[Ovmsdev] Modem - Last Error: User Interrupt
Thu Aug 3 03:26:54 HKT 2023
Thanx :-)
Am Mittwoch, dem 02.08.2023 um 21:00 +0200 schrieb Michael Balzer:
> It still would be better to find the actual cause of the modem issue
> though.
> Am 02.08.23 um 20:58 schrieb Michael Balzer:
> Chris & Pierre,
> cron jobs can easily be implemented by attaching event scripts to the
> standard "clock.*" events.
>https://docs.openvehicles.com/en/latest/userguide/events.html
> For a daily job running at 01:00, all you need is a simple script for
> "clock.0100".
> For jobs running at specific time conditions, make the event script a
> javascript, e.g. along something like this:
> (function(){
>   const now = new Date();
>   const day = now.getDay(); // Sunday - Saturday : 0 - 6
>   if (day == 3) {
>     print("now performing the wednesday job…");
> A plugin providing a simple UI to manage cron jobs should be easy to
> create.
> Am 21.07.23 um 21:53 schrieb Chris van der Meijden:
> > Wifi still works for me. I did some lazy search on how to implement
> > a cronjob script within OVMS without success. So my "workaroud" for
> > now is to type a preventive
> > module reset
> > in the "Messages" command line within the app every morning (as
> > long as I'm still connected to my wifi).
> > This is a great example of "Turnschuhadmin" (sneaker admin) ...
> > Feature request: A simple cron implementation for scripting.
> > Or a hint on where to find such a feature within OVMS, if it
> > already exists.
> > Regards
> > Chris
> > Am Freitag, dem 21.07.2023 um 21:23 +0200 schrieb
> > pi.uhl at bluewin.ch:
> > > At the moment I have the same problem with at least 3 customers
> > > of mine. WLAN doesn't work anymore either. The only solution is
> > > powerless and afterwards it works again for some time. I would
> > > appreciate to install a watchdog which makes a reset every 24
> > > hours.
> > > Regards
> > > Pierre Uhl
> > > Von: OvmsDev <ovmsdev-bounces at lists.openvehicles.com> Im Auftrag
> > > von Chris van der Meijden
> > > Gesendet: Samstag, 15. Juli 2023 15:33
> > > An: ovmsdev at lists.openvehicles.com
> > > Betreff: Re: [Ovmsdev] Modem - Last Error: User Interrupt
> > > With the constantly PoweringOn state my odyssee started with the
> > > 5360 Modem.
> > > I recently changed to the 7600 and could not see anything obvious
> > > about "neglected" contacts.
> > > If this thing has no solution I'll write a script that does a
> > > reboot every 24 hours.
> > > Nothing we can't handle with a nice workaround ...
> > > Am Samstag, dem 15.07.2023 um 14:35 +0200 schrieb sharkcow:
> > > > Funny coincindence: my 5360 modem stopped working a few days
> > > > ago
> > > > (constantly in state PoweringOn). I tried rebooting & a
> > > > different
> > > > firmware to no avail. Just took the module out of the car,
> > > > opened it and
> > > > it ran fine on my workbench and then also back in the car...
> > > > maybe just
> > > > some bad contacts that needed some "love" :)
> > > > Am 14.07.23 um 19:47 schrieb Chris van der Meijden:
> > > > > After I upgraded my modem to a SIM7600 (and replaced my SIM
> > > > > card) I
> > > > > hoped the GSM would be running well again.
> > > > > I'm sorry to say that I still have issues. Every few days GSM
> > > > > will
> > > > > disconnect with "Last Error: User Interrupt". When it
> > > > > disconnects this
> > > > > way it won't connect anymore. Not even when I change
> > > > > location. Only
> > > > > after a "module reset" the connection comes back for another
> > > > > few days.
> > > > > The antenna I use is the internal antenna of the car. I had
> > > > > no issues
> > > > > like this last year. Same antenna then.
> > > > > Am I alone with this behauviour?
> > > > > Any ideas?
> > > > > Thanx
> > > > > Chris
> > > > > cellular status
> > > > > MODEM Status
> > > > > Model: SIM7600
> > > > > Network Registration: RegisteredHome
> > > > > Provider: congstar
> > > > > Signal: -77 dBm
> > > > > Mode: GSM;Online
> > > > > State: NetLoss
> > > > > Mux: Status up
> > > > > PPP: Not connected
> > > > > GPS: Not running
> > > > > module reset
> > > > > cellular status
> > > > > MODEM Status
> > > > > Model: SIM7600
> > > > > Provider: congstar
> > > > > Signal: -79 dBm
> > > > > Mode: LTE;Online
> > > > > State: NetMode
> > > > > Mux: Status up
> > > > > PPP: Connected on channel: #2
> > > > > GPS: Not running
> > > > > _______________________________________________
> > > > > OvmsDev mailing list
> > > > > OvmsDev at lists.openvehicles.com
> > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230802/c1466ce7/attachment.htm>
