[Ovmsdev] New Metric Units
    Michael Geddes
    Tue Nov 15 15:27:37 HKT 2022
Also, all the command status displays should probably be in user units.
There is already stuff there to check for miles/km... But that becomes
simpler.
For example:
Not charging
SOC: 895.0‰
Ideal range: 245M
Est. range: 253M
ODO: 6754.9M
CAC: 974.7Ah
SOH: 1000‰
I mean not my choice of units... But you can!
On Tue, 15 Nov 2022, 8:26 am Michael Geddes, <frog at bunyip.wheelycreek.net>
wrote:
> If you're ok with the [default] option I'll stick with that. I mean in
> some ways it would be nice to have a button choice
> metric | usa | europe | asia | custom   etc and I kind of considered
> something like that but figured it's only a handful of choices.. and it's
> an embedded device.. so simpler is better.
> On a related note - I was thinking how it would be nice if the dashboard
> (etc) had access to the 'user' units, so went hunting down that little
> rabbit hole. Quite a nice mechanism with the web socket updating the
> "metrics" object in the UI.
> This is a snippet of one idea, which is that for any metric that has the
> possibility of a user unit, we set the extra values of the metric with
> '#unit' and '#user' appended - see below. (I've chosen '#' arbitrarily..
> but it could be '/' or ':' or '>'  but maybe not '.' )
> v.p.odometer#unit: "M"
> v.p.odometer#user: 6754.91
> v.p.satcount: 13
> v.p.speed: 0
> v.p.speed#unit: "km/h"
> v.p.speed#user: null
> *v.p.trip: 28*
> *v.p.trip#unit: "M"v.p.trip#user: 17.3984*
> Then we can use this in the dials to populate the values and captions!
> (not that I like Miles).
> I
> [image: image.png]
> The other (similar) way was to have something like the following:
> "v.p.trip#user" : { "value": 17.3984, "unit": "M" }
> It wouldn't make the total message any shorter.. soo.. dunno.
> There's also some complications with setting up the dials (for min/max
> values) - like for the speed.
> Notice also that I'm returning null for undefined values. It's nice - but
> I'm not sure how javascript handles null when used / printed etc.
> //.ichael
> On Sun, 13 Nov 2022 at 21:06, Michael Balzer <dexter at expeedo.de> wrote:
>> Michael,
>> looks good.
>> I think having an explicit 'default' option is better than taking the
>> 'Metric' equivalent for that, as in your example you already show unit
>> alternatives within the metric system to support different scalings (kW /
>> W, kWh / Wh). (Btw… waiting for someone to miss Horsepower & BTU here ;-))
>> @Patrick, I think that also answers your implicit question:
>> The default button makes it unclear what the actual setting is.
>> The default (native unit) is always metric, but you may have a mix of
>> scalings, as we try to find the one that fits best for the given
>> application when defining a metric. For example the current driving energy
>> consumption is stored natively in Wh/km, while the energy used or
>> regenerated is in kWh, and the odometer & trip counters are in km, while
>> the altitude ist in m.
>> Am 13.11.22 um 08:42 schrieb Michael Geddes:
>> Greetings,
>> so this is my idea of being able to select which units various groups use
>> (in addition to Distance).
>> This can be then accessed by the special 'user' unit code.  (or  'metrics
>> list -u ' )
>> The idea of [Default] selection below  simply means storing the value to
>> blank - meaning use whatever unit the particular metric uses.  The other
>> idea I had was to actually default it to the equivalent of 'Metric' special
>> unit code and not have the [Default] button.
>> [image: image.png]
>> Currently I've made it so that if there are more than 3 choices other
>> than [default] that it uses the choice/combo box rather than the Radio
>> buttons. (ie this list is auto-generated from the Metric Units table and
>> the Metric Groups table).
>> Thoughts / comments?
>> //.ichael
>> On Sat, 12 Nov 2022 at 17:35, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/771
>>> I'm hoping this P/R is ok in this form (made of 5 separate commits).
>>> I will have a look at implementing the "user" unit code.  The base for
>>> how it would work is already a part of the above pull request.  I'll just
>>> look at the module configuration for distance.
>>> The 'power consumption' is one where it's not just a check-box..
>>> there're 5 possible choice!
>>> I should also add 'bar' for pressure given that for some reason that's
>>> still a thing people want.
>>> //.ichael
>>> On Sat, 12 Nov 2022 at 16:24, Michael Balzer <dexter at expeedo.de> wrote:
>>>> I think this is pretty decent & complete now.
>>>> I also like the approach of the 'user' unit code. Moving all user unit
>>>> prefs into the module configuration is an old todo. Currently only the
>>>> distance unit is defined at the module side, temperature and pressure are
>>>> App prefs.
>>>> Regards,
>>>> Michael
>>>> Am 11.11.22 um 09:54 schrieb Michael Geddes:
>>>> Ok - so here's what I have implemented for Duktape and Metrics. (I
>>>> added IsDefined() as well).
>>>> Any thoughts on this?
>>>> Noting
>>>>    OvmsMetrics.Float( {metric} ) -> Outputs metric as float (same)
>>>>    OvmsMetrics.Float( {metric}, {unit}) -> Outputs metric as float
>>>> converted to given unit  (new)
>>>>    OvmsMetrics.Value( {metric} )   -> Outputs Metric in native value
>>>> (same)
>>>>    OvmsMetrics.Value( {metric} , false)   -> Outputs Metric as string
>>>> and no units (same)
>>>>    OvmsMetrics.Value( {metric} ,  {unit})  -> Outputs Metric converted
>>>> to given unit as native value. (new)
>>>>   OvmsMetrics.Value( {metric} ,  {unit}, false )  -> Outputs Metric
>>>> converted to given unit as string including any unit specifier. (new)
>>>> also  OvmsMetric.GetValues( {metric} [,{unit}] [, {converted} ] )  Adds
>>>> similar behaviour to Value() above.
>>>> also the special units '*imperial*' and '*metric*' will convert to the
>>>> associated imperial / metric version of the units as appropriate.
>>>> (function() {
>>>>    dump = function (metric) { print( metric+ " ["+(typeof metric)+"]\n"
>>>>    dump_obj = function (obj )  {
>>>>      print('--- Object ----\n')
>>>>      for (var k in obj) {
>>>>        xk = obj[k];
>>>>        print( k+':'+ xk + ' ['+typeof xk+ "]\n");
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption"));
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", false));
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh"));
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false));
>>>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption"));
>>>>    dump(OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh"));
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial"))
>>>>    dump(OvmsMetrics.Value("xiq.v.trip.consumption","imperial", false))
>>>>    dump_obj(OvmsMetrics.GetValues("trip", "metric"))
>>>>    dump_obj(OvmsMetrics.GetValues("trip", "imperial", false))
>>>> With this output:
>>>> 19.2308 [number]
>>>> 19.2308 [string]
>>>> 5.2 [number]
>>>> 3.23112mi/kWh [string]
>>>> 19.2308 [number]
>>>> 5.2 [number]
>>>> 309.49 [number]
>>>> 309.49Wh/mi [string]
>>>> --- Object ----
>>>> v.p.trip:13 [number]
>>>> xiq.e.trip:0 [number]
>>>> xiq.e.trip.energy.recuperated:0 [number]
>>>> xiq.e.trip.energy.used:0 [number]
>>>> xiq.v.trip.consumption:19.2308 [number]
>>>> --- Object ----
>>>> v.p.trip:8.07781M [string]
>>>> xiq.e.trip:0M [string]
>>>> xiq.e.trip.energy.recuperated:0kWh [string]
>>>> xiq.e.trip.energy.used:0kWh [string]
>>>> xiq.v.trip.consumption:309.49Wh/mi [string]
>>>> On Wed, 9 Nov 2022 at 05:47, Michael Geddes <
>>>> frog at bunyip.wheelycreek.net> wrote:
>>>>> Yeah - I like HasValue.  I implemented IsDefined() but I will rename
>>>>> it.. that's a much clearer name.
>>>>> Another thought. How about if we did this (but also with GetValues()
>>>>> as well - see the special values below)
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption",  true)  -> 17.0582
>>>>> (Number)
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption",  false)  -> 17.0582
>>>>> (String)
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", true)  ->
>>>>> 3.64264  (Number)
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)  ->
>>>>> 3.64264Mi/kWh  (String)
>>>>>  OvmsMetrics.Value("xiq.v.trip.consumption", "native", false)  ->
>>>>> 17.0582km/kWh  (String)
>>>>> and
>>>>> OvmsMetrics.Value("xiq.v.trip.consumption", "imperial", false)  ->
>>>>> I have already implemented the special values 'native' (existing),
>>>>> 'imperial' and 'metric'.
>>>>> I was also thinking that in the future you could have 'user'. Where
>>>>> for each group of values:
>>>>> 'temperature', 'distance', 'shortdistance', 'power' etc.. you could
>>>>> have a user preference. I probably won't implement it now,.but it could be
>>>>> cool that any UI could just ask for the user defined units (rather than
>>>>> having a separate choice).
>>>>> //.ichael
>>>>> On Tue, 8 Nov 2022 at 21:57, Mark Webb-Johnson <mark at webb-johnson.net>
>>>>> wrote:
>>>>>> Or perhaps something more specific?
>>>>>>     HasValue()
>>>>>> Mark
>>>>>> On 8 Nov 2022, at 9:01 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>> Signed PGP part
>>>>>> That's basically a good approach, but be aware 'IsDefined()' has an
>>>>>> ambiguous meaning here, as with the API stem "OvmsMetrics" it would
>>>>>> naturally be expected to mean "is this metric defined", not "does this
>>>>>> metric have a defined value".
>>>>>> An undefined metric currently can be derived from 'Values()'
>>>>>> returning undefined, but that's more an undocumented side effect than
>>>>>> intended.
>>>>>> Maybe 'GetDefined()' could be a better name, leveraging this
>>>>>> behaviour, i.e. returning 'undefined' for an actually undefined metric, and
>>>>>> 'null' for a defined metric without a value.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 08.11.22 um 13:46 schrieb Michael Geddes:
>>>>>> Ah yes. Arrays - will check those.  Yeah, how about we add a
>>>>>> 'IsDefined' method to metrics instead of the null thing (it does sound like
>>>>>> it will upset too many applecarts).
>>>>>> On Tue, 8 Nov 2022 at 20:35, Michael Balzer <dexter at expeedo.de>
>>>>>> wrote:
>>>>>>> Michael,
>>>>>>> looks all good to me, once again nice find with the decode argument.
>>>>>>> Adding decode to the Value() call was only for symmetry IIRC, the main use
>>>>>>> was with GetValues() (
>>>>>>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsmetrics
>>>>>>> Don't forget to test arrays, e.g. "v.t.pressure" & "v.t.temp".
>>>>>>> Returning null for an undefined metric seems like a natural choice,
>>>>>>> but is a rather deep change, as for consistency not only the Duktape
>>>>>>> metrics API but also the Web UI metrics API would need to be changed
>>>>>>> accordingly. Unless you've got a real use case that needs that, we should
>>>>>>> be careful.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 07.11.22 um 15:00 schrieb Michael Geddes:
>>>>>>> I have figured out a bunch of stuff and have implemented the
>>>>>>> following: (having done away with needing AsFloatUnit)
>>>>>>> OvmsMetrics.Value( {metric} [, {decode}])
>>>>>>> OvmsMetrics.Value( {metric}, {unit} [,{decode}])
>>>>>>> It turns out that the [decode] flag wasn't working anyway (since the
>>>>>>> function was being registered as only having 1 param)...
>>>>>>> This way it is still really 1 function.. but I check it the second
>>>>>>> parameter is a 'boolean', and if not.. try the second form.
>>>>>>> OvmsMetrics.AsFloat( {metric} [,{unit}] )
>>>>>>> and add the function
>>>>>>> Ovms.Metrics.ValueUnit( {metric} [,{unit}])
>>>>>>> This prints the value and the unit.
>>>>>>> Here's a sample function and the output! This also shows the types
>>>>>>> of the output.
>>>>>>> (function() {
>>>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption");
>>>>>>>    print( (typeof x) + ": "+  x+"\n"  );
>>>>>>>    x = OvmsMetrics.Value("xiq.v.trip.consumption", false);
>>>>>>>    print( (typeof x) + ": "+  x +"\n" );
>>>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption","kmpkwh")
>>>>>>>    print( (typeof x) + ": "+ x +"\n");
>>>>>>>    x =  OvmsMetrics.Value("xiq.v.trip.consumption", "mipkwh", false)
>>>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption")
>>>>>>>    x =  OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh")
>>>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption")
>>>>>>>    x =  OvmsMetrics.AsFloat("xiq.v.trip.consumption","kmpkwh")
>>>>>>> number: 17.0582
>>>>>>> string: 17.0582
>>>>>>> number: 5.86227
>>>>>>> string: 3.64264
>>>>>>> string: 17.0582kWh/100km
>>>>>>> string: 3.64264mi/kWh
>>>>>>> number: 17.0582
>>>>>>> number: 5.86227
>>>>>>> It still might be an idea to use 'null' as a return value if the
>>>>>>> metrics is !IsDefined() but that would be changing the existing
>>>>>>> behaviour slightly.
>>>>>>> //.ichael
>>>>>>> On Mon, 7 Nov 2022 at 08:12, Michael Geddes <
>>>>>>>> I've worked out what the decode flag is for and how it works, and I
>>>>>>>> think how optional params work.
>>>>>>>> I'm pretty sure I won't  need the 'AsFloatUnit' function; the unit
>>>>>>>> would be an option to AsFloat(); I'll know that soon.
>>>>>>>> The 'Value' function is more complicated because of the optional
>>>>>>>> decode bool. I guess I could add the Unit to the end of that.
>>>>>>>> ValueUnit could be still useful then to provide a 'Value + Unit'.
>>>>>>>> Question:  Is there a reason we shouldn't be returning with
>>>>>>>> duk_push_null    if the metric !IsDefined()  in both AsFloat() and
>>>>>>>> Value(metric,true) cases?
>>>>>>>> //.ichael
>>>>>>>> On Sun, 6 Nov 2022 at 11:22, Michael Geddes <
>>>>>>>>> Right, so I've implemented some stuff that seems to work quite
>>>>>>>>> well.
>>>>>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/764
>>>>>>>>> should be ready now after a couple of stupid mistakes slipped through.
>>>>>>>>>  This absolutely needs somebody to review it please! (There's a reason why
>>>>>>>>> I've converted some if()'s to switch() - which is that it will be used in
>>>>>>>>> the follow-up commit).
>>>>>>>>> The commit that will follow on from that it implements the new
>>>>>>>>> Units: kWh/100km, km/kWh  and  mi/kWh.
>>>>>>>>> This is a summary of what I've implemented for scripting -
>>>>>>>>> including showing the unit codes I have so far.  I've considered a few
>>>>>>>>> things:
>>>>>>>>>   * Should some of the longer unit codes be shortened  (eg mi,
>>>>>>>>> mins, m, ft, deg, perc)
>>>>>>>>>   * The unit codes could be much more regular and separated by
>>>>>>>>> dots  eg:
>>>>>>>>>         watthours -> w.h
>>>>>>>>>         kwhp100km -> kw.h_100km or kw.h/100km
>>>>>>>>>         miph ->  mi_h or mi/h  (or should it be mph).
>>>>>>>>>         psi -> p_in.in or p/in.in or lb_in.in (yes, slightly
>>>>>>>>> weird, but predictable)
>>>>>>>>> *OVMS# metric units*
>>>>>>>>>           km : km
>>>>>>>>>        miles : M
>>>>>>>>>       meters : m
>>>>>>>>>         feet : ft
>>>>>>>>>      celcius : °C
>>>>>>>>>   fahrenheit : °F
>>>>>>>>>          kpa : kPa
>>>>>>>>>           pa : Pa
>>>>>>>>>          psi : psi
>>>>>>>>>        volts : V
>>>>>>>>>         amps : A
>>>>>>>>>     amphours : Ah
>>>>>>>>>           kw : kW
>>>>>>>>>          kwh : kWh
>>>>>>>>>        watts : W
>>>>>>>>>    watthours : Wh
>>>>>>>>>      seconds : Sec
>>>>>>>>>      minutes : Min
>>>>>>>>>        hours : Hour
>>>>>>>>>          utc : UTC
>>>>>>>>>      degrees : °
>>>>>>>>>         kmph : km/h
>>>>>>>>>         miph : Mph
>>>>>>>>>       kmphps : km/h/s
>>>>>>>>>       miphps : Mph/s
>>>>>>>>>         mpss : m/s²
>>>>>>>>>          dbm : dBm
>>>>>>>>>           sq : sq
>>>>>>>>>      percent : %
>>>>>>>>>        whpkm : Wh/km
>>>>>>>>>        whpmi : Wh/mi
>>>>>>>>>    kwhp100km : kWh/100km
>>>>>>>>>       kmpkwh : km/kWh
>>>>>>>>>       mipkwh : mi/kWh
>>>>>>>>>           nm : Nm
>>>>>>>>> *OVMS# metric unit mi*
>>>>>>>>>        miles : M
>>>>>>>>>      minutes : Min
>>>>>>>>>         miph : Mph
>>>>>>>>>       miphps : Mph/s
>>>>>>>>>        whpmi : Wh/mi
>>>>>>>>>       mipkwh : mi/kWh
>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption *17.0597kWh/100km
>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption kpkwh *5.86177km/kWh
>>>>>>>>> *OVMS# metric get xiq.v.trip.consumption mpkwh *3.64233mi/kWh
>>>>>>>>> *OVMS# metric set xiq.c.speed 5 miph *Metric set
>>>>>>>>> *OVMS# metric get xiq.c.speed *8.04673km/h
>>>>>>>>> *OVMS# metric get xiq.c.speed miph *5Mph
>>>>>>>>> And then in DukTape - there are some questions I have about the
>>>>>>>>> implementation:
>>>>>>>>> * Names of functions? Better ideas?
>>>>>>>>> * Should ValueUnit output the units?
>>>>>>>>> * In Value() there is the line    bool decode =
>>>>>>>>> duk_opt_boolean(ctx, 1, true);
>>>>>>>>>     * What does 'decode' mean here?
>>>>>>>>>     * Do I need it for ValueUnit() ?
>>>>>>>>> * (function() {    print(
>>>>>>>>> OvmsMetrics.Value("xiq.v.trip.consumption"));    print("\n")    print(
>>>>>>>>> OvmsMetrics.ValueUnit("xiq.v.trip.consumption",""));    print("\n")
>>>>>>>>>  print( OvmsMetrics.ValueUnit("xiq.v.trip.consumption","mipkwh"));
>>>>>>>>>  print("\n")    print(
>>>>>>>>> OvmsMetrics.AsFloatUnit("xiq.v.trip.consumption","kmpkwh")); })();*
>>>>>>>>> --- Output ---
>>>>>>>>> 17.0597
>>>>>>>>> 17.0597kWh/100km
>>>>>>>>> 3.64233mi/kWh
>>>>>>>>> 5.86177
>>>>>>>>> The basic stuff all works - it's just quibbling over the details..
>>>>>>>>> but let's get them right!
>>>>>>>>> //.ichael
>>>>>>>>> On Sat, 5 Nov 2022 at 20:09, Michael Geddes <
>>>>>>>>>> Yeah - this was copied code from kia/kona and is what triggered
>>>>>>>>>> these ideas; I totally agree this shouldn't be doubled up on.
>>>>>>>>>> I've got some commits centred round Metrics that I'll just check
>>>>>>>>>> over and push up ... and then I'll just have the single xiq.v.
>>>>>>>>>> trip.consumption metric (unless you have some ideas for the
>>>>>>>>>> namespace) which will be much neater.
>>>>>>>>>> If it's ok with you then I might do that unit conversion proposal.
>>>>>>>>>> Would it ok if the unit specifications were the same as to the
>>>>>>>>>> programatic codes in ovms_metrics.h?
>>>>>>>>>> (kWh,   WattHours , MetersPSS )
>>>>>>>>>> I would probably add a command
>>>>>>>>>> metric units <spec>
>>>>>>>>>> to list all (matching) units and their associated Labels.
>>>>>>>>>> //.ichael
>>>>>>>>>> On Sat, 5 Nov 2022 at 18:48, Michael Balzer <dexter at expeedo.de>
>>>>>>>>>> wrote:
>>>>>>>>>>> Michael,
>>>>>>>>>>> adding unit conversion support to the shell and Duktape commands
>>>>>>>>>>> is a good idea.
>>>>>>>>>>> Metrics are not meant to provide a user interface, they should
>>>>>>>>>>> be defined to be efficient and non-redundant.
>>>>>>>>>>> Btw, metrics names also shall not use upper case characters, and
>>>>>>>>>>> shall only use "." as a separator.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>>>>> Am 05.11.22 um 11:22 schrieb Michael Geddes:
>>>>>>>>>>> Hi all,
>>>>>>>>>>> Some of the code I copied from Kona/Kia code had both kwh/100km
>>>>>>>>>>> and km/kwh metrics in the code as 'Other'.
>>>>>>>>>>> Adding the various power consumption Units is not particularly
>>>>>>>>>>> hard (I will have a pull-request soon) - though the conversions between
>>>>>>>>>>> them all required some thought!
>>>>>>>>>>> ... but it also made me think these two metrics that are (with
>>>>>>>>>>> the consumption units added) defined like this:
>>>>>>>>>>> m_v_trip_consumption1 =
>>>>>>>>>>> MyMetrics.InitFloat("xiq.v.trip.consumption.KWh/100km", 10, 0, kWHP100K);
>>>>>>>>>>> m_v_trip_consumption2 = MyMetrics.InitFloat("
>>>>>>>>>>> xiq.v.trip.consumption.km/kWh", 10, 0, kPkWH);
>>>>>>>>>>> These are effectively the same metric but in different units!
>>>>>>>>>>> I'm wondering if we would be better to have scripting and
>>>>>>>>>>> Duktape support for converting metrics to different unit!  This might be
>>>>>>>>>>> also quite useful for those strange countries that insist on using miles as
>>>>>>>>>>> a measurement.
>>>>>>>>>>> On top of the 'metric list' and 'metric set' we could add a
>>>>>>>>>>> 'metric get' which gets a single value.. and add unit support for get/set.
>>>>>>>>>>> I've also got a pull request that improves the precision of the
>>>>>>>>>>> km<->mi conversions and factors it out.
>>>>>>>>>>> //.ichael
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221115/8c8deb5c/attachment-0001.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221115/8c8deb5c/attachment-0002.png>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221115/8c8deb5c/attachment-0003.png>
