[Ovmsdev] Not processing canbus frames anymore
Simon Ehlen ovms at highteq.de
Fri Apr 15 02:58:00 HKT 2022
My CAN1 bus works without problems, as before only CAN2 and CAN3 are affected.
 Enclosed is a current excerpt from the status. Both CAN2 and CAN3 do not provide any new data at the moment, although both buses are still active. For me it is noticeable that currently CAN3 has more packets than interrupts. I have observed the same with CAN2, but never with CAN1.
 Greg D. had indicated that there was a problem with CAN2/CAN3 in the past where the buses went deaf after a while. Has the problem actually been fixed in the past or is this still the problem that remains unresolved?
 Is there any other information I could provide to help track down the problem?
 CAN:       can1
Mode:      Active
Speed:     500000
DBC:       none
 Interrupts:            14256668
Rx pkt:                14245150
Rx ovrflw:                   23
Tx pkt:                       0
Tx delays:                    0
Tx ovrflw:                    0
Tx fails:                     0
 Err flags: 0x00000000
Rx err:                       0
Tx err:                       0
Rx invalid:                   0
Wdg Resets:                   0
Wdg Timer:                    0 sec(s)
Err Resets:                   0
 CAN:       can2
Mode:      Active
Speed:     125000
DBC:       none
 Interrupts:              101488
Rx pkt:                  101483
Rx ovrflw:                    0
Tx pkt:                       0
Tx delays:                    0
Tx ovrflw:                    0
Tx fails:                     0
 Err flags: 0x01000001
Rx err:                       0
Tx err:                       0
Rx invalid:                   0
Wdg Resets:                   0
Wdg Timer:                    9 sec(s)
Err Resets:                   0
 CAN:       can3
Mode:      Active
Speed:     500000
DBC:       none
 Interrupts:             3036646
Rx pkt:                 3044758
Rx ovrflw:                    0
Tx pkt:                       0
Tx delays:                    0
Tx ovrflw:                    0
Tx fails:                     0
Rx err:                       0
Tx err:                       0
Rx invalid:                   0
Wdg Resets:                   0
Wdg Timer:                    0 sec(s)
Err Resets:                   0
 Kind regards,
Simon
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20220414/faa95ee5/attachment.htm>
