[Ovmsdev] Duktape heap memory management
    Mon Sep  6 10:33:42 HKT 2021
Craig,
For SIM7600, ANT1 is GPS, and ANT2 is GSM. ANT3 should not be connected.
> On 6 Sep 2021, at 1:40 AM, Craig Leres <leres at xse.com> wrote:
> As it turns out, u.fl sockets are directional (if I had looked more closely I would have seen this). The socket I replaced at ant3 had the correct orientation but after removing it all 4 pins are still shorted together. This makes me think ant3 is not really used with a sim7600.
> The socket on ant2 was reversed. Installing a new one correctly solved the short circuit but now it appears to be open and I'm still getting no signal (+CSQ: 99,99). So I guess now I need to swap the simcom module.
> 		Craig
