[Ovmsdev] netreg and new crash?
    Craig Leres
    leres at xse.com
    Tue Nov  8 15:15:18 HKT 2022
I have been having a lot of issues with netreg over the last few weeks.
But Sunday when I built a new image I noticed some stack sizes had
changed between my sdkconfig and support/sdkconfig.default.hw31. (I
normally run with basically the support version but with most vehicles
turned off and ) I remember a thread I didn't follow closely about the
increasing the size of the stack. Anyway, I built and booted that
version (3.3.003-71-g5c873b72). And hadn't had a netreg issue for more
than a day across my three active modules.
Arriving home a few minutes ago I had a fresh netreg issue (the first
with this build). But it turned out to maybe be a crash...
     Last boot was 521 second(s) ago
     Time at boot: 2022-11-07 22:53:04 PST
       This is reset #3 since last power cycle
       Detected boot reason: Crash (12/12)
       Reset reason: Exception/panic (4)
       Crash counters: 3 total, 0 early
     Last crash: abort() was called on core 1
       Current task on core 0: IDLE0, 524 stack bytes free
       Current task on core 1: OVMS NetMan, 512 stack bytes free
       Backtrace:
       0x400891af 0x40089449 0x40261021 0x4023d1a2 0x40236f4a 0x4023893f
0x40247d73 0x40238c0e 0x40238c39 0x40127340 0x401289ec 0x4012a135
0x4012a65b 0x40126b4e 0x4011b053 0x4011b0f1
       Version: 3.3.003-71-g5c873b72-dirty/ota_1/main (build idf
v3.3.4-848-g1ff5e24b1 Nov  6 2022 10:35:33)
       Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
Which decodes as:
     xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x400891af 0x40089449
0x40261021 0x4023d1a2 0x40236f4a 0x4023893f 0x40247d73 0x40238c0e
0x40238c39 0x40127340 0x401289ec 0x4012a135 0x4012a65b 0x40126b4e
     .../esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
.../esp/openvehicles-xtensa-esp32-elf/components/esp32/hwcrypto/sha.c:272
.../esp/openvehicles-xtensa-esp32-elf/components/mbedtls/port/esp_sha256.c:349
.../esp/openvehicles-xtensa-esp32-elf/components/mbedtls/mbedtls/library/ssl_tls.c:7649
.../esp/openvehicles-xtensa-esp32-elf/components/mbedtls/mbedtls/library/ssl_cli.c:3894
     components/mongoose/mongoose/mongoose.c:1701
     main/ovms_netmanager.cpp:1036
diff'ing my sdkconfig against support/sdkconfig.default.hw31 I was
surprised to find that CONFIG_MDNS_TASK_STACK_SIZE was missing from
mine; I added it back (again), nuked the build directory and rebuilt...
and it was missing again:
     ice 616 % diff sdkconfig support/sdkconfig.default.hw31 | fgrep -v
CONFIG_OVMS_VEHICLE
     209c209
     < CONFIG_SPIRAM_CACHE_WORKAROUND=
     > CONFIG_SPIRAM_CACHE_WORKAROUND=y
     667,684c667,685
     687,692c688,693
     833a835
     > CONFIG_MDNS_TASK_STACK_SIZE=3072
What's the story with CONFIG_MDNS_TASK_STACK_SIZE?
		Craig
