[Ovmsdev] Branch for-v3.3 network issues
    Craig Leres
    leres at xse.com
    Sat Sep 18 06:14:56 HKT 2021
On 9/17/21 12:24 AM, Michael Balzer wrote:
> I've been running the new for-v3.3 version this week on both of my
> modules without ppp issues.
> Duktape still occasionally runs into the null/undefined issue with for…in:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/474#issuecomment-744005044
> for…in normally doesn't throw an error even if you run over null or
> undefined.
> I think both could still be the SPIRAM bug, now probably only occurring
> with very specific conditions. We build with LWIP using SPIRAM as well,
> so the PPP instance is allocated from SPIRAM also. Reallocating the
> instance on each new connect implies a higher chance of triggering the
> problem if it's address specific. The Duktape stack object addresses
> vary continuously with the running event handlers and user interactions,
> so that also has a high chance of occasionally triggering an address
> specific bug.
> We need to test the revision 3 ESP32 on this.
What can I do to test this on my frankenstein v3 module?
		Craig
