[Ovmsdev] Android App beta
Sun Sep 25 22:23:39 HKT 2022
No, icon can only be 0 from the else branch, in that case it shall fall
back to the default image.
But I've meanwhile found (I think) your maps/track crash, commit is
already in the hub. The checkbox handler didn't check if the map object
is initialized.
https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/FragMap.java#L319
Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
> Just guessing, but does
> int icon;
> in MyGcmListenerService.java
> <https://github.com/devmarxx/Open-Vehicle-Android/commit/3c13100a6a25257fe694be3050a1b76ca2b6fb44#diff-c13198cb33bb355f600c37f8889cedcb72346835dbb7e357c031c57aba424487> at
> line 132
> not need to be initialized like
> int icon = 0;
> now you use
> .setSmallIcon((icon!= 0) ? icon: R.drawable.map_car_default)
> at line 150 now?
> As the images and the Google stuff are related to that integer it made
> me thinking ...
> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
>> Chris,
>> that's not a crash log, that's just a warning.
>> On that warning: the App requests
>> android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe with
>> LineageOS you need to manually give it that permission?
>> A crash log has class "E" (error) and includes an exception and a
>> backtrace, for an example see:
>> https://issuetracker.google.com/issues/201308676#comment4
>> On the crash: maybe it's because you don't have the Google
>> components, not sure if FragMap can handle that.
>> The forum post relates to /e/OS … maybe I need some emulator images
>> running alternative Androids now…
>> Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
>> Hey Michael,
>> this is from logcat when I change "Track vehicle" and the app crashes:
>> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial:
>> receiving Intent { act=android.intent.action.SERVICE_STATE
>> flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54
>> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires
>> android.permission.ACCESS_FINE_LOCATION due to sender android (uid 1001)
>> I saw now, that this crash also happens in the production app.
>> The widget is running well. I will keep the app running for while and
>> will see if it stays stable.
>> Regards
>> Chris
>> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
>>> Chris,
>>> thanks for testing. A crash log would help on any crashes you see.
>>> Btw, I don't bump the revision until the actual release build.
>>> Crashes related to the car image don't occur immediately, it
>>> sometimes takes hours of use before it happens. When it does,
>>> clearing the App cache fixes the crash for another random period.
>>> Speed optimization was one goal. What about the widget?
>>> Thanks,
>>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
>>> Hey Michael,
>>> I just installed the "release" Version on LineageOS 19.1 (Android
>>> 12) without Google components.
>>> The vehicle setup was without any troubles. I could select the
>>> yellow VW e-UP image without crashing.
>>> The App version is set wrong under "Vehicle info" (3.19.1, 2021122401).
>>> Everything seems to be faster than before.
>>> When I change the checkbox on "Track vehicle" under "Position" the
>>> App crashes. But after a new start of the app the value of the
>>> checkbox has changed.
>>> Perhaps this first impression is of some help.
>>> Regards
>>> Chris
>>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
>>>> Everyone,
>>>> I'm currently working on the next Android release including
>>>> KustomWidget support and a native app widget based on the old
>>>> Automagic gauge widget.
>>>> Automagic has been dead for some time now, and it keeps crashing on
>>>> Androids >= 7.
>>>> My changes so far are in the hub, APK builds are available here:
>>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>>>> * debug build for extended logging:
>>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>>>> There's an issue with the App related to Android >= 10 though,
>>>> which I haven't found yet. It's been reported in the forum:
>>>> * https://www.openvehicles.com/node/3410
>>>> I could use some help with that, I've got no idea other than
>>>> blaming Android.
>>>> I've seen the effect in my emulator tests, and it seems to occur
>>>> more frequently with non-roadster images.
>>>> Regards,
>>>> Michael
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220925/dc709069/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220925/dc709069/attachment-0001.sig>
