[Ovmsdev] Android App beta
Sun Sep 25 04:43:52 HKT 2022
Hey Michael,
I just installed the "release" Version on LineageOS 19.1 (Android 12)
without Google components.
The vehicle setup was without any troubles. I could select the yellow
VW e-UP image without crashing.
The App version is set wrong under "Vehicle info" (3.19.1, 2021122401).
Everything seems to be faster than before.
When I change the checkbox on "Track vehicle" under "Position" the App
crashes. But after a new start of the app the value of the checkbox has
changed.
Perhaps this first impression is of some help.
Regards
Chris
Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
> Everyone,
> I'm currently working on the next Android release including
> KustomWidget support and a native app widget based on the old
> Automagic gauge widget.
> Automagic has been dead for some time now, and it keeps crashing on
> Androids >= 7.
> My changes so far are in the hub, APK builds are available here:
>  * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>  * debug build for extended logging: https://dexters-web.de/f/tw-
>    beta/OpenVehicleApp-22092401-debug.apk
> There's an issue with the App related to Android >= 10 though, which
> I haven't found yet. It's been reported in the forum:
>  * https://www.openvehicles.com/node/3410
> I could use some help with that, I've got no idea other than blaming
> Android.
> I've seen the effect in my emulator tests, and it seems to occur more
> frequently with non-roadster images.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220924/2965d30c/attachment.htm>
