: Not running
>>>>> module reset
>>>>> cellular status
>>>>> MODEM Status
>>>>> Model: SIM7600
>>>>> Provider: congstar
>>>>> Signal: -79 dBm
>>>>> Mode: LTE;Online
>>>>> State: NetMode
>>>>> Mux: Status up
>>>>> PPP: Connected on channel: #2
>>>>> GPS: Not running
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230802/d24acc6c/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230802/d24acc6c/attachment-0001.sig>
