[Ovmsdev] Android App beta
Sun Sep 25 17:40:48 HKT 2022
Hey Michael,
this is from logcat when I change "Track vehicle" and the app crashes:
09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial:
receiving Intent { act=android.intent.action.SERVICE_STATE
flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54
2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires
android.permission.ACCESS_FINE_LOCATION due to sender android (uid
1001)
I saw now, that this crash also happens in the production app.
The widget is running well. I will keep the app running for while and
will see if it stays stable.
Regards
Chris
Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
> Chris,
> thanks for testing. A crash log would help on any crashes you see.
> Btw, I don't bump the revision until the actual release build.
> Crashes related to the car image don't occur immediately, it
> sometimes takes hours of use before it happens. When it does,
> clearing the App cache fixes the crash for another random period.
> Speed optimization was one goal. What about the widget?
> Thanks,
> Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
> Hey Michael,
> I just installed the "release" Version on LineageOS 19.1 (Android 12)
> without Google components.
> The vehicle setup was without any troubles. I could select the yellow
> VW e-UP image without crashing.
> The App version is set wrong under "Vehicle info" (3.19.1,
> 2021122401).
> Everything seems to be faster than before.
> When I change the checkbox on "Track vehicle" under "Position" the
> App crashes. But after a new start of the app the value of the
> checkbox has changed.
> Perhaps this first impression is of some help.
> Regards
> Chris
> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
> > Everyone,
> > I'm currently working on the next Android release including
> > KustomWidget support and a native app widget based on the old
> > Automagic gauge widget.
> > Automagic has been dead for some time now, and it keeps crashing on
> > Androids >= 7.
> > My changes so far are in the hub, APK builds are available here:
> >  * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
> >  * debug build for extended logging: https://dexters-web.de/f/tw-
> >    beta/OpenVehicleApp-22092401-debug.apk
> > There's an issue with the App related to Android >= 10 though,
> > which I haven't found yet. It's been reported in the forum:
> >  * https://www.openvehicles.com/node/3410
> > I could use some help with that, I've got no idea other than
> > blaming Android.
> > I've seen the effect in my emulator tests, and it seems to occur
> > more frequently with non-roadster images.
> > Regards,
> > Michael
> > OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220925/c0f2d542/attachment-0001.htm>
