[Ovmsdev] SIM7600 Registration Denied
Fri Sep 9 20:23:06 HKT 2022
A related issue -- I remember wanting to ask this before: why do we
receive all NMEA sentences three times / on three MUX channels?
Apparently they come in on channels 1, 3 and 4 -- stumbled across this
again because this now leads to these also being added to a cellular
command response:
OVMS# cell cmd AT+CMUX?
+CMUX: 0,0,5,118,0,0,600
OK
$GPRMC,114516.00,A,xxx.139223,N,xxx.391678,E,0.0,,090922,0.9,W,A*07
$GNGNS,114516.00,xxx.139223,N,xxx.391678,E,AAN,11,1.0,324.4,47.0,,,V*68
V (3388221) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
D (3388231) gsm-nmea: Incoming RMC:
V (3388231) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
V (3388231) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
V (3388241) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
D (3388241) gsm-nmea: Incoming GNS:
V (3388251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
V (3388261) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
V (3393221) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
D (3393231) gsm-nmea: Incoming RMC:
$GPRMC,114521.00,A,xxx.139223,N,xxx.391676,E,0.0,,090922,0.9,W,A*0D
V (3393231) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
V (3393231) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
V (3393241) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
D (3393241) gsm-nmea: Incoming GNS:
$GNGNS,114521.00,xxx.139223,N,xxx.391676,E,AAN,11,1.0,324.4,47.0,,,V*62
V (3393251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
V (3393261) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
This also produces a lot of unnecessary stress on the ESP's RX buffer,
doesn't it?
Channel 1 is the dedicated NMEA channel, 3 is POLL and 4 is CMD. I don't
see why channels 3 & 4 are used for these by the modem, but I also
cannot find any command meant to configure this.
Any idea on this?
Am 09.09.22 um 13:14 schrieb Michael Balzer:
> Mark,
> (am I the only one experiencing this?)
> I've had multiple times of temporarily frozen modem communication over
> the last days on my car module. That's new, so I think we should try
> to fix that before releasing.
> On my bench module there's a clear correlation between the extended
> status query and the frame errors. It's also not related to the NMEA
> messages, I've checked that, they come at another second.
> Log excerpts below.
> With frame errors responses also occasionally get corrupted, e.g.
> D (204251) cellular: mux-rx-line #3: Hologram",7
> I think the extended status responses now very often cause an overflow
> on the RX buffer when coming in together. Solution could be to split
> the queries and distribute over 2-3 seconds.
> I don't know if that will also fix the strange cold/warm boot
> difference with this, but maybe that's simply because the modem is
> faster with getting back to the network after a reboot, so the status
> responses become large quickly.
> D (204211) cellular: mux-tx #3:
> AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
> W (204251) gsm-mux: Frame error: EOF mismatch (CHAN=55, ADDR=df,
> CTRL=ff, FCS=35, LEN=133)
> V (204251) gsm-mux: Frame dump: f9 df ff ff bf bf dd ff f9 0d ff af 0d
> 0a 2b 43 | ..............+C
> V (204251) gsm-mux: Frame dump: 50 53 49 3a 20 4c 54 45 2c 4f 6e 6c 69
> 6e 65 2c | PSI: LTE,Online,
> V (204251) gsm-mux: Frame dump: 32 36 32 2d 30 32 2c 30 78 42 30 46 35
> 2c 31 33 | 262-02,0xB0F5,13
> V (204251) gsm-mux: Frame dump: 31 37 39 34 31 32 2c 34 34 38 2c 45 55
> 54 52 41 | 179412,448,EUTRA
> V (204251) gsm-mux: Frame dump: 4e 2d 42 41 4e 44 31 2c 31 30 30 2c 34
> 2c 34 2c | N-BAND1,100,4,4,
> V (204251) gsm-mux: Frame dump: 2d 39 32 2c 2d 31 31 35 32 2c 2d 38 37
> 35 2c 31 | -92,-1152,-875,1
> V (204251) gsm-mux: Frame dump: 34 0d 0a 34 f9 f9 0d ff ed 0d 0a 2b 43
> 52 45 47 | 4..4.......+CREG
> V (204251) gsm-mux: Frame dump: 3a 20 31 2c 35 0d 0a 0d 0a 2b 43 47 52
> 45 47 3a | : 1,5....+CGREG:
> V (204251) gsm-mux: Frame dump: 20 31 2c 35
> 0d | 1,5.
> V (204251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
> V (208231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
> V (208241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
> V (208251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
> V (208251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
> V (208271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
> V (233271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
> V (233271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
> D (234211) cellular: mux-tx #3:
> W (234211) cellular: UART frame error
> W (234231) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff,
> CTRL=ea, FCS=2c, LEN=53)
> V (234231) gsm-mux: Frame dump: f9 ff ea 5f ff b7 ff fd ff b9 df fd bf
> f9 ff fd | ..._............
> V (234231) gsm-mux: Frame dump: fb ff f9 f9 a9 f9 0d ff af 0d 0a 2b 43
> 50 53 49 | ...........+CPSI
> V (234231) gsm-mux: Frame dump: 3a 20 4c 54 45 2c 4f 6e 6c 69 6e 65 2c
> 32 36 32 | : LTE,Online,262
> V (234231) gsm-mux: Frame dump: 2d 30 32 2c
> 30 | -02,0
> V (234241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=a7,
> LEN=124)
> D (234241) cellular: mux-rx-line #3: +CREG: 1,5
> D (234241) cellular: mux-rx-line #3: +CGREG: 1,5
> D (234241) cellular: mux-rx-line #3: +CEREG: 1,5
> D (234241) cellular: mux-rx-line #3: +CCLK: "22/09/09,12:52:41+08"
> D (234241) cellular: mux-rx-line #3: +CSQ: 13,99
> V (234241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
> D (234251) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7
> V (238231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
> V (238241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
> V (293251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
> V (293251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
> V (293271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
> V (293271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
> D (294211) cellular: mux-tx #3:
> W (294211) cellular: UART frame error
> W (294241) gsm-mux: Frame error: EOF mismatch (CHAN=59, ADDR=ef,
> CTRL=db, FCS=2b, LEN=117)
> V (294241) gsm-mux: Frame dump: f9 ef db df ef df f7 cb f9 ff ff db 7f
> fd ff ff | ................
> V (294241) gsm-mux: Frame dump: f9 0d ff af 0d 0a 2b 43 50 53 49 3a 20
> 4c 54 45 | ......+CPSI: LTE
> V (294241) gsm-mux: Frame dump: 2c 4f 6e 6c 69 6e 65 2c 32 36 32 2d 30
> 32 2c 30 | ,Online,262-02,0
> V (294241) gsm-mux: Frame dump: 78 42 30 46 35 2c 31 33 31 37 39 34 31
> 32 2c 34 | xB0F5,13179412,4
> V (294241) gsm-mux: Frame dump: 34 38 2c 45 55 54 52 41 4e 2d 42 41 4e
> 44 31 2c | 48,EUTRAN-BAND1,
> V (294241) gsm-mux: Frame dump: 31 30 30 2c 34 2c 34 2c 2d 39 36 2c 2d
> 31 31 35 | 100,4,4,-96,-115
> V (294241) gsm-mux: Frame dump: 35 2c 2d 38 37 33 2c 31 34 0d 0a 34 f9
> f9 0d ff | 5,-873,14..4....
> V (294241) gsm-mux: Frame dump: ed 0d 0a 2b
> 43 | ...+C
> V (294251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
> D (294251) cellular: mux-rx-line #3: Hologram",7
> V (298231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
> V (298241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
> V (298241) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
> V (298251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
> V (298261) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
> V (298271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
> V (323251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
> V (323261) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
> V (323271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
> V (323271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
> D (324211) cellular: mux-tx #3:
> W (324231) gsm-mux: Frame error: EOF mismatch (CHAN=29, ADDR=77,
> CTRL=fb, FCS=45, LEN=125)
> V (324231) gsm-mux: Frame dump: f9 77 fb ef 5f ff bb ed fb bb db ff b7
> fb cf ff | .w.._...........
> V (324231) gsm-mux: Frame dump: bf d9 ff bb f9 0d ff b1 0d 0a 2b 43 50
> 53 49 3a | ..........+CPSI:
> V (324231) gsm-mux: Frame dump: 20 4c 54 45 2c 4f 6e 6c 69 6e 65 2c 32
> 36 32 2d | LTE,Online,262-
> V (324231) gsm-mux: Frame dump: 30 32 2c 30 78 42 30 46 35 2c 31 33 31
> 37 39 34 | 02,0xB0F5,131794
> V (324231) gsm-mux: Frame dump: 31 32 2c 34 34 38 2c 45 55 54 52 41 4e
> 2d 42 41 | 12,448,EUTRAN-BA
> V (324241) gsm-mux: Frame dump: 4e 44 31 2c 31 30 30 2c 34 2c 34 2c 2d
> 31 30 39 | ND1,100,4,4,-109
> V (324241) gsm-mux: Frame dump: 2c 2d 31 31 36 36 2c 2d 38 37 34 2c 31
> 31 0d 0a | ,-1166,-874,11..
> V (324241) gsm-mux: Frame dump: c2 f9 f9 0d ff ed 0d 0a 2b 43 52 45
> 47 | ........+CREG
> V (324241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
> D (324241) cellular: mux-rx-line #3: Hologram",7
> V (328231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
> V (328241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
> V (328251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
> V (353251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
> V (353251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
> V (353271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
> V (353271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
> D (354211) cellular: mux-tx #3:
> W (354211) cellular: UART frame error
> V (354231) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=34, LEN=93)
> D (354231) cellular: mux-rx-line #3: +CPSI:
> LTE,Online,262-02,0xB0F5,13179412,448,EUTRAN-BAND1,100,4,4,-122,-1184,-874,9
> V (354241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=a7,
> LEN=124)
> D (354241) cellular: mux-rx-line #3: +CREG: 1,5
> D (354241) cellular: mux-rx-line #3: +CGREG: 1,5
> D (354241) cellular: mux-rx-line #3: +CEREG: 1,5
> D (354241) cellular: mux-rx-line #3: +CCLK: "22/09/09,12:54:41+08"
> D (354251) cellular: mux-rx-line #3: +CSQ: 13,99
> V (354251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
> D (354251) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7
> V (358231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
> V (358241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
> V (358251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
> Am 08.09.22 um 07:15 schrieb Mark Webb-Johnson:
>> Michael,
>> I reviewed:
>> $ git diff 2b25287fbef5fa968236cb8e556ea11da7c8f579
>> components/ovms_cellular components/simcom
>> But can’t see anything really related to frame errors, other than the
>> two extra CGREG and CEREG output lines once every thirty seconds.
>> Maybe an existing issue re-occurring?
>> Do you think this should block our release of 3.3.003 to ‘main’ release?
>>> On 4 Sep 2022, at 4:17 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Signed PGP part
>>> I'm seeing an issue with the current build, but not sure if that's
>>> new & related to the latest changes or just coincidentally has
>>> become more severe somehow:
>>> On a cold boot, modem communication is mostly fine, nearly no UART
>>> frame errors, and messages received by the modem are fine.
>>> After the first warm reboot, initial modem messages are garbled, and
>>> lots of UART frame errors occur right from the beginning of modem
>>> communication.
>>> This looks like some part of the serial communication now doesn't
>>> get fully reset on a reboot. Log attached.
>>> Am 03.09.22 um 11:37 schrieb Michael Balzer:
>>>> EAP release also done on ovms.dexters-web.de
>>>> <http://ovms.dexters-web.de>.
>>>> Regards,
>>>> Michael
>>>> Am 01.09.22 um 02:53 schrieb Mark Webb-Johnson:
>>>>> Sounds good. I think this is important enough to make a formal
>>>>> release so I will arrange that.
>>>>> I have made a 3.3.003, and released to EAP on api.openvehicles.com
>>>>> <http://api.openvehicles.com/>. We can target a main release for
>>>>> next week.
>>>>> Regards, Mark.
>>>>> P.S. I have a bunch of unrelated enhancements to CAN logging to
>>>>> commit, but those can wait.
>>>>>> On 31 Aug 2022, at 10:27 PM, Michael Balzer <dexter at expeedo.de>
>>>>>> wrote:
>>>>>> Signed PGP part
>>>>>> Looks good:
>>>>>> Model: SIMCOM_SIM7600G
>>>>>> Revision: SIM7600M21-A_V2.0
>>>>>> D (80128) cellular: mux-tx #3:
>>>>>> D (80158) cellular: mux-rx-line #3: +CPSI:
>>>>>> LTE,Online,262-02,0xB0F5,12829697,303,EUTRAN-BAND20,6300,3,3,-93,-969,-701,17
>>>>>> D (80168) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>> D (80168) cellular: mux-rx-line #3: +CGREG: 1,5
>>>>>> D (80168) cellular: mux-rx-line #3: +CEREG: 1,5
>>>>>> D (80168) cellular: mux-rx-line #3: +CCLK: "22/08/31,11:15:03+08"
>>>>>> D (80168) cellular: mux-rx-line #3: +CSQ: 21,99
>>>>>> D (80168) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>> <http://vodafone.de/> Hologram",7
>>>>>> Model: SIMCOM_SIM5360E
>>>>>> Revision: SIM5360E_V3.5
>>>>>> D (74307) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
>>>>>> D (74327) cellular: mux-rx-line #3: +CPSI:
>>>>>> GSM,Online,262-02,0x011f,14822,4 EGSM 900,-69,0,38-38
>>>>>> D (74337) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>> D (74337) cellular: mux-rx-line #3: +CCLK: "22/08/31,11:19:47+08"
>>>>>> D (74337) cellular: mux-rx-line #3: +CSQ: 22,99
>>>>>> D (74337) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>> <http://vodafone.de/> Hologram",0
>>>>>> Revision: SIM7600M21-A_V2.0.1
>>>>>> D (324279) cellular: mux-tx #3:
>>>>>> D (324309) cellular: mux-rx-line #3: +CPSI:
>>>>>> LTE,Online,262-01,0x34B9,29268996,36,EUTRAN-BAND3,1444,3,3,-147,-1213,-889,8
>>>>>> D (324319) cellular: mux-rx-line #3: +CREG: 1,1
>>>>>> D (324319) cellular: mux-rx-line #3: +CGREG: 1,1
>>>>>> D (324319) cellular: mux-rx-line #3: +CEREG: 1,1
>>>>>> D (324319) cellular: mux-rx-line #3: +CCLK: "22/08/31,12:22:05+08"
>>>>>> D (324319) cellular: mux-rx-line #3: +CSQ: 11,99
>>>>>> D (324319) cellular: mux-rx-line #3: +COPS: 0,0," congstar",7
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 31.08.22 um 10:41 schrieb Mark Webb-Johnson:
>>>>>>> I’ve made some further revisions. Now in latest edge -49 release.
>>>>>>> Grateful for feedback on this, please. Particularly with SIM5360
>>>>>>> (which should be unaffected, but …).
>>>>>>> Regards, Mark.
>>>>>>>> On 26 Aug 2022, at 10:17 PM, Michael Balzer<dexter at expeedo.de>
>>>>>>>> wrote:
>>>>>>>> Signed PGP part
>>>>>>>> From testing on my three modules here in Germany, looks good:
>>>>>>>> D (151128) cellular: mux-tx #3:
>>>>>>>> D (151158) cellular: mux-rx-line #3: +CPSI:
>>>>>>>> LTE,Online,262-02,0xB0F5,13179412,448,EUTRAN-BAND1,100,4,4,-93,-1141,-864,14
>>>>>>>> D (151168) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>>>> D (151168) cellular: mux-rx-line #3: +CGREG: 1,5
>>>>>>>> D (151168) cellular: mux-rx-line #3: +CEREG: 1,5
>>>>>>>> D (151168) cellular: mux-rx-line #3: +CCLK: "22/08/26,09:13:51+08"
>>>>>>>> D (151168) cellular: mux-rx-line #3: +CSQ: 13,99
>>>>>>>> D (151168) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>>>> D (143784) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
>>>>>>>> D (143804) cellular: mux-rx-line #3: +CPSI:
>>>>>>>> GSM,Online,262-02,0x011f,14822,4 EGSM 900,-66,0,41-41
>>>>>>>> D (143814) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>>>> D (143814) cellular: mux-rx-line #3: +CCLK: "22/08/26,09:24:20+08"
>>>>>>>> D (143814) cellular: mux-rx-line #3: +CSQ: 23,99
>>>>>>>> D (143814) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>>>> D (9625359) cellular: mux-tx #3:
>>>>>>>> D (9625389) cellular: mux-rx-line #3: +CPSI:
>>>>>>>> LTE,Online,262-01,0x34B9,29268999,268,EUTRAN-BAND8,3749,2,2,-112,-1042,-791,15
>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CREG: 1,1
>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CGREG: 1,1
>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CEREG: 1,1
>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CCLK: "22/08/26,12:40:14+08"
>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CSQ: 15,99
>>>>>>>> D (9625399) cellular: mux-rx-line #3: +COPS: 0,0," congstar",7
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> Am 26.08.22 um 08:53 schrieb Mark Webb-Johnson:
>>>>>>>>> Thanks.
>>>>>>>>> I think anyone in USA using Hologram on T-Mobile would benefit
>>>>>>>>> from this. I just worry I break something else.
>>>>>>>>> Regards, Mark.
>>>>>>>>>> On 26 Aug 2022, at 2:46 PM, Craig Leres<leres at xse.com> wrote:
>>>>>>>>>> On 8/25/22 23:34, Mark Webb-Johnson wrote:
>>>>>>>>>>> I’ve been fighting a problem for the past few months with
>>>>>>>>>>> registration getting denied on T-Mobile in USA using
>>>>>>>>>>> Hologram and our new 4G SIM7600G modem. Without cellular
>>>>>>>>>>> connectivity at home, it hasn’t been easy to recreate this,
>>>>>>>>>>> but I found a solution:
>>>>>>>>>> I've been seeing intermittent netreg errors lately; I've
>>>>>>>>>> booted this version on a couple of my modules...
>>>>>>>>>> Craig
>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>> <220904-UART-frame-errors.txt>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220909/14214b05/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220909/14214b05/attachment-0001.sig>
