[Ovmsdev] Branch for-v3.3 network issues
Sat Sep 18 23:28:12 HKT 2021
Craig,
Am 18.09.21 um 00:14 schrieb Craig Leres:
> On 9/17/21 12:24 AM, Michael Balzer wrote:
>> Duktape still occasionally runs into the null/undefined issue with
>> for…in:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/474#issuecomment-744005044
>> We need to test the revision 3 ESP32 on this.
> What can I do to test this on my frankenstein v3 module?
Here's a simple test that reliably reproduces the effect on my modules:
1. Setup handler loop: script eval 'PubSub.subscribe("usr.testev",
function(ev) { var ms=Number(ev.substr(11))||10;
OvmsEvents.Raise("usr.testev."+ms, ms); })'
2. Start event loop with 10 ms interval: event raise usr.testev.10
The handler will keep raising the same event with the given interval.
You can monitor the events by settingt log level debug on events or
using the event tracing (event trace on/off), be aware 10 ms will flood
your terminal/shell. Check the Duktape CPU usage to see if the loop is
still running without enabling the event log.
The loop _should_ normally run indefinitely. To stop it manually, you
would do: script eval 'PubSub.unsubscribe("usr.testev")'
In reality, it will abort after some random run time with a log entry
like this:
E (1803740) ovms-duktape: [int/PubSub.js:1] TypeError: not object
coercible| at [anon] (duk_api_stack.c:3661) internal| at hasKeys
(int/PubSub.js:1) strict| at messageHasSubscribers (int/PubSub.js:1)
strict| at publish (int/PubSub.js:1) strict| at [anon]
(int/PubSub.js:1) strict preventsyield
…or (newly discovered today) with a heap corruption crash, which may
have another cause though (investigating).
If it stops with the "TypeError", the loop should be restartable simply
by repeating step 2. That proves the PubSub handler setup is still intact.
The time it needs to run into the TypeError varies widely and has some
dependance on how many other handlers are registered. With no other
javascript handlers registered, it normally takes 15-30 minutes on my
modules to run into the error. With AuxBatMon, PwrMon & Edimax plugins
enabled, it will normally happen within 5 minutes, sometimes within a
few seconds.
The interval is basically irrelevant, the effect just comes faster with
a short interval.
PS: btw, the effect occurs with Duktape running in the upper 2 MB as
well. That doesn't prove it's not the SPIRAM bug though, it just may
have other trigger conditions.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210918/7270304a/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210918/7270304a/attachment.sig>
