[Ovmsdev] Android App beta
    Chris van der Meijden
    chris at arachnon.de
    Sun Sep 25 21:46:12 HKT 2022
Just guessing, but does
int icon;
in MyGcmListenerService.java at line 132
not need to be initialized like
int icon = 0;
now you use
.setSmallIcon((icon != 0) ? icon : R.drawable.map_car_default)
at line 150 now?
As the images and the Google stuff are related to that integer it made
me thinking ...
Am Sonntag, dem 25.09.2022 um 11:52 +0200 schrieb Michael Balzer:
> Chris,
> that's not a crash log, that's just a warning.
> On that warning: the App requests
> android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe with
> LineageOS you need to manually give it that permission?
> A crash log has class "E" (error) and includes an exception and a
> backtrace, for an example see:
> https://issuetracker.google.com/issues/201308676#comment4
> On the crash: maybe it's because you don't have the Google
> components, not sure if FragMap can handle that.
> The forum post relates to /e/OS … maybe I need some emulator images
> running alternative Androids now…
> Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
> Hey Michael,
> this is from logcat when I change "Track vehicle" and the app
> crashes:
> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial:
> receiving Intent { act=android.intent.action.SERVICE_STATE
> flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54
> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires
> android.permission.ACCESS_FINE_LOCATION due to sender android (uid
> 1001)
> I saw now, that this crash also happens in the production app.
> The widget is running well. I will keep the app running for while and
> will see if it stays stable.
> Regards
> Chris
> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
> > Chris,
> > thanks for testing. A crash log would help on any crashes you see.
> > Btw, I don't bump the revision until the actual release build.
> > Crashes related to the car image don't occur immediately, it
> > sometimes takes hours of use before it happens. When it does,
> > clearing the App cache fixes the crash for another random period.
> > Speed optimization was one goal. What about the widget?
> > Thanks,
> > Michael
> > Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
> > Hey Michael,
> > I just installed the "release" Version on LineageOS 19.1 (Android
> > 12) without Google components.
> > The vehicle setup was without any troubles. I could select the
> > yellow VW e-UP image without crashing.
> > The App version is set wrong under "Vehicle info" (3.19.1,
> > 2021122401).
> > Everything seems to be faster than before.
> > When I change the checkbox on "Track vehicle" under "Position" the
> > App crashes. But after a new start of the app the value of the
> > checkbox has changed.
> > Perhaps this first impression is of some help.
> > Regards
> > Chris
> > Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
> > > Everyone,
> > > I'm currently working on the next Android release including
> > > KustomWidget support and a native app widget based on the old
> > > Automagic gauge widget.
> > > Automagic has been dead for some time now, and it keeps crashing
> > > on Androids >= 7.
> > > My changes so far are in the hub, APK builds are available here:
> > >  * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
> > >  * debug build for extended logging: https://dexters-web.de/f/tw-
> > >    beta/OpenVehicleApp-22092401-debug.apk
> > > There's an issue with the App related to Android >= 10 though,
> > > which I haven't found yet. It's been reported in the forum:
> > >  * https://www.openvehicles.com/node/3410
> > > I could use some help with that, I've got no idea other than
> > > blaming Android.
> > > I've seen the effect in my emulator tests, and it seems to occur
> > > more frequently with non-roadster images.
> > > Regards,
> > > Michael
> > > _______________________________________________
> > > OvmsDev mailing list
> > > OvmsDev at lists.openvehicles.com
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220925/c80df42e/attachment.htm>
