[Ovmsdev] New Metric Units
    Sun Nov 13 21:05:32 HKT 2022
Michael,
looks good.
I think having an explicit 'default' option is better than taking the
'Metric' equivalent for that, as in your example you already show unit
alternatives within the metric system to support different scalings (kW
/ W, kWh / Wh). (Btw… waiting for someone to miss Horsepower & BTU here ;-))
@Patrick, I think that also answers your implicit question:
> The default button makes it unclear what the actual setting is.
The default (native unit) is always metric, but you may have a mix of
scalings, as we try to find the one that fits best for the given
application when defining a metric. For example the current driving
energy consumption is stored natively in Wh/km, while the energy used or
regenerated is in kWh, and the odometer & trip counters are in km, while
the altitude ist in m.
Am 13.11.22 um 08:42 schrieb Michael Geddes:
> Greetings,
> so this is my idea of being able to select which units various groups
> use (in addition to Distance).
> This can be then accessed by the special 'user' unit code. (or
> 'metrics list -u ' )
> The idea of [Default] selection below  simply means storing the value
> to blank - meaning use whatever unit the particular metric uses.  The
> other idea I had was to actually default it to the equivalent of
> 'Metric' special unit code and not have the [Default] button.
> Currently I've made it so that if there are more than 3 choices other
> than [default] that it uses the choice/combo box rather than the Radio
> buttons. (ie this list is auto-generated from the Metric Units table
> and the Metric Groups table).
> Thoughts / comments?
> //.ichael
> On Sat, 12 Nov 2022 at 17:35, Michael Geddes
> <frog at bunyip.wheelycreek.net> wrote:
>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/771
>     I'm hoping this P/R is ok in this form (made of 5 separate commits).
>     I will have a look at implementing the "user" unit code.  The base
>     for how it would work is already a part of the above pull
>     request.  I'll just look at the module configuration for distance.
>     The 'power consumption' is one where it's not just a check-box..
>     there're 5 possible choice!
>     I should also add 'bar' for pressure given that for some reason
>     that's still a thing people want.
>     //.ichael
>     On Sat, 12 Nov 2022 at 16:24, Michael Balzer <dexter at expeedo.de>
>     wrote:
>         I think this is pretty decent & complete now.
>         I also like the approach of the 'user' unit code. Moving all
>         user unit prefs into the module configuration is an old todo.
>         Currently only the distance unit is defined at the module
>         side, temperature and pressure are App prefs.
>         Regards,
>         Michael
>         Am 11.11.22 um 09:54 schrieb Michael Geddes:
>>         Ok - so here's what I have implemented for Duktape and
>>         Metrics. (I added IsDefined() as well).
>>         Any thoughts on this?
>>         Noting
>>            OvmsMetrics.Float( {metric} ) -> Outputs metric as float
>>         (same)
>>            OvmsMetrics.Float( {metric}, {unit}) -> Outputs metric as
>>         float converted to given unit  (new)
>>            OvmsMetrics.Value( {metric} )   -> Outputs Metric in
>>         native value (same)
>>            OvmsMetrics.Value( {metric} , false)  -> Outputs Metric as
>>         string and no units (same)
>>            OvmsMetrics.Value( {metric} ,  {unit}) -> Outputs Metric
>>         converted to given unit as native value. (new)
>>           OvmsMetrics.Value( {metric} ,  {unit}, false )  -> Outputs
>>         Metric converted to given unit as string including any unit
>>         specifier. (new)
>>         also  OvmsMetric.GetValues( {metric} [,{unit}] [, {converted}
>>         ] )  Adds similar behaviour to Value() above.
>>         also the special units '*imperial*' and '*metric*' will
>>         convert to the associated imperial / metric version of the
>>         units as appropriate.
>>         (function() {
>>            dump = function (metric) { print( metric+ " ["+(typeof
>>         metric)+"]\n"  ); }
>>            dump_obj = function (obj )  {
>>              print('--- Object ----\n')
>>              for (var k in obj) {
>>                xk = obj[k];
>>                print( k+':'+ xk + ' ['+typeof xk+ "]\n");
>>          dump(OvmsMetrics.Value("xiq.v.trip.consumption"));
>>          dump(OvmsMetrics.Value("xiq.v.trip.consumption", false));
>>          dump(OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh"));
>>          dump(OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh",
>>         false));
>>          dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption"));
>>          dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh"));
>>          dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial"))
>>          dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial",
>>         false))
>>          dump_obj(OvmsMetrics.GetValues("trip", "metric"))
>>          dump_obj(OvmsMetrics.GetValues("trip", "imperial", false))
>>         With this output:
>>         19.2308 [number]
>>         19.2308 [string]
>>         5.2 [number]
>>         3.23112mi/kWh [string]
>>         19.2308 [number]
>>         5.2 [number]
>>         309.49 [number]
>>         309.49Wh/mi [string]
>>         --- Object ----
>>         v.p.trip:13 [number]
>>         xiq.e.trip:0 [number]
>>         xiq.e.trip.energy.recuperated:0 [number]
>>         xiq.e.trip.energy.used:0 [number]
>>         xiq.v.trip.consumption:19.2308 [number]
>>         --- Object ----
>>         v.p.trip:8.07781M [string]
>>         xiq.e.trip:0M [string]
>>         xiq.e.trip.energy.recuperated:0kWh [string]
>>         xiq.e.trip.energy.used:0kWh [string]
>>         xiq.v.trip.consumption:309.49Wh/mi [string]
>>         On Wed, 9 Nov 2022 at 05:47, Michael Geddes
>>             Yeah - I like HasValue.  I implemented IsDefined() but I
>>             will rename it.. that's a much clearer name.
>>             Another thought. How about if we did this (but also with
>>             GetValues() as well - see the special values below)
>>             OvmsMetrics.Value("xiq.v.trip.consumption",  true)  ->
>>             17.0582  (Number)
>>             OvmsMetrics.Value("xiq.v.trip.consumption",  false)  ->
>>             17.0582  (String)
>>             true)  -> 3.64264  (Number)
>>             false)  -> 3.64264Mi/kWh  (String)
>>              OvmsMetrics.Value("xiq.v.trip.consumption", "native",
>>             false)  -> 17.0582km/kWh  (String)
>>             and
>>             OvmsMetrics.Value("xiq.v.trip.consumption", "imperial",
>>             I have already implemented the special values 'native'
>>             (existing), 'imperial' and 'metric'.
>>             I was also thinking that in the future you could have
>>             'user'. Where for each group of values:
>>             'temperature', 'distance', 'shortdistance', 'power' etc..
>>             you could have a user preference. I probably won't
>>             implement it now,.but it could be cool that any UI could
>>             just ask for the user defined units (rather than having a
>>             separate choice).
>>             //.ichael
>>             On Tue, 8 Nov 2022 at 21:57, Mark Webb-Johnson
>>             <mark at webb-johnson.net> wrote:
>>                 Or perhaps something more specific?
>>                   HasValue()
>>                 Mark
>>>                 On 8 Nov 2022, at 9:01 PM, Michael Balzer
>>>                 <dexter at expeedo.de> wrote:
>>>                 Signed PGP part
>>>                 That's basically a good approach, but be aware
>>>                 'IsDefined()' has an ambiguous meaning here, as with
>>>                 the API stem "OvmsMetrics" it would naturally be
>>>                 expected to mean "is this metric defined", not "does
>>>                 this metric have a defined value".
>>>                 An undefined metric currently can be derived from
>>>                 'Values()' returning undefined, but that's more an
>>>                 undocumented side effect than intended.
>>>                 Maybe 'GetDefined()' could be a better name,
>>>                 leveraging this behaviour, i.e. returning
>>>                 'undefined' for an actually undefined metric, and
>>>                 'null' for a defined metric without a value.
>>>                 Regards,
>>>                 Michael
>>>                 Am 08.11.22 um 13:46 schrieb Michael Geddes:
>>>>                 Ah yes. Arrays - will check those. Yeah, how about
>>>>                 we add a 'IsDefined' method to metrics instead of
>>>>                 the null thing (it does sound like it will upset
>>>>                 too many applecarts).
>>>>                 On Tue, 8 Nov 2022 at 20:35, Michael Balzer
>>>>                     Michael,
>>>>                     looks all good to me, once again nice find with
>>>>                     the decode argument. Adding decode to the
>>>>                     Value() call was only for symmetry IIRC, the
>>>>                     main use was with GetValues()
>>>>                     (https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsmetrics).
>>>>                     Don't forget to test arrays, e.g.
>>>>                     "v.t.pressure" & "v.t.temp".
>>>>                     Returning null for an undefined metric seems
>>>>                     like a natural choice, but is a rather deep
>>>>                     change, as for consistency not only the Duktape
>>>>                     metrics API but also the Web UI metrics API
>>>>                     would need to be changed accordingly. Unless
>>>>                     you've got a real use case that needs that, we
>>>>                     should be careful.
>>>>                     Regards,
>>>>                     Michael
>>>>                     Am 07.11.22 um 15:00 schrieb Michael Geddes:
>>>>>                     I have figured out a bunch of stuff and have
>>>>>                     implemented the following: (having done away
>>>>>                     with needing AsFloatUnit)
>>>>>                     OvmsMetrics.Value( {metric} [, {decode}])
>>>>>                     OvmsMetrics.Value( {metric}, {unit} [,{decode}])
>>>>>                     It turns out that the [decode] flag wasn't
>>>>>                     working anyway (since the function was being
>>>>>                     registered as only having 1 param)...
>>>>>                     This way it is still really 1 function.. but I
>>>>>                     check it the second parameter is a 'boolean',
>>>>>                     and if not.. try the second form.
>>>>>                     OvmsMetrics.AsFloat( {metric} [,{unit}] )
>>>>>                     and add the function
>>>>>                     Ovms.Metrics.ValueUnit( {metric} [,{unit}])
>>>>>                     This prints the value and the unit.
>>>>>                     Here's a sample function and the output! This
>>>>>                     also shows the types of the output.
>>>>>                     (function() {
>>>>>                        x =
>>>>>                     OvmsMetrics.Value("xiq.v.trip.consumption");
>>>>>                        print( (typeof x) + ": "+  x+"\n"  );
>>>>>                        x =
>>>>>                     false);
>>>>>                        print( (typeof x) + ": "+  x +"\n" );
>>>>>                        x =
>>>>>                        print( (typeof x) + ": "+ x +"\n");
>>>>>                        x =
>>>>>                     "mipkwh", false)
>>>>>                        x =
>>>>>                      OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
>>>>>                        x =
>>>>>                      OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
>>>>>                        x =
>>>>>                        x =
>>>>>                     number: 17.0582
>>>>>                     string: 17.0582
>>>>>                     number: 5.86227
>>>>>                     string: 3.64264
>>>>>                     string: 17.0582kWh/100km
>>>>>                     string: 3.64264mi/kWh
>>>>>                     number: 17.0582
>>>>>                     number: 5.86227
>>>>>                     It still might be an idea to use 'null' as a
>>>>>                     return value if the metrics is!IsDefined() but
>>>>>                     that would be changing the existing behaviour
>>>>>                     slightly.
>>>>>                     //.ichael
>>>>>                     On Mon, 7 Nov 2022 at 08:12, Michael Geddes
>>>>>                         I've worked out what the decode flag is
>>>>>                         for and how it works, and I think how
>>>>>                         optional params work.
>>>>>                         I'm pretty sure I won't  need the
>>>>>                         'AsFloatUnit' function; the unit would be
>>>>>                         an option to AsFloat(); I'll know that soon.
>>>>>                         The 'Value' function is more complicated
>>>>>                         because of the optional decode bool. I
>>>>>                         guess I could add the Unit to the end of that.
>>>>>                         ValueUnit could be still useful then to
>>>>>                         provide a 'Value + Unit'.
>>>>>                         Question: Is there a reason we shouldn't
>>>>>                         be returning with duk_push_null   if the
>>>>>                         metric !IsDefined() in both AsFloat() and
>>>>>                         Value(metric,true) cases?
>>>>>                         //.ichael
>>>>>                         On Sun, 6 Nov 2022 at 11:22, Michael
>>>>>                         Geddes <frog at bunyip.wheelycreek.net> wrote:
>>>>>                             Right, so I've implemented some stuff
>>>>>                             that seems to work quite well.
>>>>>                             https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>>>>>                             should be ready now after a couple of
>>>>>                             stupid mistakes slipped through.  This
>>>>>                             absolutely needs somebody to review it
>>>>>                             please! (There's a reason why I've
>>>>>                             converted some if()'s to switch() -
>>>>>                             which is that it will be used in the
>>>>>                             follow-up commit).
>>>>>                             The commit that will follow on from
>>>>>                             that it implements the new Units:
>>>>>                             kWh/100km, km/kWh  and mi/kWh.
>>>>>                             This is a summary of what I've
>>>>>                             implemented for scripting - including
>>>>>                             showing the unit codes I have so far.
>>>>>                             I've considered a few things:
>>>>>                               * Should some of the longer unit
>>>>>                             codes be shortened  (eg mi, mins, m,
>>>>>                             ft, deg, perc)
>>>>>                               * The unit codes could be much more
>>>>>                             regular and separated by dots  eg:
>>>>>                             watthours -> w.h
>>>>>                             kwhp100km -> kw.h_100km or kw.h/100km
>>>>>                                   miph ->  mi_h or mi/h  (or
>>>>>                             should it be mph).
>>>>>                                   psi -> p_in.in <http://p_in.in/>
>>>>>                             or p/in.in <http://in.in/> or lb_in.in
>>>>>                             <http://lb_in.in/> (yes, slightly
>>>>>                             weird, but predictable)
>>>>>                             *OVMS# metric units*
>>>>>                                     km : km
>>>>>                                  miles : M
>>>>>                                 meters : m
>>>>>                                   feet : ft
>>>>>                                celcius : °C
>>>>>                             fahrenheit : °F
>>>>>                                    kpa : kPa
>>>>>                                     pa : Pa
>>>>>                                    psi : psi
>>>>>                                  volts : V
>>>>>                                   amps : A
>>>>>                             amphours: Ah
>>>>>                                     kw : kW
>>>>>                                    kwh : kWh
>>>>>                                  watts : W
>>>>>                             watthours: Wh
>>>>>                                seconds : Sec
>>>>>                                minutes : Min
>>>>>                                  hours : Hour
>>>>>                                    utc : UTC
>>>>>                                degrees : °
>>>>>                                   kmph : km/h
>>>>>                             miph: Mph
>>>>>                             kmphps: km/h/s
>>>>>                             miphps: Mph/s
>>>>>                                   mpss : m/s²
>>>>>                                    dbm : dBm
>>>>>                                     sq : sq
>>>>>                                percent : %
>>>>>                                  whpkm : Wh/km
>>>>>                             whpmi: Wh/mi
>>>>>                              kwhp100km : kWh/100km
>>>>>                             kmpkwh: km/kWh
>>>>>                             mipkwh: mi/kWh
>>>>>                                     nm : Nm
>>>>>                             *OVMS# metric unit mi*
>>>>>                                    miles : M
>>>>>                                  minutes : Min
>>>>>                                     miph : Mph
>>>>>                                   miphps : Mph/s
>>>>>                                    whpmi : Wh/mi
>>>>>                                   mipkwh : mi/kWh
>>>>>                             *OVMS# metric get xiq.v.trip.consumption
>>>>>                             *17.0597kWh/100km
>>>>>                             *OVMS# metric get
>>>>>                             xiq.v.trip.consumption kpkwh
>>>>>                             *5.86177km/kWh
>>>>>                             *OVMS# metric get
>>>>>                             xiq.v.trip.consumption mpkwh
>>>>>                             *3.64233mi/kWh
>>>>>                             *OVMS# metric set xiq.c.speed 5 miph
>>>>>                             *Metric set
>>>>>                             *OVMS# metric get xiq.c.speed
>>>>>                             *8.04673km/h
>>>>>                             *OVMS# metric get xiq.c.speed miph
>>>>>                             *5Mph
>>>>>                             And then in DukTape - there are some
>>>>>                             questions I have about the
>>>>>                             implementation:
>>>>>                             * Names of functions? Better ideas?
>>>>>                             * Should ValueUnit output the units?
>>>>>                             * In Value() there is the line bool
>>>>>                             decode = duk_opt_boolean(ctx, 1, true);
>>>>>                                 * What does 'decode' mean here?
>>>>>                                 * Do I need it for ValueUnit() ?
>>>>>                             (function() {
>>>>>                              print(
>>>>>                              print("\n")
>>>>>                              print(
>>>>>                             OvmsMetrics.ValueUnit("xiq.v.trip.consumption",""));
>>>>>                              print("\n")
>>>>>                              print(
>>>>>                             OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh"));
>>>>>                              print("\n")
>>>>>                              print(
>>>>>                             OvmsMetrics.AsFloatUnit("xiq.v.trip.consumption","kmpkwh"));
>>>>>                             --- Output ---
>>>>>                             17.0597
>>>>>                             17.0597kWh/100km
>>>>>                             3.64233mi/kWh
>>>>>                             5.86177
>>>>>                             The basic stuff all works - it's just
>>>>>                             quibbling over the details.. but let's
>>>>>                             get them right!
>>>>>                             //.ichael
>>>>>                             On Sat, 5 Nov 2022 at 20:09, Michael
>>>>>                             wrote:
>>>>>                                 Yeah - this was copied code from
>>>>>                                 kia/kona and is what triggered
>>>>>                                 these ideas; I totally agree this
>>>>>                                 shouldn't be doubled up on.
>>>>>                                 I've got some commits centred
>>>>>                                 round Metrics that I'll just check
>>>>>                                 over and push up ... and then I'll
>>>>>                                 just have the single
>>>>>                                 xiq.v.trip.consumption metric
>>>>>                                 (unless you have some ideas for
>>>>>                                 the namespace) which will be much
>>>>>                                 neater.
>>>>>                                 If it's ok with you then I might
>>>>>                                 do that unit conversion proposal.
>>>>>                                 Would it ok if the unit
>>>>>                                 specifications were the same as to
>>>>>                                 the programatic codes in
>>>>>                                 ovms_metrics.h?
>>>>>                                 (kWh,  WattHours , MetersPSS )
>>>>>                                 I would probably add a command
>>>>>                                 metric units <spec>
>>>>>                                 to list all (matching) units and
>>>>>                                 their associated Labels.
>>>>>                                 //.ichael
>>>>>                                 On Sat, 5 Nov 2022 at 18:48,
>>>>>                                 wrote:
>>>>>                                     Michael,
>>>>>                                     adding unit conversion support
>>>>>                                     to the shell and Duktape
>>>>>                                     commands is a good idea.
>>>>>                                     Metrics are not meant to
>>>>>                                     provide a user interface, they
>>>>>                                     should be defined to be
>>>>>                                     efficient and non-redundant.
>>>>>                                     Btw, metrics names also shall
>>>>>                                     not use upper case characters,
>>>>>                                     and shall only use "." as a
>>>>>                                     separator.
>>>>>                                     Regards,
>>>>>                                     Michael
>>>>>                                     Am 05.11.22 um 11:22 schrieb
>>>>>                                     Michael Geddes:
>>>>>>                                     Hi all,
>>>>>>                                     Some of the code I copied
>>>>>>                                     from Kona/Kia code had both
>>>>>>                                     kwh/100km and km/kwh metrics
>>>>>>                                     in the code as 'Other'.
>>>>>>                                     Adding the various power
>>>>>>                                     consumption Units is not
>>>>>>                                     particularly hard (I will
>>>>>>                                     have a pull-request soon) -
>>>>>>                                     though the conversions
>>>>>>                                     between them all required
>>>>>>                                     some thought!
>>>>>>                                     ... but it also made me think
>>>>>>                                     these two metrics that are
>>>>>>                                     (with the consumption units
>>>>>>                                     added) defined like this:
>>>>>>                                     m_v_trip_consumption1 =
>>>>>>                                     MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km",
>>>>>>                                     10, 0, kWHP100K);
>>>>>>                                     m_v_trip_consumption2 =
>>>>>>                                     MyMetrics.InitFloat("xiq.v.trip.consumption.km/kWh
>>>>>>                                     <http://xiq.v.trip.consumption.km/kWh>",
>>>>>>                                     10, 0, kPkWH);
>>>>>>                                     These are effectively the
>>>>>>                                     same metric but in different
>>>>>>                                     units!
>>>>>>                                     I'm wondering if we would be
>>>>>>                                     better to have scripting and
>>>>>>                                     Duktape support for
>>>>>>                                     converting metrics to
>>>>>>                                     different unit!  This might
>>>>>>                                     be also quite useful for
>>>>>>                                     those strange countries that
>>>>>>                                     insist on using miles as a
>>>>>>                                     measurement.
>>>>>>                                     On top of the 'metric list'
>>>>>>                                     and 'metric set' we could add
>>>>>>                                     a 'metric get' which gets a
>>>>>>                                     single value.. and add unit
>>>>>>                                     support for get/set.
>>>>>>                                     I've also got a pull request
>>>>>>                                     that improves the precision
>>>>>>                                     of the km<->mi conversions
>>>>>>                                     and factors it out.
>>>>>>                                     //.ichael
>>>>>>                                     _______________________________________________
>>>>>>                                     OvmsDev mailing list
>>>>>>                                     OvmsDev at lists.openvehicles.com
>>>>>>                                     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>                                     Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>                                     Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221113/86f379f5/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221113/86f379f5/attachment-0001.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221113/86f379f5/attachment-0001.sig>
