[Ovmsdev] Android App beta
Sun Sep 25 23:52:21 HKT 2022
Hey Michael
Cool, thanx!
I just compiled the app with the new code. I got a lint error:
GPSTracker.java:73: Error: Missing permissions required by
LocationManager.requestLocationUpdates:
android.permission.ACCESS_COARSE_LOCATION or
android.permission.ACCESS_FINE_LOCATION [MissingPermission]
locationManager.requestLocationUpdates(
so I compiled with
gradlew build -x lint
and I could build the apk.
The app is running and the checkbox crash is solved :-)
If there is anything else I can check, just let me know.
Regards
Chris
Am Sonntag, dem 25.09.2022 um 16:23 +0200 schrieb Michael Balzer:
> No, icon can only be 0 from the else branch, in that case it shall
> fall back to the default image.
> But I've meanwhile found (I think) your maps/track crash, commit is
> already in the hub. The checkbox handler didn't check if the map
> object is initialized.
> https://github.com/openvehicles/Open-Vehicle-Android/blob/master/OpenVehicleApp/src/main/java/com/openvehicles/OVMS/ui/FragMap.java#L319
> Am 25.09.22 um 15:46 schrieb Chris van der Meijden:
> Just guessing, but does
> int icon;
> in MyGcmListenerService.java at line 132
> not need to be initialized like
> int icon = 0;
> now you use
> .setSmallIcon((icon != 0) ? icon : R.drawable.map_car_default)
> at line 150 now?
> As the images and the Google stuff are related to that integer it
> made me thinking ...
> Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
> > Chris,
> > that's not a crash log, that's just a warning.
> > On that warning: the App requests
> > android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe
> > with LineageOS you need to manually give it that permission?
> > A crash log has class "E" (error) and includes an exception and a
> > backtrace, for an example see:
> > https://issuetracker.google.com/issues/201308676#comment4
> > On the crash: maybe it's because you don't have the Google
> > components, not sure if FragMap can handle that.
> > The forum post relates to /e/OS … maybe I need some emulator images
> > running alternative Androids now…
> > Regards,
> > Michael
> > Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
> > Hey Michael,
> > this is from logcat when I change "Track vehicle" and the app
> > crashes:
> > 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial:
> > receiving Intent { act=android.intent.action.SERVICE_STATE
> > flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54
> > 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires
> > android.permission.ACCESS_FINE_LOCATION due to sender android (uid
> > 1001)
> > I saw now, that this crash also happens in the production app.
> > The widget is running well. I will keep the app running for while
> > and will see if it stays stable.
> > Regards
> > Chris
> > Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
> > > Chris,
> > > thanks for testing. A crash log would help on any crashes you
> > > see. Btw, I don't bump the revision until the actual release
> > > build.
> > > Crashes related to the car image don't occur immediately, it
> > > sometimes takes hours of use before it happens. When it does,
> > > clearing the App cache fixes the crash for another random period.
> > > Speed optimization was one goal. What about the widget?
> > > Thanks,
> > > Michael
> > > Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
> > > Hey Michael,
> > > I just installed the "release" Version on LineageOS 19.1 (Android
> > > 12) without Google components.
> > > The vehicle setup was without any troubles. I could select the
> > > yellow VW e-UP image without crashing.
> > > The App version is set wrong under "Vehicle info" (3.19.1,
> > > 2021122401).
> > > Everything seems to be faster than before.
> > > When I change the checkbox on "Track vehicle" under "Position"
> > > the App crashes. But after a new start of the app the value of
> > > the checkbox has changed.
> > > Perhaps this first impression is of some help.
> > > Regards
> > > Chris
> > > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
> > > > Everyone,
> > > > I'm currently working on the next Android release including
> > > > KustomWidget support and a native app widget based on the old
> > > > Automagic gauge widget.
> > > > Automagic has been dead for some time now, and it keeps
> > > > crashing on Androids >= 7.
> > > > My changes so far are in the hub, APK builds are available
> > > > here:
> > > >  * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
> > > >  * debug build for extended logging: https://dexters-web.de/f/tw-
> > > >    beta/OpenVehicleApp-22092401-debug.apk
> > > > There's an issue with the App related to Android >= 10 though,
> > > > which I haven't found yet. It's been reported in the forum:
> > > >  * https://www.openvehicles.com/node/3410
> > > > I could use some help with that, I've got no idea other than
> > > > blaming Android.
> > > > I've seen the effect in my emulator tests, and it seems to
> > > > occur more frequently with non-roadster images.
> > > > Regards,
> > > > Michael
> > > > _______________________________________________
> > > > OvmsDev mailing list
> > > > OvmsDev at lists.openvehicles.com
> > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220925/4b7e7f3c/attachment.htm>
