[Ovmsdev] Slider widget not disabled when first loading unchecked?
    Tue Dec 27 19:09:21 HKT 2022
Details were missing, so I just tried this over here, and don't see any
immediate issues:
diff --git
a/vehicle/OVMS.V3/components/ovms_webserver/src/web_framework.cpp
b/vehicle/OVMS.V3/components/ovms_webserver/src/web_framework.cpp
index 913510c3..7d756f01 100644
--- a/vehicle/OVMS.V3/components/ovms_webserver/src/web_framework.cpp
+++ b/vehicle/OVMS.V3/components/ovms_webserver/src/web_framework.cpp
@@ -361,7 +361,7 @@ void PageContext::input_slider(const char* label,
const char* name, int size, co
        "<label class=\"control-label col-sm-3\"
for=\"input-%s\">%s:</label>"
        "<div class=\"col-sm-9\">"
          "<div class=\"form-control slider\" data-default=\"%g\"
data-reset=\"false\""
-        " data-value=\"%g\" data-min=\"%g\" data-max=\"%g\"
data-step=\"%g\">"
+        " data-value=\"%g\" data-min=\"%g\" data-max=\"%g\"
data-step=\"%g\" data-checked=\"%s\">"
            "<div class=\"slider-control form-inline\">"
              "<input class=\"slider-enable\" type=\"%s\" %s> "
              "<input class=\"form-control slider-value\" %s
type=\"number\" style=\"width:%dpx;\""
@@ -380,6 +380,7 @@ void PageContext::input_slider(const char* label,
      , _attr(name)
      , label
      , defval, value, min, max, step
+    , (enabled != 0) ? "true" : "false"
      , (enabled < 0) ? "hidden" : "checkbox" // -1 => no checkbox
      , (enabled > 0) ? "checked" : ""
      , (enabled == 0) ? "disabled" : ""
I've tested this quick & dirty on the Wifi config page by testing for
the default value, that worked as expected.
Am 27.12.22 um 11:32 schrieb Michael Geddes:
> Unfortunately that doesn't work (detail below). The code I had worked
> much better from the  framework generated input box.. but I'm not sure
> how to test it in a plugin.
> I have the 2 sliders with checkboxes on http://ov.ms/#/xkn/battery
> (ov.ms <http://ov.ms> is a local network alias for my ovms box).
> I have one slider unchecked and one checked.
> Just putting data-checked as an attribute in the generated code caused
> both sliders to be disabled on first load!
> //.ichael
> On Tue, 27 Dec 2022 at 15:54, Michael Balzer <dexter at expeedo.de> wrote:
>     Michael,
>     I remember I changed the slider enable/disable control scheme from
>     reading the checkbox state to using the data attribute / option
>     for a reason, but I cannot remember exactly which now. I think it
>     was to get consistent dynamic controllability.
>     My initial commit was ec1a874dadce01e8bd588c20115d890acd9149c2,
>     which used the checkbox state. A few days later in
>     91ed78a3d7ac5392eadd65be026a1a0fc77a611e I changed this to using
>     the `checked` option, but missed adding `data-checked` to
>     `PageContext::input_slider()` accordingly.
>     Sliders using the enable/disable feature at that time only
>     appeared in plugins/pages doing dynamic initialization, so this
>     didn't become visible. Plugins normally create sliders by data
>     attributes or init options, not by explicit markup.
>     TL;DR: I think the fix would probably better be to add the missing
>     `data-checked` to the markup created by `PageContext::input_slider()`.
>     Regards,
>     Michael
>     Am 27.12.22 um 04:40 schrieb Michael Geddes:
>>     Right, so that didn't work if the check-box was disabled (like in
>>     wifi)- but this does seem to work!
>>         var $sld = $(this).closest('.slider'), $cbi =
>>     $sld.find('.slider-enable'), data = $.extend({ checked:
>>     ($cbi.prop("type") === "hidden" || $cbi.prop("checked")) },
>>     $sld.data());
>>     //.ichael
>>     On Tue, 27 Dec 2022 at 11:04, Michael Geddes
>>     <frog at bunyip.wheelycreek.net> wrote:
>>         Hi all,
>>         I've noticed that if you create a 'slider' widget with a
>>         checkbox that if it's unchecked when it first loads, then the
>>         slider is enabled. If you check/uncheck then the slider is
>>         disabled. Or at least that's what I seen in google chrome.
>>         I'm really not familiar with NodeJS, but this _seems_ to fix
>>         the problem:
>>         Does this fix make sense?  If so - I'll do a p/r for it.
>>         //.ichael
>>         * Slider widget plugin
>>          $.fn.slider = function(options) {
>>            return this.each(function() {
>>         - var $sld = $(this).closest('.slider'), data = $.extend({
>>         checked: true }, $sld.data());
>>         +    var $sld = $(this).closest('.slider'), $cbi =
>>         $cbi.prop("checked") }, $sld.data());
>>              var opts = (typeof options == "object") ? options : data;
>>              // init?
>>              if ($sld.children().length == 0) {
>>                var id = $sld.attr('id');
>>                $sld.html('\
>>     _______________________________________________
>>     OvmsDev mailing list
>>     OvmsDev at lists.openvehicles.com
>>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>     Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>     Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221227/85bcb1e2/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20221227/85bcb1e2/attachment.sig>
