[Ovmsdev] Slider widget not disabled when first loading unchecked?
Tue Dec 27 23:00:02 HKT 2022
Ahh.  OK.
Sorry, totally misunderstood. That works with the checks and Battery
config.
On Tue, 27 Dec 2022, 7:09 pm Michael Balzer, <dexter at expeedo.de> wrote:
> Details were missing, so I just tried this over here, and don't see any
> immediate issues:
> diff --git
> a/vehicle/OVMS.V3/components/ovms_webserver/src/web_framework.cpp
> b/vehicle/OVMS.V3/components/ovms_webserver/src/web_framework.cpp
> index 913510c3..7d756f01 100644
> --- a/vehicle/OVMS.V3/components/ovms_webserver/src/web_framework.cpp
> +++ b/vehicle/OVMS.V3/components/ovms_webserver/src/web_framework.cpp
> @@ -361,7 +361,7 @@ void PageContext::input_slider(const char* label,
> const char* name, int size, co
>        "<label class=\"control-label col-sm-3\"
> for=\"input-%s\">%s:</label>"
>        "<div class=\"col-sm-9\">"
>          "<div class=\"form-control slider\" data-default=\"%g\"
> data-reset=\"false\""
> -        " data-value=\"%g\" data-min=\"%g\" data-max=\"%g\"
> data-step=\"%g\">"
> +        " data-value=\"%g\" data-min=\"%g\" data-max=\"%g\"
> data-step=\"%g\" data-checked=\"%s\">"
>            "<div class=\"slider-control form-inline\">"
>              "<input class=\"slider-enable\" type=\"%s\" %s> "
>              "<input class=\"form-control slider-value\" %s
> type=\"number\" style=\"width:%dpx;\""
> @@ -380,6 +380,7 @@ void PageContext::input_slider(const char* label,
>      , _attr(name)
>      , label
>      , defval, value, min, max, step
> +    , (enabled != 0) ? "true" : "false"
>      , (enabled < 0) ? "hidden" : "checkbox" // -1 => no checkbox
>      , (enabled > 0) ? "checked" : ""
>      , (enabled == 0) ? "disabled" : ""
> I've tested this quick & dirty on the Wifi config page by testing for the
> default value, that worked as expected.
> Am 27.12.22 um 11:32 schrieb Michael Geddes:
> Unfortunately that doesn't work (detail below).  The code I had worked
> much better from the  framework generated input box.. but I'm not sure how
> to test it in a plugin.
> I have the 2 sliders with checkboxes on http://ov.ms/#/xkn/battery  (ov.ms
> is a local network alias for my ovms box).
> I have one slider unchecked and one checked.
> Just putting data-checked as an attribute in the generated code caused
> both sliders to be disabled on first load!
> //.ichael
> On Tue, 27 Dec 2022 at 15:54, Michael Balzer <dexter at expeedo.de> wrote:
>> Michael,
>> I remember I changed the slider enable/disable control scheme from
>> reading the checkbox state to using the data attribute / option for a
>> reason, but I cannot remember exactly which now. I think it was to get
>> consistent dynamic controllability.
>> My initial commit was ec1a874dadce01e8bd588c20115d890acd9149c2, which
>> used the checkbox state. A few days later in
>> 91ed78a3d7ac5392eadd65be026a1a0fc77a611e I changed this to using the
>> `checked` option, but missed adding `data-checked` to
>> `PageContext::input_slider()` accordingly.
>> Sliders using the enable/disable feature at that time only appeared in
>> plugins/pages doing dynamic initialization, so this didn't become visible.
>> Plugins normally create sliders by data attributes or init options, not by
>> explicit markup.
>> TL;DR: I think the fix would probably better be to add the missing
>> `data-checked` to the markup created by `PageContext::input_slider()`.
>> Am 27.12.22 um 04:40 schrieb Michael Geddes:
>> Right, so that didn't work if the check-box was disabled (like in wifi)-
>> but this does seem to work!
>>     var $sld = $(this).closest('.slider'), $cbi =
>> $sld.find('.slider-enable'), data = $.extend({ checked: ($cbi.prop("type")
>> === "hidden" || $cbi.prop("checked")) }, $sld.data());
>> //.ichael
>> On Tue, 27 Dec 2022 at 11:04, Michael Geddes <frog at bunyip.wheelycreek.net>
>> wrote:
>>> Hi all,
>>> I've noticed that if you create a 'slider' widget with a checkbox that
>>> if it's unchecked when it first loads, then the slider is enabled. If you
>>> check/uncheck then the slider is disabled. Or at least that's what I seen
>>> in google chrome.
>>> I'm really not familiar with NodeJS, but this _seems_ to fix the problem:
>>> Does this fix make sense?  If so - I'll do a p/r for it.
>>> //.ichael
>>> * Slider widget plugin
>>>  $.fn.slider = function(options) {
>>>    return this.each(function() {
>>> -    var $sld = $(this).closest('.slider'), data = $.extend({ checked:
>>> true }, $sld.data());
>>> +    var $sld = $(this).closest('.slider'), $cbi =
>>> $cbi.prop("checked") }, $sld.data());
>>>      var opts = (typeof options == "object") ? options : data;
>>>      // init?
>>>      if ($sld.children().length == 0) {
>>>        var id = $sld.attr('id');
>>>        $sld.html('\
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221227/58e327f1/attachment-0001.htm>
