[Ovmsdev] SIM7600 Registration Denied
Sat Sep 10 03:00:09 HKT 2022
Regarding the UART frame errors:
1. disabling GPS doesn't change anything
2. splitting the status poll into two queries doesn't change anything
3. issuing a UART HW FIFO reset
(https://github.com/espressif/esp-idf/commit/5404252e803f5489a72119a3ad41b580f2881a2a)
4. explicitly setting the mode to standard UART doesn't change anything
5. performing a deep sleep instead of a standard reboot doesn't change
anything
6. brute force writing a cycle of all 1's and all 0's twice to the full
UART1 register range before driver init doesn't change anything
Apparently, the ESP32 UART has some kind of hardware flaw leading to an
ESP32 reset actually not doing a full UART reset.
* https://www.esp32.com/viewtopic.php?t=4701
* https://github.com/espressif/esp-idf/commit/5404252e803f5489a72119a3ad41b580f2881a2a
* https://github.com/espressif/esp-idf/commit/f482e9e54ce83e249e46f5ee082f6ffb61431339
* …some were lucky with this patch:
https://esp32.com/viewtopic.php?f=2&t=4725 …we are not.
> //Due to hardware issue, we can not use fifo_rst to reset uart fifo.
> //See description about UART_TXFIFO_RST and UART_RXFIFO_RST in
> <<esp32_technical_reference_manual>> v2.6 or later.
There is apparently no method to perform a full UART HW reset, at least
I haven't found one. It seems this is an issue we cannot fix (in software).
But I now don't think this is a new issue, and this also affects modules
quite differently, no idea depending on what circumstances: on the
current run, my car module has lots of FIFO overflows & quite some MUX
framing errors, but not a single UART frame error.
IOW, I don't think we should let that block the release.
Am 09.09.22 um 14:23 schrieb Michael Balzer:
> A related issue -- I remember wanting to ask this before: why do we
> receive all NMEA sentences three times / on three MUX channels?
> Apparently they come in on channels 1, 3 and 4 -- stumbled across this
> again because this now leads to these also being added to a cellular
> command response:
> OVMS# cell cmd AT+CMUX?
> +CMUX: 0,0,5,118,0,0,600
> OK
> $GPRMC,114516.00,A,xxx.139223,N,xxx.391678,E,0.0,,090922,0.9,W,A*07
> $GNGNS,114516.00,xxx.139223,N,xxx.391678,E,AAN,11,1.0,324.4,47.0,,,V*68
> V (3388221) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
> LEN=78)
> D (3388231) gsm-nmea: Incoming RMC:
> V (3388231) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
> LEN=78)
> V (3388231) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
> LEN=78)
> V (3388241) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
> LEN=82)
> D (3388241) gsm-nmea: Incoming GNS:
> V (3388251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
> LEN=82)
> V (3388261) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
> LEN=82)
> V (3393221) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
> LEN=78)
> D (3393231) gsm-nmea: Incoming RMC:
> $GPRMC,114521.00,A,xxx.139223,N,xxx.391676,E,0.0,,090922,0.9,W,A*0D
> V (3393231) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
> LEN=78)
> V (3393231) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
> LEN=78)
> V (3393241) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
> LEN=82)
> D (3393241) gsm-nmea: Incoming GNS:
> $GNGNS,114521.00,xxx.139223,N,xxx.391676,E,AAN,11,1.0,324.4,47.0,,,V*62
> V (3393251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
> LEN=82)
> V (3393261) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
> LEN=82)
> This also produces a lot of unnecessary stress on the ESP's RX buffer,
> doesn't it?
> Channel 1 is the dedicated NMEA channel, 3 is POLL and 4 is CMD. I
> don't see why channels 3 & 4 are used for these by the modem, but I
> also cannot find any command meant to configure this.
> Any idea on this?
> Am 09.09.22 um 13:14 schrieb Michael Balzer:
>> Mark,
>> (am I the only one experiencing this?)
>> I've had multiple times of temporarily frozen modem communication
>> over the last days on my car module. That's new, so I think we should
>> try to fix that before releasing.
>> On my bench module there's a clear correlation between the extended
>> status query and the frame errors. It's also not related to the NMEA
>> messages, I've checked that, they come at another second.
>> Log excerpts below.
>> With frame errors responses also occasionally get corrupted, e.g.
>> D (204251) cellular: mux-rx-line #3: Hologram",7
>> I think the extended status responses now very often cause an
>> overflow on the RX buffer when coming in together. Solution could be
>> to split the queries and distribute over 2-3 seconds.
>> I don't know if that will also fix the strange cold/warm boot
>> difference with this, but maybe that's simply because the modem is
>> faster with getting back to the network after a reboot, so the status
>> responses become large quickly.
>> D (204211) cellular: mux-tx #3:
>> AT+CREG?;+CGREG?;+CEREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
>> W (204251) gsm-mux: Frame error: EOF mismatch (CHAN=55, ADDR=df,
>> CTRL=ff, FCS=35, LEN=133)
>> V (204251) gsm-mux: Frame dump: f9 df ff ff bf bf dd ff f9 0d ff af
>> 0d 0a 2b 43 | ..............+C
>> V (204251) gsm-mux: Frame dump: 50 53 49 3a 20 4c 54 45 2c 4f 6e 6c
>> 69 6e 65 2c | PSI: LTE,Online,
>> V (204251) gsm-mux: Frame dump: 32 36 32 2d 30 32 2c 30 78 42 30 46
>> 35 2c 31 33 | 262-02,0xB0F5,13
>> V (204251) gsm-mux: Frame dump: 31 37 39 34 31 32 2c 34 34 38 2c 45
>> 55 54 52 41 | 179412,448,EUTRA
>> V (204251) gsm-mux: Frame dump: 4e 2d 42 41 4e 44 31 2c 31 30 30 2c
>> 34 2c 34 2c | N-BAND1,100,4,4,
>> V (204251) gsm-mux: Frame dump: 2d 39 32 2c 2d 31 31 35 32 2c 2d 38
>> 37 35 2c 31 | -92,-1152,-875,1
>> V (204251) gsm-mux: Frame dump: 34 0d 0a 34 f9 f9 0d ff ed 0d 0a 2b
>> 43 52 45 47 | 4..4.......+CREG
>> V (204251) gsm-mux: Frame dump: 3a 20 31 2c 35 0d 0a 0d 0a 2b 43 47
>> 52 45 47 3a | : 1,5....+CGREG:
>> V (204251) gsm-mux: Frame dump: 20 31 2c 35
>> 0d | 1,5.
>> V (204251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da,
>> LEN=25)
>> V (208231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
>> LEN=78)
>> V (208241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>> LEN=78)
>> V (208251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>> LEN=78)
>> V (208251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
>> LEN=82)
>> V (208271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>> LEN=82)
>> V (233271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>> LEN=82)
>> V (233271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
>> LEN=82)
>> D (234211) cellular: mux-tx #3:
>> W (234211) cellular: UART frame error
>> W (234231) gsm-mux: Frame error: EOF mismatch (CHAN=63, ADDR=ff,
>> CTRL=ea, FCS=2c, LEN=53)
>> V (234231) gsm-mux: Frame dump: f9 ff ea 5f ff b7 ff fd ff b9 df fd
>> bf f9 ff fd | ..._............
>> V (234231) gsm-mux: Frame dump: fb ff f9 f9 a9 f9 0d ff af 0d 0a 2b
>> 43 50 53 49 | ...........+CPSI
>> V (234231) gsm-mux: Frame dump: 3a 20 4c 54 45 2c 4f 6e 6c 69 6e 65
>> 2c 32 36 32 | : LTE,Online,262
>> V (234231) gsm-mux: Frame dump: 2d 30 32 2c
>> 30 | -02,0
>> V (234241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=a7,
>> LEN=124)
>> D (234241) cellular: mux-rx-line #3: +CREG: 1,5
>> D (234241) cellular: mux-rx-line #3: +CGREG: 1,5
>> D (234241) cellular: mux-rx-line #3: +CEREG: 1,5
>> D (234241) cellular: mux-rx-line #3: +CCLK: "22/09/09,12:52:41+08"
>> D (234241) cellular: mux-rx-line #3: +CSQ: 13,99
>> V (234241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da,
>> LEN=25)
>> D (234251) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7
>> V (238231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
>> LEN=78)
>> V (238241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>> LEN=78)
>> V (293251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>> LEN=78)
>> V (293251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
>> LEN=82)
>> V (293271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>> LEN=82)
>> V (293271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
>> LEN=82)
>> D (294211) cellular: mux-tx #3:
>> W (294211) cellular: UART frame error
>> W (294241) gsm-mux: Frame error: EOF mismatch (CHAN=59, ADDR=ef,
>> CTRL=db, FCS=2b, LEN=117)
>> V (294241) gsm-mux: Frame dump: f9 ef db df ef df f7 cb f9 ff ff db
>> 7f fd ff ff | ................
>> V (294241) gsm-mux: Frame dump: f9 0d ff af 0d 0a 2b 43 50 53 49 3a
>> 20 4c 54 45 | ......+CPSI: LTE
>> V (294241) gsm-mux: Frame dump: 2c 4f 6e 6c 69 6e 65 2c 32 36 32 2d
>> 30 32 2c 30 | ,Online,262-02,0
>> V (294241) gsm-mux: Frame dump: 78 42 30 46 35 2c 31 33 31 37 39 34
>> 31 32 2c 34 | xB0F5,13179412,4
>> V (294241) gsm-mux: Frame dump: 34 38 2c 45 55 54 52 41 4e 2d 42 41
>> 4e 44 31 2c | 48,EUTRAN-BAND1,
>> V (294241) gsm-mux: Frame dump: 31 30 30 2c 34 2c 34 2c 2d 39 36 2c
>> 2d 31 31 35 | 100,4,4,-96,-115
>> V (294241) gsm-mux: Frame dump: 35 2c 2d 38 37 33 2c 31 34 0d 0a 34
>> f9 f9 0d ff | 5,-873,14..4....
>> V (294241) gsm-mux: Frame dump: ed 0d 0a 2b
>> 43 | ...+C
>> V (294251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da,
>> LEN=25)
>> D (294251) cellular: mux-rx-line #3: Hologram",7
>> V (298231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
>> LEN=78)
>> V (298241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>> LEN=78)
>> V (298241) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>> LEN=78)
>> V (298251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
>> LEN=82)
>> V (298261) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>> LEN=82)
>> V (298271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
>> LEN=82)
>> V (323251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>> LEN=78)
>> V (323261) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
>> LEN=82)
>> V (323271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>> LEN=82)
>> V (323271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
>> LEN=82)
>> D (324211) cellular: mux-tx #3:
>> W (324231) gsm-mux: Frame error: EOF mismatch (CHAN=29, ADDR=77,
>> CTRL=fb, FCS=45, LEN=125)
>> V (324231) gsm-mux: Frame dump: f9 77 fb ef 5f ff bb ed fb bb db ff
>> b7 fb cf ff | .w.._...........
>> V (324231) gsm-mux: Frame dump: bf d9 ff bb f9 0d ff b1 0d 0a 2b 43
>> 50 53 49 3a | ..........+CPSI:
>> V (324231) gsm-mux: Frame dump: 20 4c 54 45 2c 4f 6e 6c 69 6e 65 2c
>> 32 36 32 2d | LTE,Online,262-
>> V (324231) gsm-mux: Frame dump: 30 32 2c 30 78 42 30 46 35 2c 31 33
>> 31 37 39 34 | 02,0xB0F5,131794
>> V (324231) gsm-mux: Frame dump: 31 32 2c 34 34 38 2c 45 55 54 52 41
>> 4e 2d 42 41 | 12,448,EUTRAN-BA
>> V (324241) gsm-mux: Frame dump: 4e 44 31 2c 31 30 30 2c 34 2c 34 2c
>> 2d 31 30 39 | ND1,100,4,4,-109
>> V (324241) gsm-mux: Frame dump: 2c 2d 31 31 36 36 2c 2d 38 37 34 2c
>> 31 31 0d 0a | ,-1166,-874,11..
>> V (324241) gsm-mux: Frame dump: c2 f9 f9 0d ff ed 0d 0a 2b 43 52 45
>> 47 | ........+CREG
>> V (324241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da,
>> LEN=25)
>> D (324241) cellular: mux-rx-line #3: Hologram",7
>> V (328231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
>> LEN=78)
>> V (328241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>> LEN=78)
>> V (328251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>> LEN=78)
>> V (353251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>> LEN=78)
>> V (353251) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=b1,
>> LEN=82)
>> V (353271) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=f4,
>> LEN=82)
>> V (353271) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f9,
>> LEN=82)
>> D (354211) cellular: mux-tx #3:
>> W (354211) cellular: UART frame error
>> V (354231) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=34,
>> LEN=93)
>> D (354231) cellular: mux-rx-line #3: +CPSI:
>> LTE,Online,262-02,0xB0F5,13179412,448,EUTRAN-BAND1,100,4,4,-122,-1184,-874,9
>> V (354241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=a7,
>> LEN=124)
>> D (354241) cellular: mux-rx-line #3: +CREG: 1,5
>> D (354241) cellular: mux-rx-line #3: +CGREG: 1,5
>> D (354241) cellular: mux-rx-line #3: +CEREG: 1,5
>> D (354241) cellular: mux-rx-line #3: +CCLK: "22/09/09,12:54:41+08"
>> D (354251) cellular: mux-rx-line #3: +CSQ: 13,99
>> V (354251) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=da,
>> LEN=25)
>> D (354251) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de Hologram",7
>> V (358231) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=bf,
>> LEN=78)
>> V (358241) gsm-mux: ProcessFrame(CHAN=3, ADDR=0d, CTRL=ff, FCS=fa,
>> LEN=78)
>> V (358251) gsm-mux: ProcessFrame(CHAN=4, ADDR=11, CTRL=ff, FCS=f7,
>> LEN=78)
>> Am 08.09.22 um 07:15 schrieb Mark Webb-Johnson:
>>> Michael,
>>> I reviewed:
>>> $ git diff 2b25287fbef5fa968236cb8e556ea11da7c8f579
>>> components/ovms_cellular components/simcom
>>> But can’t see anything really related to frame errors, other than
>>> the two extra CGREG and CEREG output lines once every thirty seconds.
>>> Maybe an existing issue re-occurring?
>>> Do you think this should block our release of 3.3.003 to ‘main’ release?
>>>> On 4 Sep 2022, at 4:17 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Signed PGP part
>>>> I'm seeing an issue with the current build, but not sure if that's
>>>> new & related to the latest changes or just coincidentally has
>>>> become more severe somehow:
>>>> On a cold boot, modem communication is mostly fine, nearly no UART
>>>> frame errors, and messages received by the modem are fine.
>>>> After the first warm reboot, initial modem messages are garbled,
>>>> and lots of UART frame errors occur right from the beginning of
>>>> modem communication.
>>>> This looks like some part of the serial communication now doesn't
>>>> get fully reset on a reboot. Log attached.
>>>> Regards,
>>>> Michael
>>>> Am 03.09.22 um 11:37 schrieb Michael Balzer:
>>>>> EAP release also done on ovms.dexters-web.de
>>>>> <http://ovms.dexters-web.de>.
>>>>> Regards,
>>>>> Michael
>>>>> Am 01.09.22 um 02:53 schrieb Mark Webb-Johnson:
>>>>>> Sounds good. I think this is important enough to make a formal
>>>>>> release so I will arrange that.
>>>>>> I have made a 3.3.003, and released to EAP on
>>>>>> api.openvehicles.com <http://api.openvehicles.com/>. We can
>>>>>> target a main release for next week.
>>>>>> Regards, Mark.
>>>>>> P.S. I have a bunch of unrelated enhancements to CAN logging to
>>>>>> commit, but those can wait.
>>>>>>> On 31 Aug 2022, at 10:27 PM, Michael Balzer <dexter at expeedo.de>
>>>>>>> wrote:
>>>>>>> Signed PGP part
>>>>>>> Looks good:
>>>>>>> Model: SIMCOM_SIM7600G
>>>>>>> Revision: SIM7600M21-A_V2.0
>>>>>>> D (80128) cellular: mux-tx #3:
>>>>>>> D (80158) cellular: mux-rx-line #3: +CPSI:
>>>>>>> LTE,Online,262-02,0xB0F5,12829697,303,EUTRAN-BAND20,6300,3,3,-93,-969,-701,17
>>>>>>> D (80168) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>>> D (80168) cellular: mux-rx-line #3: +CGREG: 1,5
>>>>>>> D (80168) cellular: mux-rx-line #3: +CEREG: 1,5
>>>>>>> D (80168) cellular: mux-rx-line #3: +CCLK: "22/08/31,11:15:03+08"
>>>>>>> D (80168) cellular: mux-rx-line #3: +CSQ: 21,99
>>>>>>> D (80168) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>>> <http://vodafone.de/> Hologram",7
>>>>>>> Model: SIMCOM_SIM5360E
>>>>>>> Revision: SIM5360E_V3.5
>>>>>>> D (74307) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
>>>>>>> D (74327) cellular: mux-rx-line #3: +CPSI:
>>>>>>> GSM,Online,262-02,0x011f,14822,4 EGSM 900,-69,0,38-38
>>>>>>> D (74337) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>>> D (74337) cellular: mux-rx-line #3: +CCLK: "22/08/31,11:19:47+08"
>>>>>>> D (74337) cellular: mux-rx-line #3: +CSQ: 22,99
>>>>>>> D (74337) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>>> <http://vodafone.de/> Hologram",0
>>>>>>> Revision: SIM7600M21-A_V2.0.1
>>>>>>> D (324279) cellular: mux-tx #3:
>>>>>>> D (324309) cellular: mux-rx-line #3: +CPSI:
>>>>>>> LTE,Online,262-01,0x34B9,29268996,36,EUTRAN-BAND3,1444,3,3,-147,-1213,-889,8
>>>>>>> D (324319) cellular: mux-rx-line #3: +CREG: 1,1
>>>>>>> D (324319) cellular: mux-rx-line #3: +CGREG: 1,1
>>>>>>> D (324319) cellular: mux-rx-line #3: +CEREG: 1,1
>>>>>>> D (324319) cellular: mux-rx-line #3: +CCLK: "22/08/31,12:22:05+08"
>>>>>>> D (324319) cellular: mux-rx-line #3: +CSQ: 11,99
>>>>>>> D (324319) cellular: mux-rx-line #3: +COPS: 0,0," congstar",7
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 31.08.22 um 10:41 schrieb Mark Webb-Johnson:
>>>>>>>> I’ve made some further revisions. Now in latest edge -49 release.
>>>>>>>> Grateful for feedback on this, please. Particularly with
>>>>>>>> SIM5360 (which should be unaffected, but …).
>>>>>>>> Regards, Mark.
>>>>>>>>> On 26 Aug 2022, at 10:17 PM, Michael Balzer<dexter at expeedo.de>
>>>>>>>>> wrote:
>>>>>>>>> Signed PGP part
>>>>>>>>> From testing on my three modules here in Germany, looks good:
>>>>>>>>> D (151128) cellular: mux-tx #3:
>>>>>>>>> D (151158) cellular: mux-rx-line #3: +CPSI:
>>>>>>>>> LTE,Online,262-02,0xB0F5,13179412,448,EUTRAN-BAND1,100,4,4,-93,-1141,-864,14
>>>>>>>>> D (151168) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>>>>> D (151168) cellular: mux-rx-line #3: +CGREG: 1,5
>>>>>>>>> D (151168) cellular: mux-rx-line #3: +CEREG: 1,5
>>>>>>>>> D (151168) cellular: mux-rx-line #3: +CCLK: "22/08/26,09:13:51+08"
>>>>>>>>> D (151168) cellular: mux-rx-line #3: +CSQ: 13,99
>>>>>>>>> D (151168) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>>>>> D (143784) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
>>>>>>>>> D (143804) cellular: mux-rx-line #3: +CPSI:
>>>>>>>>> GSM,Online,262-02,0x011f,14822,4 EGSM 900,-66,0,41-41
>>>>>>>>> D (143814) cellular: mux-rx-line #3: +CREG: 1,5
>>>>>>>>> D (143814) cellular: mux-rx-line #3: +CCLK: "22/08/26,09:24:20+08"
>>>>>>>>> D (143814) cellular: mux-rx-line #3: +CSQ: 23,99
>>>>>>>>> D (143814) cellular: mux-rx-line #3: +COPS: 0,0,"vodafone.de
>>>>>>>>> D (9625359) cellular: mux-tx #3:
>>>>>>>>> D (9625389) cellular: mux-rx-line #3: +CPSI:
>>>>>>>>> LTE,Online,262-01,0x34B9,29268999,268,EUTRAN-BAND8,3749,2,2,-112,-1042,-791,15
>>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CREG: 1,1
>>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CGREG: 1,1
>>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CEREG: 1,1
>>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CCLK:
>>>>>>>>> "22/08/26,12:40:14+08"
>>>>>>>>> D (9625399) cellular: mux-rx-line #3: +CSQ: 15,99
>>>>>>>>> D (9625399) cellular: mux-rx-line #3: +COPS: 0,0," congstar",7
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 26.08.22 um 08:53 schrieb Mark Webb-Johnson:
>>>>>>>>>> Thanks.
>>>>>>>>>> I think anyone in USA using Hologram on T-Mobile would
>>>>>>>>>> benefit from this. I just worry I break something else.
>>>>>>>>>> Regards, Mark.
>>>>>>>>>>> On 26 Aug 2022, at 2:46 PM, Craig Leres<leres at xse.com> wrote:
>>>>>>>>>>> On 8/25/22 23:34, Mark Webb-Johnson wrote:
>>>>>>>>>>>> I’ve been fighting a problem for the past few months with
>>>>>>>>>>>> registration getting denied on T-Mobile in USA using
>>>>>>>>>>>> Hologram and our new 4G SIM7600G modem. Without cellular
>>>>>>>>>>>> connectivity at home, it hasn’t been easy to recreate this,
>>>>>>>>>>>> but I found a solution:
>>>>>>>>>>> I've been seeing intermittent netreg errors lately; I've
>>>>>>>>>>> booted this version on a couple of my modules...
>>>>>>>>>>> Craig
>>>>>>>>>> _______________________________________________
>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>> <220904-UART-frame-errors.txt>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220909/3b56a174/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220909/3b56a174/attachment-0001.sig>
