[Ovmsdev] OBDII vehicle chicken-n-egg issue
Craig Leres leres at xse.com
Sun Oct 2 10:17:06 HKT 2022
I cloned the OBDII module when I started work on the C6 Corvette and 2nd
gen CTS modules. Trying to debug my C6 Corvette canbus issues I'm not
understanding how OBD polling works.
What I see when I look at vehicle_obdii.cpp is that there is a list of
pids that are polled. However, OvmsVehicleOBDII::IncomingPollReply() is
the only place that *enables* polling:
     case 0x0c:  // Engine RPM
       if (value2 == 0)
         { // Car engine is OFF
         PollSetState(0);
         StandardMetrics.ms_v_env_handbrake->SetValue(true);
         StandardMetrics.ms_v_env_on->SetValue(false);
         StandardMetrics.ms_v_pos_speed->SetValue(0);
         StandardMetrics.ms_v_env_charging12v->SetValue(false);
       else
         { // Car engine is ON
         PollSetState(1);
         StandardMetrics.ms_v_env_handbrake->SetValue(false);
         StandardMetrics.ms_v_env_on->SetValue(true);
         StandardMetrics.ms_v_env_charging12v->SetValue(true);
       break;
I can only assume "engine RPM" canbus frames are always sent by the
vehicle (not unreasonable); but then I don't understand why we are
polling for it? I guess I would expect ms_v_env_on state changes to
happen in SOvmsVehicleOBDII::IncomingFrameCan1(). But maybe
OvmsVehicleOBDII::IncomingPollReply() gets engine RPM frames since they
are on the list of things we're polling for? So if we didn't handle them
in IncomingPollReply() we'd have to add a IncomingFrameCan1() routine?
Playing around with savvycan I find it's possible to have the C6
Corvette, with engine running, to not be "on" but still send canbus
frames to savvycan (at least until *it* gives up and disconnects). This
makes me think I'm getting into a situation where ovms does not detect
that the car is on but not because the canbus is not working due to
logic errors on my part. Certainly "can can1 status" reports a similar
number of tx fails when compared to my working vehicle (2nd gen Cadillac).
		Craig
