[Ovmsdev] New Metric Units
    Michael Geddes
    Tue Nov 15 08:26:43 HKT 2022
If you're ok with the [default] option I'll stick with that. I mean in some
ways it would be nice to have a button choice
metric | usa | europe | asia | custom   etc and I kind of considered
something like that but figured it's only a handful of choices.. and it's
an embedded device.. so simpler is better.
On a related note - I was thinking how it would be nice if the dashboard
(etc) had access to the 'user' units, so went hunting down that little
rabbit hole. Quite a nice mechanism with the web socket updating the
"metrics" object in the UI.
This is a snippet of one idea, which is that for any metric that has the
possibility of a user unit, we set the extra values of the metric with
'#unit' and '#user' appended - see below. (I've chosen '#' arbitrarily..
but it could be '/' or ':' or '>'  but maybe not '.' )
v.p.odometer#unit: "M"
v.p.odometer#user: 6754.91
v.p.satcount: 13
v.p.speed: 0
v.p.speed#unit: "km/h"
v.p.speed#user: null
*v.p.trip: 28*
*v.p.trip#unit: "M"v.p.trip#user: 17.3984*
Then we can use this in the dials to populate the values and captions! (not
that I like Miles).
I
[image: image.png]
The other (similar) way was to have something like the following:
"v.p.trip#user" : { "value": 17.3984, "unit": "M" }
It wouldn't make the total message any shorter.. soo.. dunno.
There's also some complications with setting up the dials (for min/max
values) - like for the speed.
Notice also that I'm returning null for undefined values. It's nice - but
I'm not sure how javascript handles null when used / printed etc.
//.ichael
On Sun, 13 Nov 2022 at 21:06, Michael Balzer <dexter at expeedo.de> wrote:
> Michael,
> looks good.
> I think having an explicit 'default' option is better than taking the
> 'Metric' equivalent for that, as in your example you already show unit
> alternatives within the metric system to support different scalings (kW /
> W, kWh / Wh). (Btw… waiting for someone to miss Horsepower & BTU here ;-))
> @Patrick, I think that also answers your implicit question:
> The default button makes it unclear what the actual setting is.
> The default (native unit) is always metric, but you may have a mix of
> scalings, as we try to find the one that fits best for the given
> application when defining a metric. For example the current driving energy
> consumption is stored natively in Wh/km, while the energy used or
> regenerated is in kWh, and the odometer & trip counters are in km, while
> the altitude ist in m.
> Am 13.11.22 um 08:42 schrieb Michael Geddes:
> Greetings,
> so this is my idea of being able to select which units various groups use
> (in addition to Distance).
> This can be then accessed by the special 'user' unit code.  (or  'metrics
> list -u ' )
> The idea of [Default] selection below  simply means storing the value to
> blank - meaning use whatever unit the particular metric uses.  The other
> idea I had was to actually default it to the equivalent of 'Metric' special
> unit code and not have the [Default] button.
> [image: image.png]
> Currently I've made it so that if there are more than 3 choices other than
> [default] that it uses the choice/combo box rather than the Radio buttons.
> (ie this list is auto-generated from the Metric Units table and the Metric
> Groups table).
> Thoughts / comments?
> //.ichael
> On Sat, 12 Nov 2022 at 17:35, Michael Geddes <frog at bunyip.wheelycreek.net>
> wrote:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/771
>> I'm hoping this P/R is ok in this form (made of 5 separate commits).
>> I will have a look at implementing the "user" unit code.  The base for
>> how it would work is already a part of the above pull request.  I'll just
>> look at the module configuration for distance.
>> The 'power consumption' is one where it's not just a check-box.. there're
>> 5 possible choice!
>> I should also add 'bar' for pressure given that for some reason that's
>> still a thing people want.
>> //.ichael
>> On Sat, 12 Nov 2022 at 16:24, Michael Balzer <dexter at expeedo.de> wrote:
>>> I think this is pretty decent & complete now.
>>> I also like the approach of the 'user' unit code. Moving all user unit
>>> prefs into the module configuration is an old todo. Currently only the
>>> distance unit is defined at the module side, temperature and pressure are
>>> App prefs.
>>> Am 11.11.22 um 09:54 schrieb Michael Geddes:
>>> Ok - so here's what I have implemented for Duktape and Metrics. (I added
>>> IsDefined() as well).
>>> Any thoughts on this?
>>> Noting
>>>    OvmsMetrics.Float( {metric} ) -> Outputs metric as float (same)
>>>    OvmsMetrics.Float( {metric}, {unit}) -> Outputs metric as float
>>> converted to given unit  (new)
>>>    OvmsMetrics.Value( {metric} )   -> Outputs Metric in native value
>>> (same)
>>>    OvmsMetrics.Value( {metric} , false)   -> Outputs Metric as string
>>> and no units (same)
>>>    OvmsMetrics.Value( {metric} ,  {unit})  -> Outputs Metric converted
>>> to given unit as native value. (new)
>>>   OvmsMetrics.Value( {metric} ,  {unit}, false )  -> Outputs Metric
>>> converted to given unit as string including any unit specifier. (new)
>>> also  OvmsMetric.GetValues( {metric} [,{unit}] [, {converted} ] )  Adds
>>> similar behaviour to Value() above.
>>> also the special units '*imperial*' and '*metric*' will convert to the
>>> associated imperial / metric version of the units as appropriate.
>>> (function() {
>>>    dump = function (metric) { print( metric+ " ["+(typeof metric)+"]\n"
>>>    dump_obj = function (obj )  {
>>>      print('--- Object ----\n')
>>>      for (var k in obj) {
>>>        xk = obj[k];
>>>        print( k+':'+ xk + ' ['+typeof xk+ "]\n");
>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption"));
>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", false));
>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh"));
>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false));
>>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption"));
>>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh"));
>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial"))
>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial", false))
>>>    dump_obj(OvmsMetrics.GetValues("trip", "metric"))
>>>    dump_obj(OvmsMetrics.GetValues("trip", "imperial", false))
>>> With this output:
>>> 19.2308 [number]
>>> 19.2308 [string]
>>> 5.2 [number]
>>> 3.23112mi/kWh [string]
>>> 19.2308 [number]
>>> 5.2 [number]
>>> 309.49 [number]
>>> 309.49Wh/mi [string]
>>> --- Object ----
>>> v.p.trip:13 [number]
>>> xiq.e.trip:0 [number]
>>> xiq.e.trip.energy.recuperated:0 [number]
>>> xiq.e.trip.energy.used:0 [number]
>>> xiq.v.trip.consumption:19.2308 [number]
>>> --- Object ----
>>> v.p.trip:8.07781M [string]
>>> xiq.e.trip:0M [string]
>>> xiq.e.trip.energy.recuperated:0kWh [string]
>>> xiq.e.trip.energy.used:0kWh [string]
>>> xiq.v.trip.consumption:309.49Wh/mi [string]
>>> On Wed, 9 Nov 2022 at 05:47, Michael Geddes <frog at bunyip.wheelycreek.net>
>>> wrote:
>>>> Yeah - I like HasValue.  I implemented IsDefined() but I will rename
>>>> it.. that's a much clearer name.
>>>> Another thought. How about if we did this (but also with GetValues() as
>>>> well - see the special values below)
>>>> OvmsMetrics.Value("xiq.v.trip.consumption",  true)  -> 17.0582
>>>> (Number)
>>>> OvmsMetrics.Value("xiq.v.trip.consumption",  false)  -> 17.0582
>>>> (String)
>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", true)  -> 3.64264
>>>> (Number)
>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)  ->
>>>> 3.64264Mi/kWh  (String)
>>>>  OvmsMetrics.Value("xiq.v.trip.consumption", "native", false)  ->
>>>> 17.0582km/kWh  (String)
>>>> and
>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "imperial", false)  ->
>>>> I have already implemented the special values 'native' (existing),
>>>> 'imperial' and 'metric'.
>>>> I was also thinking that in the future you could have 'user'. Where for
>>>> each group of values:
>>>> 'temperature', 'distance', 'shortdistance', 'power' etc.. you could
>>>> have a user preference. I probably won't implement it now,.but it could be
>>>> cool that any UI could just ask for the user defined units (rather than
>>>> having a separate choice).
>>>> //.ichael
>>>> On Tue, 8 Nov 2022 at 21:57, Mark Webb-Johnson <mark at webb-johnson.net>
>>>> wrote:
>>>>> Or perhaps something more specific?
>>>>>     HasValue()
>>>>> Mark
>>>>> On 8 Nov 2022, at 9:01 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> Signed PGP part
>>>>> That's basically a good approach, but be aware 'IsDefined()' has an
>>>>> ambiguous meaning here, as with the API stem "OvmsMetrics" it would
>>>>> naturally be expected to mean "is this metric defined", not "does this
>>>>> metric have a defined value".
>>>>> An undefined metric currently can be derived from 'Values()' returning
>>>>> undefined, but that's more an undocumented side effect than intended.
>>>>> Maybe 'GetDefined()' could be a better name, leveraging this
>>>>> behaviour, i.e. returning 'undefined' for an actually undefined metric, and
>>>>> 'null' for a defined metric without a value.
>>>>> Regards,
>>>>> Michael
>>>>> Am 08.11.22 um 13:46 schrieb Michael Geddes:
>>>>> Ah yes. Arrays - will check those.  Yeah, how about we add a
>>>>> 'IsDefined' method to metrics instead of the null thing (it does sound like
>>>>> it will upset too many applecarts).
>>>>> On Tue, 8 Nov 2022 at 20:35, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>> Michael,
>>>>>> looks all good to me, once again nice find with the decode argument.
>>>>>> Adding decode to the Value() call was only for symmetry IIRC, the main use
>>>>>> was with GetValues() (
>>>>>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsmetrics
>>>>>> Don't forget to test arrays, e.g. "v.t.pressure" & "v.t.temp".
>>>>>> Returning null for an undefined metric seems like a natural choice,
>>>>>> but is a rather deep change, as for consistency not only the Duktape
>>>>>> metrics API but also the Web UI metrics API would need to be changed
>>>>>> accordingly. Unless you've got a real use case that needs that, we should
>>>>>> be careful.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 07.11.22 um 15:00 schrieb Michael Geddes:
>>>>>> I have figured out a bunch of stuff and have implemented the
>>>>>> following: (having done away with needing AsFloatUnit)
>>>>>> OvmsMetrics.Value( {metric} [, {decode}])
>>>>>> OvmsMetrics.Value( {metric}, {unit} [,{decode}])
>>>>>> It turns out that the [decode] flag wasn't working anyway (since the
>>>>>> function was being registered as only having 1 param)...
>>>>>> This way it is still really 1 function.. but I check it the second
>>>>>> parameter is a 'boolean', and if not.. try the second form.
>>>>>> OvmsMetrics.AsFloat( {metric} [,{unit}] )
>>>>>> and add the function
>>>>>> Ovms.Metrics.ValueUnit( {metric} [,{unit}])
>>>>>> This prints the value and the unit.
>>>>>> Here's a sample function and the output! This also shows the types of
>>>>>> the output.
>>>>>> (function() {
>>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption");
>>>>>>    print( (typeof x) + ": "+  x+"\n"  );
>>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption", false);
>>>>>>    print( (typeof x) + ": "+  x +"\n" );
>>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh")
>>>>>>    print( (typeof x) + ": "+ x +"\n");
>>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)
>>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
>>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
>>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption")
>>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh")
>>>>>> number: 17.0582
>>>>>> string: 17.0582
>>>>>> number: 5.86227
>>>>>> string: 3.64264
>>>>>> string: 17.0582kWh/100km
>>>>>> string: 3.64264mi/kWh
>>>>>> number: 17.0582
>>>>>> number: 5.86227
>>>>>> It still might be an idea to use 'null' as a return value if the
>>>>>> metrics is !IsDefined() but that would be changing the existing
>>>>>> behaviour slightly.
>>>>>> //.ichael
>>>>>> On Mon, 7 Nov 2022 at 08:12, Michael Geddes <
>>>>>> frog at bunyip.wheelycreek.net> wrote:
>>>>>>> I've worked out what the decode flag is for and how it works, and I
>>>>>>> think how optional params work.
>>>>>>> I'm pretty sure I won't  need the 'AsFloatUnit' function; the unit
>>>>>>> would be an option to AsFloat(); I'll know that soon.
>>>>>>> The 'Value' function is more complicated because of the optional
>>>>>>> decode bool. I guess I could add the Unit to the end of that.
>>>>>>> ValueUnit could be still useful then to provide a 'Value + Unit'.
>>>>>>> Question:  Is there a reason we shouldn't be returning with
>>>>>>> duk_push_null    if the metric !IsDefined()  in both AsFloat() and
>>>>>>> Value(metric,true) cases?
>>>>>>> //.ichael
>>>>>>> On Sun, 6 Nov 2022 at 11:22, Michael Geddes <
>>>>>>>> Right, so I've implemented some stuff that seems to work quite
>>>>>>>> well.
>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>>>>>>>> should be ready now after a couple of stupid mistakes slipped through.
>>>>>>>>  This absolutely needs somebody to review it please! (There's a reason why
>>>>>>>> I've converted some if()'s to switch() - which is that it will be used in
>>>>>>>> the follow-up commit).
>>>>>>>> The commit that will follow on from that it implements the new
>>>>>>>> Units: kWh/100km, km/kWh  and  mi/kWh.
>>>>>>>> This is a summary of what I've implemented for scripting -
>>>>>>>> including showing the unit codes I have so far.  I've considered a few
>>>>>>>> things:
>>>>>>>>   * Should some of the longer unit codes be shortened  (eg mi,
>>>>>>>> mins, m, ft, deg, perc)
>>>>>>>>   * The unit codes could be much more regular and separated by
>>>>>>>> dots  eg:
>>>>>>>>         watthours -> w.h
>>>>>>>>         kwhp100km -> kw.h_100km or kw.h/100km
>>>>>>>>         miph ->  mi_h or mi/h  (or should it be mph).
>>>>>>>>         psi -> p_in.in or p/in.in or lb_in.in (yes, slightly
>>>>>>>> weird, but predictable)
>>>>>>>> *OVMS# metric units*
>>>>>>>>           km : km
>>>>>>>>        miles : M
>>>>>>>>       meters : m
>>>>>>>>         feet : ft
>>>>>>>>      celcius : °C
>>>>>>>>   fahrenheit : °F
>>>>>>>>          kpa : kPa
>>>>>>>>           pa : Pa
>>>>>>>>          psi : psi
>>>>>>>>        volts : V
>>>>>>>>         amps : A
>>>>>>>>     amphours : Ah
>>>>>>>>           kw : kW
>>>>>>>>          kwh : kWh
>>>>>>>>        watts : W
>>>>>>>>    watthours : Wh
>>>>>>>>      seconds : Sec
>>>>>>>>      minutes : Min
>>>>>>>>        hours : Hour
>>>>>>>>          utc : UTC
>>>>>>>>      degrees : °
>>>>>>>>         kmph : km/h
>>>>>>>>         miph : Mph
>>>>>>>>       kmphps : km/h/s
>>>>>>>>       miphps : Mph/s
>>>>>>>>         mpss : m/s²
>>>>>>>>          dbm : dBm
>>>>>>>>           sq : sq
>>>>>>>>      percent : %
>>>>>>>>        whpkm : Wh/km
>>>>>>>>        whpmi : Wh/mi
>>>>>>>>    kwhp100km : kWh/100km
>>>>>>>>       kmpkwh : km/kWh
>>>>>>>>       mipkwh : mi/kWh
>>>>>>>>           nm : Nm
>>>>>>>> *OVMS# metric unit mi*
>>>>>>>>        miles : M
>>>>>>>>      minutes : Min
>>>>>>>>         miph : Mph
>>>>>>>>       miphps : Mph/s
>>>>>>>>        whpmi : Wh/mi
>>>>>>>>       mipkwh : mi/kWh
>>>>>>>> *OVMS# metric get xiq.v.trip.consumption *17.0597kWh/100km
>>>>>>>> *OVMS# metric get xiq.v.trip.consumption kpkwh *5.86177km/kWh
>>>>>>>> *OVMS# metric get xiq.v.trip.consumption mpkwh *3.64233mi/kWh
>>>>>>>> *OVMS# metric set xiq.c.speed 5 miph *Metric set
>>>>>>>> *OVMS# metric get xiq.c.speed *8.04673km/h
>>>>>>>> *OVMS# metric get xiq.c.speed miph *5Mph
>>>>>>>> And then in DukTape - there are some questions I have about the
>>>>>>>> implementation:
>>>>>>>> * Names of functions? Better ideas?
>>>>>>>> * Should ValueUnit output the units?
>>>>>>>> * In Value() there is the line    bool decode =
>>>>>>>> duk_opt_boolean(ctx, 1, true);
>>>>>>>>     * What does 'decode' mean here?
>>>>>>>>     * Do I need it for ValueUnit() ?
>>>>>>>> * (function() {    print(
>>>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption"));    print("\n")    print(
>>>>>>>> OvmsMetrics.ValueUnit("xiq.v.trip.consumption",""));    print("\n")
>>>>>>>>  print( OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh"));
>>>>>>>>  print("\n")    print(
>>>>>>>> OvmsMetrics.AsFloatUnit("xiq.v.trip.consumption","kmpkwh")); })();*
>>>>>>>> --- Output ---
>>>>>>>> 17.0597
>>>>>>>> 17.0597kWh/100km
>>>>>>>> 3.64233mi/kWh
>>>>>>>> 5.86177
>>>>>>>> The basic stuff all works - it's just quibbling over the details..
>>>>>>>> but let's get them right!
>>>>>>>> //.ichael
>>>>>>>> On Sat, 5 Nov 2022 at 20:09, Michael Geddes <
>>>>>>>>> Yeah - this was copied code from kia/kona and is what triggered
>>>>>>>>> these ideas; I totally agree this shouldn't be doubled up on.
>>>>>>>>> I've got some commits centred round Metrics that I'll just check
>>>>>>>>> over and push up ... and then I'll just have the single xiq.v.
>>>>>>>>> trip.consumption metric (unless you have some ideas for the
>>>>>>>>> namespace) which will be much neater.
>>>>>>>>> If it's ok with you then I might do that unit conversion proposal.
>>>>>>>>> Would it ok if the unit specifications were the same as to the
>>>>>>>>> programatic codes in ovms_metrics.h?
>>>>>>>>> (kWh,   WattHours , MetersPSS )
>>>>>>>>> I would probably add a command
>>>>>>>>> metric units <spec>
>>>>>>>>> to list all (matching) units and their associated Labels.
>>>>>>>>> //.ichael
>>>>>>>>> On Sat, 5 Nov 2022 at 18:48, Michael Balzer <dexter at expeedo.de>
>>>>>>>>> wrote:
>>>>>>>>>> Michael,
>>>>>>>>>> adding unit conversion support to the shell and Duktape commands
>>>>>>>>>> is a good idea.
>>>>>>>>>> Metrics are not meant to provide a user interface, they should be
>>>>>>>>>> defined to be efficient and non-redundant.
>>>>>>>>>> Btw, metrics names also shall not use upper case characters, and
>>>>>>>>>> shall only use "." as a separator.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 05.11.22 um 11:22 schrieb Michael Geddes:
>>>>>>>>>> Hi all,
>>>>>>>>>> Some of the code I copied from Kona/Kia code had both kwh/100km
>>>>>>>>>> and km/kwh metrics in the code as 'Other'.
>>>>>>>>>> Adding the various power consumption Units is not particularly
>>>>>>>>>> hard (I will have a pull-request soon) - though the conversions between
>>>>>>>>>> them all required some thought!
>>>>>>>>>> ... but it also made me think these two metrics that are (with
>>>>>>>>>> the consumption units added) defined like this:
>>>>>>>>>> m_v_trip_consumption1 =
>>>>>>>>>> MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km", 10, 0, kWHP100K);
>>>>>>>>>> m_v_trip_consumption2 = MyMetrics.InitFloat("
>>>>>>>>>> xiq.v.trip.consumption.km/kWh", 10, 0, kPkWH);
>>>>>>>>>> These are effectively the same metric but in different units!
>>>>>>>>>> I'm wondering if we would be better to have scripting and Duktape
>>>>>>>>>> support for converting metrics to different unit!  This might be also quite
>>>>>>>>>> useful for those strange countries that insist on using miles as a
>>>>>>>>>> measurement.
>>>>>>>>>> On top of the 'metric list' and 'metric set' we could add a
>>>>>>>>>> 'metric get' which gets a single value.. and add unit support for get/set.
>>>>>>>>>> I've also got a pull request that improves the precision of the
>>>>>>>>>> km<->mi conversions and factors it out.
>>>>>>>>>> //.ichael
>>>>>>>>>> _______________________________________________
>>>>>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221115/12291dab/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221115/12291dab/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221115/12291dab/attachment-0003.png>
