[Ovmsdev] Duktape heap memory management
Craig Leres
leres at xse.com
Mon Sep 6 01:40:02 HKT 2021
As it turns out, u.fl sockets are directional (if I had looked more
closely I would have seen this). The socket I replaced at ant3 had the
correct orientation but after removing it all 4 pins are still shorted
together. This makes me think ant3 is not really used with a sim7600.
The socket on ant2 was reversed. Installing a new one correctly solved
the short circuit but now it appears to be open and I'm still getting no
signal (+CSQ: 99,99). So I guess now I need to swap the simcom module.
Craig
