[Ovmsdev] netreg and new crash?
    Wed Nov  9 01:34:51 HKT 2022
Craig,
sorry, I missed posting an info on this on the list. You need to update
your esp-idf for the new build config.
See commit note:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/3e5ac7747b03603661a51eb791386e976bcd2b32
A simple pull should do, no submodules changed.
Regarding your crash, that looks very similar to the ones I mentioned here:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/702#issuecomment-1295778399
.../esp/openvehicles-xtensa-esp32-elf/components/esp32/hwcrypto/sha.c:272
void esp_sha_read_digest_state(esp_sha_type sha_type, void *digest_state)
     /* Fault injection check: verify SHA engine actually ran,
        state is not all zeroes.
     for (int i = 0; i < word_len; i++) {
         if (digest_state_words[i] != 0) {
             return;
*    abort(); // SHA peripheral returned all zero state, probably due to
fault injection*
That's exactly the place I saw multiple crashes when using net data
encryption while the SSH key generator was still running.
No idea yet how that would happen / what we would need to change.
Am 08.11.22 um 08:15 schrieb Craig Leres:
> I have been having a lot of issues with netreg over the last few
> weeks. But Sunday when I built a new image I noticed some stack sizes
> had changed between my sdkconfig and support/sdkconfig.default.hw31.
> (I normally run with basically the support version but with most
> vehicles turned off and ) I remember a thread I didn't follow closely
> about the increasing the size of the stack. Anyway, I built and booted
> that version (3.3.003-71-g5c873b72). And hadn't had a netreg issue for
> more than a day across my three active modules.
> Arriving home a few minutes ago I had a fresh netreg issue (the first
> with this build). But it turned out to maybe be a crash...
>     Last boot was 521 second(s) ago
>     Time at boot: 2022-11-07 22:53:04 PST
>       This is reset #3 since last power cycle
>       Detected boot reason: Crash (12/12)
>       Reset reason: Exception/panic (4)
>       Crash counters: 3 total, 0 early
>     Last crash: abort() was called on core 1
>       Current task on core 0: IDLE0, 524 stack bytes free
>       Current task on core 1: OVMS NetMan, 512 stack bytes free
>       Backtrace:
>       0x400891af 0x40089449 0x40261021 0x4023d1a2 0x40236f4a
> 0x4023893f 0x40247d73 0x40238c0e 0x40238c39 0x40127340 0x401289ec
> 0x4012a135 0x4012a65b 0x40126b4e 0x4011b053 0x4011b0f1
>       Version: 3.3.003-71-g5c873b72-dirty/ota_1/main (build idf
> v3.3.4-848-g1ff5e24b1 Nov  6 2022 10:35:33)
>       Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600
> Which decodes as:
>     xtensa-esp32-elf-addr2line -e build/ovms3.elf 0x400891af
> 0x40089449 0x40261021 0x4023d1a2 0x40236f4a 0x4023893f 0x40247d73
> 0x40238c0e 0x40238c39 0x40127340 0x401289ec 0x4012a135 0x4012a65b
> .../esp/openvehicles-xtensa-esp32-elf/components/esp32/panic.c:736
> .../esp/openvehicles-xtensa-esp32-elf/components/mbedtls/port/esp_sha256.c:349
> .../esp/openvehicles-xtensa-esp32-elf/components/mbedtls/mbedtls/library/ssl_tls.c:7649
> .../esp/openvehicles-xtensa-esp32-elf/components/mbedtls/mbedtls/library/ssl_cli.c:3894
>     components/mongoose/mongoose/mongoose.c:1701
>     main/ovms_netmanager.cpp:1036
> diff'ing my sdkconfig against support/sdkconfig.default.hw31 I was
> surprised to find that CONFIG_MDNS_TASK_STACK_SIZE was missing from
> mine; I added it back (again), nuked the build directory and
> rebuilt... and it was missing again:
>     ice 616 % diff sdkconfig support/sdkconfig.default.hw31 | fgrep -v
> CONFIG_OVMS_VEHICLE
>     209c209
>     < CONFIG_SPIRAM_CACHE_WORKAROUND=
>     > CONFIG_SPIRAM_CACHE_WORKAROUND=y
>     667,684c667,685
>     687,692c688,693
>     833a835
>     > CONFIG_MDNS_TASK_STACK_SIZE=3072
> What's the story with CONFIG_MDNS_TASK_STACK_SIZE?
>         Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221108/8be07bd3/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221108/8be07bd3/attachment.sig>
