[Ovmsdev] Modem - Last Error: User Interrupt
Thu Aug 3 02:58:08 HKT 2023
Chris & Pierre,
cron jobs can easily be implemented by attaching event scripts to the
standard "clock.*" events.
→ https://docs.openvehicles.com/en/latest/userguide/events.html
For a daily job running at 01:00, all you need is a simple script for
"clock.0100".
For jobs running at specific time conditions, make the event script a
javascript, e.g. along something like this:
(function(){
const now = new Date();
const day = now.getDay(); // Sunday - Saturday : 0 - 6
if (day == 3) {
print("now performing the wednesday job…");
A plugin providing a simple UI to manage cron jobs should be easy to create.
Am 21.07.23 um 21:53 schrieb Chris van der Meijden:
> Wifi still works for me. I did some lazy search on how to implement a
> cronjob script within OVMS without success. So my "workaroud" for now
> is to type a preventive
> module reset
> in the "Messages" command line within the app every morning (as long
> as I'm still connected to my wifi).
> This is a great example of "Turnschuhadmin" (sneaker admin) ...
> Feature request: A simple cron implementation for scripting.
> Or a hint on where to find such a feature within OVMS, if it already
> exists.
> Regards
> Chris
> Am Freitag, dem 21.07.2023 um 21:23 +0200 schrieb pi.uhl at bluewin.ch:
>> At the moment I have the same problem with at least 3 customers of
>> mine. WLAN doesn't work anymore either. The only solution is
>> powerless and afterwards it works again for some time. I would
>> appreciate to install a watchdog which makes a reset every 24 hours.
>> Regards
>> Pierre Uhl
>> *Von:*OvmsDev <ovmsdev-bounces at lists.openvehicles.com> *Im Auftrag
>> von *Chris van der Meijden
>> *Gesendet:* Samstag, 15. Juli 2023 15:33
>> *An:* ovmsdev at lists.openvehicles.com
>> *Betreff:* Re: [Ovmsdev] Modem - Last Error: User Interrupt
>> With the constantly PoweringOn state my odyssee started with the 5360
>> Modem.
>> I recently changed to the 7600 and could not see anything obvious
>> about "neglected" contacts.
>> If this thing has no solution I'll write a script that does a reboot
>> every 24 hours.
>> Nothing we can't handle with a nice workaround ...
>> Am Samstag, dem 15.07.2023 um 14:35 +0200 schrieb sharkcow:
>>> Funny coincindence: my 5360 modem stopped working a few days ago
>>> (constantly in state PoweringOn). I tried rebooting & a different
>>> firmware to no avail. Just took the module out of the car, opened it and
>>> it ran fine on my workbench and then also back in the car... maybe just
>>> some bad contacts that needed some "love" :)
>>> Am 14.07.23 um 19:47 schrieb Chris van der Meijden:
>>>> After I upgraded my modem to a SIM7600 (and replaced my SIM card) I
>>>> hoped the GSM would be running well again.
>>>> I'm sorry to say that I still have issues. Every few days GSM will
>>>> disconnect with "Last Error: User Interrupt". When it disconnects this
>>>> way it won't connect anymore. Not even when I change location. Only
>>>> after a "module reset" the connection comes back for another few days.
>>>> The antenna I use is the internal antenna of the car. I had no issues
>>>> like this last year. Same antenna then.
>>>> Am I alone with this behauviour?
>>>> Any ideas?
>>>> Thanx
>>>> Chris
>>>> cellular status
>>>> MODEM Status
>>>> Model: SIM7600
>>>> Network Registration: RegisteredHome
>>>> Provider: congstar
>>>> Signal: -77 dBm
>>>> Mode: GSM;Online
>>>> State: NetLoss
>>>> Mux: Status up
>>>> PPP: Not connected
>>>> GPS: Not running
>>>> module reset
>>>> cellular status
>>>> MODEM Status
>>>> Model: SIM7600
>>>> Provider: congstar
>>>> Signal: -79 dBm
>>>> Mode: LTE;Online
>>>> State: NetMode
>>>> Mux: Status up
>>>> PPP: Connected on channel: #2
>>>> GPS: Not running
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230802/88d84a60/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230802/88d84a60/attachment.sig>
