[Ovmsdev] savvycan foo
Michael Geddes
Sun Oct 2 16:01:43 HKT 2022
I had 'fun' working with savvycan as well. It's probably easier to read
logs downloaded from the SD Card!!
One way around the disconnect issue with TCP connection is to use some
TCP/IP -> Com port program, and then connect
to the COM port from savvycan, since you can reconnect COM devices (but not
TCP/IP ones).
IT seems to last a bit longer, and the reconnect is much easier.
//.ichael
On Sun, 2 Oct 2022 at 10:17, Craig Leres <leres at xse.com> wrote:
> I clearly do not understand how to drive savvycan.
> I have two versions on a windows 10 laptop:
> ?, self identifies as V203, circa April 2021
> 1.0.245, self identifies as V204, circa May 2021
> Connecting is very problematic. I started with my Cadillac which
> "works". As per the documentation I started with:
> can log start tcpserver discard gvret-b :23
> I was never able to connect with the May version.
> (Meanwhile, the FreeBSD version 1.0.245 port "works" as well as the
> Windows May executable... BTW, I'm the port *maintainer* for this!)
> With the older, April version I can sometimes connect but it's painful;
> if anything goes wrong or once it disconnects, I do not know how to
> reconnect, the *only* option appears to be to delete the device and add
> it back...
> In the rare cases I was able to connect (to a vehicle with an ovms
> module that I have started a tcpserver on, and the engine running) it
> *always* disconnects after N frames are received (about 125K for the
> Cadillac). It's like it fills up a buffer and quits. As stated, I do not
> understand how to drive this tool.
> The 2nd gen CTS has two buses: a canbus @ 500k and a single wire canbus
> @ 33.333k. Is it really not possible to configure the buses to
> *different* speeds? (And if gvret-b allows savvycan to know how many
> buses the network device has why doesn't it know what their respective
> speeds are? And why is 33.3333 missing?)
> Sorry for ranting about savvycan issues on the ovmsdev list but I have
> to believe some of you folks understand how make it do something useful.
> Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221002/622fd12c/attachment.htm>
