[Ovmsdev] Branch for-v3.3 network issues
    Tue Sep 21 05:26:38 HKT 2021
Am 20.09.21 um 23:18 schrieb Craig Leres:
> I used scp to get the currently active log (/sd/logs/ovms-z.log) but
> it doesn't contain any testev logs. I believe it covers the test I did
> overnight (the timestamps are UTC but it starts on 2021-09-18 20:16
> and goes until 2021-09-20 13:14).
> I guess I'm expecting to have to add some config to enable logging the
> test events to the sd log.
Script outputs are logged at "info" level, which is the default. Unless
you've set the level to "warn" or "error" for the "script" component,
you should have them.
You should see a line like "script: [eval:1:] usr.testev.10: <loopcnt>"
every three seconds.
When starting the event loop from ssh, you can see these by doing "log
monitor yes".
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210920/d1d36f16/attachment.sig>
