[Ovmsdev] Not processing canbus frames anymore
Fri Apr 15 16:09:00 HKT 2022
Simon,
interrupt counters work different depending on the CAN transceiver &
communication type, CAN2/3 are MCP2515 via SPI, while CAN1 is ESP32CAN
(loosely SJA1000 compatible) via internal bus. There is generally only a
loose connection, as any RX will trigger at least one interrupt, but not
all interrupts are RX related, and an RX interrupt can cover multiple
buffered packets.
But…
> Interrupts:             3036646
> Rx pkt:                 3044758
…that's possibly a hint you've frequent packet bursts on that bus, and
that may be the cause you're experiencing the freeze so often. That
would lead to a possible bug in the driver's RX handling for situations
where new packets come in very fast. The MCP2515 isn't particularly
simple to read & control in such situations, our driver may lack some
crucial handling.
> Err flags: 0x01000001
For the mcp2515 driver, that means…
  * intstat = 0x01 → RX buffer 0 full
  * errflag = 0x00
…so no actual error condition. Some development of the error status is
possibly readable from the system log and/or CAN log.
Am 14.04.22 um 20:58 schrieb Simon Ehlen:
> AW: [Ovmsdev] Not processing canbus frames anymore
> My CAN1 bus works without problems, as before only CAN2 and CAN3 are
> affected.
> Enclosed is a current excerpt from the status. Both CAN2 and CAN3 do
> not provide any new data at the moment, although both buses are still
> active. For me it is noticeable that currently CAN3 has more packets
> than interrupts. I have observed the same with CAN2, but never with CAN1.
> Greg D. had indicated that there was a problem with CAN2/CAN3 in the
> past where the buses went deaf after a while. Has the problem actually
> been fixed in the past or is this still the problem that remains
> unresolved?
> Is there any other information I could provide to help track down the
> problem?
> CAN:       can1
> Mode:      Active
> Speed:     500000
> DBC:       none
> Interrupts:            14256668
> Rx pkt:                14245150
> Rx ovrflw:                   23
> Tx pkt:                       0
> Tx delays:                    0
> Tx ovrflw:                    0
> Tx fails:                     0
> Err flags: 0x00000000
> Rx err:                       0
> Tx err:                       0
> Rx invalid:                   0
> Wdg Resets:                   0
> Wdg Timer:                    0 sec(s)
> Err Resets:                   0
> CAN:       can2
> Mode:      Active
> Speed:     125000
> DBC:       none
> Interrupts:              101488
> Rx pkt:                  101483
> Rx ovrflw:                    0
> Tx pkt:                       0
> Tx delays:                    0
> Tx ovrflw:                    0
> Tx fails:                     0
> Rx err:                       0
> Tx err:                       0
> Rx invalid:                   0
> Wdg Resets:                   0
> Wdg Timer:                    9 sec(s)
> Err Resets:                   0
> CAN:       can3
> Mode:      Active
> Speed:     500000
> DBC:       none
> Interrupts:             3036646
> Rx pkt:                 3044758
> Rx ovrflw:                    0
> Tx pkt:                       0
> Tx delays:                    0
> Tx ovrflw:                    0
> Tx fails:                     0
> Rx err:                       0
> Tx err:                       0
> Rx invalid:                   0
> Wdg Resets:                   0
> Wdg Timer:                    0 sec(s)
> Err Resets:                   0
> Kind regards,
> Simon
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220415/b572952c/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220415/b572952c/attachment.sig>
