[Ovmsdev] Android App beta
Sun Sep 25 17:52:11 HKT 2022
Chris,
that's not a crash log, that's just a warning.
On that warning: the App requests
android.permission.ACCESS_FINE_LOCATION by it's manifest. Maybe with
LineageOS you need to manually give it that permission?
A crash log has class "E" (error) and includes an exception and a
backtrace, for an example see:
https://issuetracker.google.com/issues/201308676#comment4
On the crash: maybe it's because you don't have the Google components,
not sure if FragMap can handle that.
The forum post relates to /e/OS … maybe I need some emulator images
running alternative Androids now…
Am 25.09.22 um 11:40 schrieb Chris van der Meijden:
> Hey Michael,
> this is from logcat when I change "Track vehicle" and the app crashes:
> 09-25 11:16:01.410 1710 1839 W BroadcastQueue: Permission Denial:
> receiving Intent { act=android.intent.action.SERVICE_STATE
> flg=0x1000010 (has extras) } to ProcessRecord{8dcdd54
> 2053:com.android.systemui/u0a148} (pid=2053, uid=10148) requires
> android.permission.ACCESS_FINE_LOCATION due to sender android (uid 1001)
> I saw now, that this crash also happens in the production app.
> The widget is running well. I will keep the app running for while and
> will see if it stays stable.
> Regards
> Chris
> Am Samstag, dem 24.09.2022 um 23:02 +0200 schrieb Michael Balzer:
>> Chris,
>> thanks for testing. A crash log would help on any crashes you see.
>> Btw, I don't bump the revision until the actual release build.
>> Crashes related to the car image don't occur immediately, it
>> sometimes takes hours of use before it happens. When it does,
>> clearing the App cache fixes the crash for another random period.
>> Speed optimization was one goal. What about the widget?
>> Thanks,
>> Am 24.09.22 um 22:43 schrieb Chris van der Meijden:
>> Hey Michael,
>> I just installed the "release" Version on LineageOS 19.1 (Android 12)
>> without Google components.
>> The vehicle setup was without any troubles. I could select the yellow
>> VW e-UP image without crashing.
>> The App version is set wrong under "Vehicle info" (3.19.1, 2021122401).
>> Everything seems to be faster than before.
>> When I change the checkbox on "Track vehicle" under "Position" the
>> App crashes. But after a new start of the app the value of the
>> checkbox has changed.
>> Perhaps this first impression is of some help.
>> Regards
>> Chris
>> Am Samstag, dem 24.09.2022 um 20:10 +0200 schrieb Michael Balzer:
>>> Everyone,
>>> I'm currently working on the next Android release including
>>> KustomWidget support and a native app widget based on the old
>>> Automagic gauge widget.
>>> Automagic has been dead for some time now, and it keeps crashing on
>>> Androids >= 7.
>>> My changes so far are in the hub, APK builds are available here:
>>> * https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-release.apk
>>> * debug build for extended logging:
>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-22092401-debug.apk
>>> There's an issue with the App related to Android >= 10 though, which
>>> I haven't found yet. It's been reported in the forum:
>>> * https://www.openvehicles.com/node/3410
>>> I could use some help with that, I've got no idea other than blaming
>>> Android.
>>> I've seen the effect in my emulator tests, and it seems to occur
>>> more frequently with non-roadster images.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220925/d392fb59/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220925/d392fb59/attachment.sig>
