[Ovmsdev] Duktape heap memory management
    Craig Leres
    leres at xse.com
    Sun Sep  5 15:36:16 HKT 2021
On 9/4/21 6:45 PM, Craig Leres wrote:
> Something I can try without much effort is to swap in my spare SIM5380
> modem, that might reveal some other issue with my setup.
I tried this and the sim5380 was able to register right away and I could
see that it was active on the hologram.io dashboard. So I'm sure now
that my antenna works at least to the u.fl pigtail.
I checked resistance between the center pin of the ant3 u.fl socket and
the pin on sim5380 module and it was single digits M ohms. But I see now
that both ant2 and ant3 on my sim7600 module are shorted to ground. So
that's a problem.
I remember trying to move the u.fl socket from ant3 to ant2 and giving
up and soldering new sockets in both locations. And I found the socket I
removed. Comparing it to some unused new sockets (mouser
712-CONUFL001-SMD) I see they this stupid tab that comes off of the
grounded part of the connector. I thought all 4 sides of the old u.fl
were soldered but looking at the old one I removed, I see now that only
3 were and the 4th just had solder on the trace. Oops.
Well this should be an easy fix (assuming I haven't hurt the simcom --
but if so I have two new sim7600 and one sim7100 handy).
		Craig
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210905/fa0e3c00/attachment.jpg>
