[Ovmsdev] Android App beta
Sun Sep 25 05:02:21 HKT 2022
Chris,
thanks for testing. A crash log would help on any crashes you see. Btw,
I don't bump the revision until the actual release build.
Crashes related to the car image don't occur immediately, it sometimes
takes hours of use before it happens. When it does, clearing the App
cache fixes the crash for another random period.
Speed optimization was one goal. What about the widget?
Thanks,
Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
> Hey Michael,
> I just installed the "release" Version on LineageOS 19.1 (Android 12)
> without Google components.
> The vehicle setup was without any troubles. I could select the yellow
> VW e-UP image without crashing.
> The App version is set wrong under "Vehicle info" (3.19.1, 2021122401).
> Everything seems to be faster than before.
> When I change the checkbox on "Track vehicle" under "Position" the App
> crashes. But after a new start of the app the value of the checkbox
> has changed.
> Perhaps this first impression is of some help.
> Regards
> Chris
> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
>> Everyone,
>> I'm currently working on the next Android release including
>> KustomWidget support and a native app widget based on the old
>> Automagic gauge widget.
>> Automagic has been dead for some time now, and it keeps crashing on
>> Androids >= 7.
>> My changes so far are in the hub, APK builds are available here:
>>   * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>>   * debug build for extended logging:
>>     https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>> There's an issue with the App related to Android >= 10 though, which
>> I haven't found yet. It's been reported in the forum:
>>   * https://www.openvehicles.com/node/3410
>> I could use some help with that, I've got no idea other than blaming
>> Android.
>> I've seen the effect in my emulator tests, and it seems to occur more
>> frequently with non-roadster images.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220924/e5d8f399/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220924/e5d8f399/attachment.sig>
