[Ovmsdev] Branch for-v3.3 network issues
    Mon Sep 20 02:52:30 HKT 2021
I've now also results from testing different heap placements in the
SPIRAM address space.
I've done these tests on branch "master" with duktape running on core 1
(= no heap corruption crashes).
To shift the duktape heap location into the upper SPIRAM regions, I
added this modification to DukTapeInit():
*    void *shiftmem = ExternalRamMalloc(2*1024*1024);*
     umm_memory = ExternalRamMalloc(memsize);
*    ESP_LOGI(TAG, "Duktape: shiftmem=%p umm_memory=%p", shiftmem,
umm_memory);**
**    if (shiftmem) free(shiftmem);*
I've tried shifting into the upper 2 MB as shown here, and then shifting
by just 1 MB up to place the head at the upper end of the lower 2 MB (so
memory corruption by other processes is unlikely). I've then run the
event test script 15 times until aborted by the error and collected the
total loop counts.
Result: there is a strong correlation between the heap memory half used
and the error frequency: with the heap in the upper half (shifted by 2
MB), the loop will run *>10x longer* on average than with the heap in
the lower half.
In absolute numbers: the average loop count with the heap in the lower 2
MB SPIRAM was ~ 3,000, with the heap shifted into the upper 2 MB it was
~ 40,000.
Within the lower half, there is no difference between shifting by 1 MB
and no shifting, so it's most probably not caused by some other process
corrupting the duktape heap region.
My conclusion would be now, this is still the SPIRAM bug, or a
previously undetected variant thereof. Can some others please try to
reproduce my results?
Am 17.09.21 um 10:56 schrieb Michael Balzer:
> I just remembered…
> https://github.com/espressif/esp-idf/issues/2892#issuecomment-459120605
> …and as Duktape runs on core #1, I now test shifting the Duktape heap
> into the upper 2 MB of SPIRAM.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210919/ebd4b22b/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210919/ebd4b22b/attachment-0001.sig>
