[Ovmsdev] SIM7600 Registration Denied
Fri Sep 9 19:14:45 HKT 2022
Mark,
(am I the only one experiencing this?)
I've had multiple times of temporarily frozen modem communication over
the last days on my car module. That's new, so I think we should try to
fix that before releasing.
On my bench module there's a clear correlation between the extended
status query and the frame errors. It's also not related to the NMEA
messages, I've checked that, they come at another second.
Log excerpts below.
With frame errors responses also occasionally get corrupted, e.g.
D (204251) cellular: mux-rx-line #3: Hologram",7
I think the extended status responses now very often cause an overflow
on the RX buffer when coming in together. Solution could be to split the
queries and distribute over 2-3 seconds.
I don't know if that will also fix the strange cold/warm boot difference
with this, but maybe that's simply because the modem is faster with
getting back to the network after a reboot, so the status responses
become large quickly.
D (204211) cellular: mux-tx #3:
AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
W (204251) gsm-mux: Frame error: EOF mismatch (CHAN=55, ADDR=df,
CTRL=ff, FCS=35, LEN=133)
V (204251) gsm-mux: Frame dump: f9 df ff ff bf bf dd ff f9 0d ff af 0d
0a 2b 43 | ..............+C
V (204251) gsm-mux: Frame dump: 50 53 49 3a 20 4c 54 45 2c 4f 6e 6c 69
6e 65 2c | PSI: LTE,Online,
V (204251) gsm-mux: Frame dump: 32 36 32 2d 30 32 2c 30 78 42 30 46 35
2c 31 33 | 262-02,0xB0F5,13
V (204251) gsm-mux: Frame dump: 31 37 39 34 31 32 2c 34 34 38 2c 45 55
54 52 41 | 179412,448,EUTRA
V (204251) gsm-mux: Frame dump: 4e 2d 42 41 4e 44 31 2c 31 30 30 2c 34
2c 34 2c | N-BAND1,100,4,4,
V (204251) gsm-mux: Frame dump: 2d 39 32 2c 2d 31 31 35 32 2c 2d 38 37
35 2c 31 | -92,-1152,-875,1
V (204251) gsm-mux: Frame dump: 34 0d 0a 34 f9 f9 0d ff ed 0d 0a 2b 43
52 45 47 | 4..4.......+CREG
V (204251) gsm-mux: Frame dump: 3a 20 31 2c 35 0d 0a 0d 0a 2b 43 47 52
45 47 3a | : 1,5....+CGREG:
V (204251) gsm-mux: Frame dump: 20 31 2c 35
0d                                  |  1,5.
V (204251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
V (208231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
V (208241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
V (208251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
V (208251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
V (208271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
V (233271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
V (233271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
D (234211) cellular: mux-tx #3:
W (234211) cellular: UART frame error
W (234231) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff,
CTRL=ea, FCS=2c, LEN=53)
V (234231) gsm-mux: Frame dump: f9 ff ea 5f ff b7 ff fd ff b9 df fd bf
f9 ff fd | ..._............
V (234231) gsm-mux: Frame dump: fb ff f9 f9 a9 f9 0d ff af 0d 0a 2b 43
50 53 49 | ...........+CPSI
V (234231) gsm-mux: Frame dump: 3a 20 4c 54 45 2c 4f 6e 6c 69 6e 65 2c
32 36 32 | : LTE,Online,262
V (234231) gsm-mux: Frame dump: 2d 30 32 2c
30                                  | -02,0
V (234241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=a7, LEN=124)
D (234241) cellular: mux-rx-line #3: +CREG: 1,5
D (234241) cellular: mux-rx-line #3: +CGREG: 1,5
D (234241) cellular: mux-rx-line #3: +CEREG: 1,5
D (234241) cellular: mux-rx-line #3: +CCLK: "22/09/09,12:52:41+08"
D (234241) cellular: mux-rx-line #3: +CSQ: 13,99
V (234241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
D (234251) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7
V (238231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
V (238241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
V (293251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
V (293251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
V (293271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
V (293271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
D (294211) cellular: mux-tx #3:
W (294211) cellular: UART frame error
W (294241) gsm-mux: Frame error: EOF mismatch (CHAN=59, ADDR=ef,
CTRL=db, FCS=2b, LEN=117)
V (294241) gsm-mux: Frame dump: f9 ef db df ef df f7 cb f9 ff ff db 7f
fd ff ff | ................
V (294241) gsm-mux: Frame dump: f9 0d ff af 0d 0a 2b 43 50 53 49 3a 20
4c 54 45 | ......+CPSI: LTE
V (294241) gsm-mux: Frame dump: 2c 4f 6e 6c 69 6e 65 2c 32 36 32 2d 30
32 2c 30 | ,Online,262-02,0
V (294241) gsm-mux: Frame dump: 78 42 30 46 35 2c 31 33 31 37 39 34 31
32 2c 34 | xB0F5,13179412,4
V (294241) gsm-mux: Frame dump: 34 38 2c 45 55 54 52 41 4e 2d 42 41 4e
44 31 2c | 48,EUTRAN-BAND1,
V (294241) gsm-mux: Frame dump: 31 30 30 2c 34 2c 34 2c 2d 39 36 2c 2d
31 31 35 | 100,4,4,-96,-115
V (294241) gsm-mux: Frame dump: 35 2c 2d 38 37 33 2c 31 34 0d 0a 34 f9
f9 0d ff | 5,-873,14..4....
V (294241) gsm-mux: Frame dump: ed 0d 0a 2b
43                                  | ...+C
V (294251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
D (294251) cellular: mux-rx-line #3: Hologram",7
V (298231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
V (298241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
V (298241) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
V (298251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
V (298261) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
V (298271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
V (323251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
V (323261) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
V (323271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
V (323271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
D (324211) cellular: mux-tx #3:
W (324231) gsm-mux: Frame error: EOF mismatch (CHAN=29, ADDR=77,
CTRL=fb, FCS=45, LEN=125)
V (324231) gsm-mux: Frame dump: f9 77 fb ef 5f ff bb ed fb bb db ff b7
fb cf ff | .w.._...........
V (324231) gsm-mux: Frame dump: bf d9 ff bb f9 0d ff b1 0d 0a 2b 43 50
53 49 3a | ..........+CPSI:
V (324231) gsm-mux: Frame dump: 20 4c 54 45 2c 4f 6e 6c 69 6e 65 2c 32
36 32 2d |  LTE,Online,262-
V (324231) gsm-mux: Frame dump: 30 32 2c 30 78 42 30 46 35 2c 31 33 31
37 39 34 | 02,0xB0F5,131794
V (324231) gsm-mux: Frame dump: 31 32 2c 34 34 38 2c 45 55 54 52 41 4e
2d 42 41 | 12,448,EUTRAN-BA
V (324241) gsm-mux: Frame dump: 4e 44 31 2c 31 30 30 2c 34 2c 34 2c 2d
31 30 39 | ND1,100,4,4,-109
V (324241) gsm-mux: Frame dump: 2c 2d 31 31 36 36 2c 2d 38 37 34 2c 31
31 0d 0a | ,-1166,-874,11..
V (324241) gsm-mux: Frame dump: c2 f9 f9 0d ff ed 0d 0a 2b 43 52 45
47          | ........+CREG
V (324241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
D (324241) cellular: mux-rx-line #3: Hologram",7
V (328231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
V (328241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
V (328251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
V (353251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
V (353251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1, LEN=82)
V (353271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4, LEN=82)
V (353271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9, LEN=82)
D (354211) cellular: mux-tx #3:
W (354211) cellular: UART frame error
V (354231) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=34, LEN=93)
D (354231) cellular: mux-rx-line #3: +CPSI:
LTE,Online,262-02,0xB0F5,13179412,448,EUTRAN-BAND1,100,4,4,-122,-1184,-874,9
V (354241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=a7, LEN=124)
D (354241) cellular: mux-rx-line #3: +CREG: 1,5
D (354241) cellular: mux-rx-line #3: +CGREG: 1,5
D (354241) cellular: mux-rx-line #3: +CEREG: 1,5
D (354241) cellular: mux-rx-line #3: +CCLK: "22/09/09,12:54:41+08"
D (354251) cellular: mux-rx-line #3: +CSQ: 13,99
V (354251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da, LEN=25)
D (354251) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7
V (358231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf, LEN=78)
V (358241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa, LEN=78)
V (358251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7, LEN=78)
Am 08.09.22 um 07:15 schrieb Mark Webb-Johnson:
> Michael,
> I reviewed:
>     $ git diff 2b25287fbef5fa968236cb8e556ea11da7c8f579
>     components/ovms_cellular components/simcom
> But can’t see anything really related to frame errors, other than the
> two extra CGREG and CEREG output lines once every thirty seconds.
> Maybe an existing issue re-occurring?
> Do you think this should block our release of 3.3.003 to ‘main’ release?
>> On 4 Sep 2022, at 4:17 PM, Michael Balzer <dexter at expeedo.de> wrote:
>> Signed PGP part
>> I'm seeing an issue with the current build, but not sure if that's
>> new & related to the latest changes or just coincidentally has become
>> more severe somehow:
>> On a cold boot, modem communication is mostly fine, nearly no UART
>> frame errors, and messages received by the modem are fine.
>> After the first warm reboot, initial modem messages are garbled, and
>> lots of UART frame errors occur right from the beginning of modem
>> communication.
>> This looks like some part of the serial communication now doesn't get
>> fully reset on a reboot. Log attached.
>> Am 03.09.22 um 11:37 schrieb Michael Balzer:
>>> EAP release also done on ovms.dexters-web.de
>>> <http://ovms.dexters-web.de>.
>>> Am 01.09.22 um 02:53 schrieb Mark Webb-Johnson:
>>>> Sounds good. I think this is important enough to make a formal
>>>> release so I will arrange that.
>>>> I have made a 3.3.003, and released to EAP on api.openvehicles.com
>>>> <http://api.openvehicles.com/>. We can target a main release for
>>>> next week.
>>>> Regards, Mark.
>>>> P.S. I have a bunch of unrelated enhancements to CAN logging to
>>>> commit, but those can wait.
>>>>> On 31 Aug 2022, at 10:27 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> Signed PGP part
>>>>> Looks good:
>>>>> Model: SIMCOM_SIM7600G
>>>>> Revision: SIM7600M21-A_V2.0
>>>>> D (80128) cellular: mux-tx #3:
>>>>> D (80158) cellular: mux-rx-line #3: +CPSI:
>>>>> LTE,Online,262-02,0xB0F5,12829697,303,EUTRAN-BAND20,6300,3,3,-93,-969,-701,17
>>>>> D (80168) cellular: mux-rx-line #3: +CREG: 1,5
>>>>> D (80168) cellular: mux-rx-line #3: +CGREG: 1,5
>>>>> D (80168) cellular: mux-rx-line #3: +CEREG: 1,5
>>>>> D (80168) cellular: mux-rx-line #3: +CCLK: "22/08/31,11:15:03+08"
>>>>> D (80168) cellular: mux-rx-line #3: +CSQ: 21,99
>>>>> D (80168) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>> <http://vodafone.de/> Hologram",7
>>>>> Model: SIMCOM_SIM5360E
>>>>> Revision: SIM5360E_V3.5
>>>>> D (74307) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
>>>>> D (74327) cellular: mux-rx-line #3: +CPSI:
>>>>> GSM,Online,262-02,0x011f,14822,4 EGSM 900,-69,0,38-38
>>>>> D (74337) cellular: mux-rx-line #3: +CREG: 1,5
>>>>> D (74337) cellular: mux-rx-line #3: +CCLK: "22/08/31,11:19:47+08"
>>>>> D (74337) cellular: mux-rx-line #3: +CSQ: 22,99
>>>>> D (74337) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>> <http://vodafone.de/> Hologram",0
>>>>> Revision: SIM7600M21-A_V2.0.1
>>>>> D (324279) cellular: mux-tx #3:
>>>>> D (324309) cellular: mux-rx-line #3: +CPSI:
>>>>> LTE,Online,262-01,0x34B9,29268996,36,EUTRAN-BAND3,1444,3,3,-147,-1213,-889,8
>>>>> D (324319) cellular: mux-rx-line #3: +CREG: 1,1
>>>>> D (324319) cellular: mux-rx-line #3: +CGREG: 1,1
>>>>> D (324319) cellular: mux-rx-line #3: +CEREG: 1,1
>>>>> D (324319) cellular: mux-rx-line #3: +CCLK: "22/08/31,12:22:05+08"
>>>>> D (324319) cellular: mux-rx-line #3: +CSQ: 11,99
>>>>> D (324319) cellular: mux-rx-line #3: +COPS: 0,0," congstar",7
>>>>> Regards,
>>>>> Michael
>>>>> Am 31.08.22 um 10:41 schrieb Mark Webb-Johnson:
>>>>>> I’ve made some further revisions. Now in latest edge -49 release.
>>>>>> Grateful for feedback on this, please. Particularly with SIM5360
>>>>>> (which should be unaffected, but …).
>>>>>> Regards, Mark.
>>>>>>> On 26 Aug 2022, at 10:17 PM, Michael Balzer<dexter at expeedo.de>
>>>>>>>  wrote:
>>>>>>> Signed PGP part
>>>>>>> From testing on my three modules here in Germany, looks good:
>>>>>>> D (151128) cellular: mux-tx #3:
>>>>>>> D (151158) cellular: mux-rx-line #3: +CPSI:
>>>>>>> LTE,Online,262-02,0xB0F5,13179412,448,EUTRAN-BAND1,100,4,4,-93,-1141,-864,14
>>>>>>> D (151168) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>>> D (151168) cellular: mux-rx-line #3: +CGREG: 1,5
>>>>>>> D (151168) cellular: mux-rx-line #3: +CEREG: 1,5
>>>>>>> D (151168) cellular: mux-rx-line #3: +CCLK: "22/08/26,09:13:51+08"
>>>>>>> D (151168) cellular: mux-rx-line #3: +CSQ: 13,99
>>>>>>> D (151168) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>>> D (143784) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
>>>>>>> D (143804) cellular: mux-rx-line #3: +CPSI:
>>>>>>> GSM,Online,262-02,0x011f,14822,4 EGSM 900,-66,0,41-41
>>>>>>> D (143814) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>>> D (143814) cellular: mux-rx-line #3: +CCLK: "22/08/26,09:24:20+08"
>>>>>>> D (143814) cellular: mux-rx-line #3: +CSQ: 23,99
>>>>>>> D (143814) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>>> D (9625359) cellular: mux-tx #3:
>>>>>>> D (9625389) cellular: mux-rx-line #3: +CPSI:
>>>>>>> LTE,Online,262-01,0x34B9,29268999,268,EUTRAN-BAND8,3749,2,2,-112,-1042,-791,15
>>>>>>> D (9625399) cellular: mux-rx-line #3: +CREG: 1,1
>>>>>>> D (9625399) cellular: mux-rx-line #3: +CGREG: 1,1
>>>>>>> D (9625399) cellular: mux-rx-line #3: +CEREG: 1,1
>>>>>>> D (9625399) cellular: mux-rx-line #3: +CCLK: "22/08/26,12:40:14+08"
>>>>>>> D (9625399) cellular: mux-rx-line #3: +CSQ: 15,99
>>>>>>> D (9625399) cellular: mux-rx-line #3: +COPS: 0,0,"  congstar",7
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 26.08.22 um 08:53 schrieb Mark Webb-Johnson:
>>>>>>>> Thanks.
>>>>>>>> I think anyone in USA using Hologram on T-Mobile would benefit
>>>>>>>> from this. I just worry I break something else.
>>>>>>>> Regards, Mark.
>>>>>>>>> On 26 Aug 2022, at 2:46 PM, Craig Leres<leres at xse.com>  wrote:
>>>>>>>>> On 8/25/22 23:34, Mark Webb-Johnson wrote:
>>>>>>>>>> I’ve been fighting a problem for the past few months with
>>>>>>>>>> registration getting denied on T-Mobile in USA using Hologram
>>>>>>>>>> and our new 4G SIM7600G modem. Without cellular connectivity
>>>>>>>>>> at home, it hasn’t been easy to recreate this, but I found a
>>>>>>>>>> solution:
>>>>>>>>> I've been seeing intermittent netreg errors lately; I've
>>>>>>>>> booted this version on a couple of my modules...
>>>>>>>>> Craig
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>> <220904-UART-frame-errors.txt>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220909/afe07674/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220909/afe07674/attachment-0001.sig>
