[Ovmsdev] Branch for-v3.3 network issues
    Craig Leres
    leres at xse.com
    Tue Sep 21 05:18:10 HKT 2021
On 9/20/21 2:12 PM, Michael Balzer wrote:
>> OVMS# log status
>> Log listeners      : 4
>> File logging status: active
>>   Log file path    : /sd/logs/ovms-z.log
>>   Current size     : 182.2 kB
>>   Cycle size       : 1024 kB
>>   Cycle count      : 0
>>   Dropped messages : 0
>>   Messages logged  : 45
>>   Total fsync time : 0.1 s
> That's file logging enabled, and logs stored on your SD card in the
> "logs" directory. If your config is unchanged, you should find some
> archived log files there. Configuration is btw explained here:
> https://docs.openvehicles.com/en/latest/userguide/logging.html#logging-to-sd-card
> You cannot download these files via the server. The "*-OVM-ServerLog" is
> just the protocol of the server communication as seen by the server.
Got it.
> To download the module log files from /sd/logs, you can either use the
> web UI, or you can use ssh/scp.
I used scp to get the currently active log (/sd/logs/ovms-z.log) but it
doesn't contain any testev logs. I believe it covers the test I did
overnight (the timestamps are UTC but it starts on 2021-09-18 20:16 and
goes until 2021-09-20 13:14).
I guess I'm expecting to have to add some config to enable logging the
test events to the sd log.
		Craig
