[Ovmsdev] Presentation and first questions
Sat Apr 29 15:55:13 HKT 2023
Romuald,
welcome :-)
Am 27.04.23 um 15:06 schrieb Romuald Conty (Opus Codium):
> To reach my goals, I'll have to:
> - Read two CAN buses to grab and display values on a HUD
> - Make an expansion board with some IC which requires to talk using I²C
> - Publish events on a third CAN bus which exposes additional sensors values
> [...] To do it periodically, you would need a task
> Is there is a code base to write a task in OVMSv3 context? or a similar code
> that have the right architecture in current firmware?
There is a `TaskBase` class, but that doesn't offer much of an advantage
for your use case. Creating a task really is very simple with FreeRTOS.
Examples:
* The `obd2ecu` component derives & publishes HUD data using a task
and seems to be close to your use case.
* The `retools_pidscan` component uses a task to scan for PIDs on
OBD2/ISO-TP devices.
* The `canopen` component uses worker tasks to handle async CANopen
protocol communication.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230429/cb1577a5/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20230429/cb1577a5/attachment.sig>
