[Ovmsdev] 3.2.018 release
Craig Leres
leres at xse.com
Mon Nov 22 14:53:00 HKT 2021
On 11/21/21 16:25, Mark Webb-Johnson wrote:
> The ‘user interrupt’ is just the error code that comes back from the PPP driver when the cellular link goes down.
> We’d really need a log file to see what the issue is.
I figured. I used:
log monitor
log level verbose cellular
Is the attached sufficient? Looks like it wraps around the axle
suspiciously close to 12 hours after boot.
Craig
D (197024) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
D (197034) cellular: mux-rx-line #3: +CPSI:
LTE,Online,310-410,0x8B44,169982479,257,EUTRAN-BAND12,5110,3,3,-103,-931,-655,14
D (197044) cellular: mux-rx-line #3: +CREG: 1,5
D (197044) cellular: mux-rx-line #3: +CCLK: "21/11/21,10:22:48-32"
D (197044) cellular: mux-rx-line #3: +CSQ: 23,99
D (197044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
D (43127044) cellular: mux-rx-line #3: +CPSI:
LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-125,-1207,-883,12
D (43127044) cellular: mux-rx-line #3: +CREG: 1,5
D (43127044) cellular: mux-rx-line #3: +CCLK: "21/11/21,22:18:18-32"
D (43127044) cellular: mux-rx-line #3: +CSQ: 13,99
D (43127044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
OVMS# D (43157024) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
D (43157044) cellular: mux-rx-line #3: +CPSI:
LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-138,-1210,-876,12
D (43157044) cellular: mux-rx-line #3: +CREG: 1,5
D (43157044) cellular: mux-rx-line #3: +CCLK: "21/11/21,22:18:48-32"
D (43157044) cellular: mux-rx-line #3: +CSQ: 13,99
D (43157044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
OVMS# D (43187024) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
D (43187034) cellular: mux-rx-line #3: +CPSI:
LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-129,-1206,-877,12
D (43187044) cellular: mux-rx-line #3: +CREG: 1,5
D (43187044) cellular: mux-rx-line #3: +CCLK: "21/11/21,22:19:18-32"
D (43187044) cellular: mux-rx-line #3: +CSQ: 13,99
D (43187044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
OVMS# I (43201024) housekeeping: 2021-11-21 22:19:33 PST (RAM:
8b=86580-87608 32b=30544)
OVMS# D (43217024) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
D (43217044) cellular: mux-rx-line #3: +CPSI:
LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-136,-1212,-879,11
D (43217044) cellular: mux-rx-line #3: +CREG: 1,5
D (43217044) cellular: mux-rx-line #3: +CCLK: "21/11/21,22:19:48-32"
D (43217044) cellular: mux-rx-line #3: +CSQ: 13,99
D (43217044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
OVMS# D (43218664) cellular: mux-rx-line #3: NO CARRIER
D (43218664) cellular: mux-rx-line #4: NO CARRIER
D (43218674) cellular: mux-rx-line #3: +PPPD: DISCONNECTED
I (43218674) cellular: PPP Connection disconnected
D (43218674) cellular: mux-rx-line #4: +PPPD: DISCONNECTED
OVMS# W (43219024) cellular: Lost network connection (+PPP disconnect in
NetMode)
D (43219024) cellular: State transition NetMode => NetLoss
I (43219024) cellular: State: Enter NetLoss state
D (43219024) cellular: mux-tx #3: AT+CGATT=0
V (43219024) cellular: Stopping PPP
I (43219024) gsm-ppp: Shutting down (hard)...
I (43219024) gsm-ppp: PPP is shutdown
I (43219024) netmanager: Set DNS#1 0.0.0.0
I (43219024) netmanager: Set DNS#2 0.0.0.0
I (43219024) netmanager: MODEM down (with WIFI client up): staying with
WIFI client priority
OVMS# I (43224644) gsm-ppp: StatusCallBack: User Interrupt
OVMS# D (43229024) cellular: State timeout NetLoss => NetWait
I (43229024) cellular: State: Enter NetWait state
OVMS# D (43233024) cellular: State transition NetWait => NetStart
I (43233024) cellular: State: Enter NetStart state
OVMS# D (43233834) cellular: mux-rx-line #2: +CSQ: 10,99
I (43233834) cellular: Signal Quality is: 10 (-93 dBm)
D (43233834) cellular: mux-rx-line #3: +CSQ: 10,99
D (43233834) cellular: mux-rx-line #4: +CSQ: 10,99
D (43233834) cellular: mux-rx-line #2: +CREG: 5
D (43233834) cellular: mux-rx-line #3: +CREG: 5
D (43233834) cellular: mux-rx-line #4: +CREG: 5
D (43234024) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
D (43234064) cellular: mux-rx-line #2: CONNECT 115200
I (43234064) cellular: PPP Connection is ready to start
OVMS# D (43235024) cellular: State transition NetStart => NetMode
I (43235024) cellular: State: Enter NetMode state
V (43235024) cellular: Starting PPP
I (43235024) gsm-ppp: Initialising...
D (43235114) cellular: mux-rx-line #3: NO CARRIER
D (43235114) cellular: mux-rx-line #4: NO CARRIER
D (43235124) cellular: mux-rx-line #3: +PPPD: DISCONNECTED
I (43235124) cellular: PPP Connection disconnected
D (43235124) cellular: mux-rx-line #4: +PPPD: DISCONNECTED
OVMS# W (43236024) cellular: Lost network connection (+PPP disconnect in
NetMode)
D (43236024) cellular: State transition NetMode => NetLoss
I (43236024) cellular: State: Enter NetLoss state
D (43236024) cellular: mux-tx #3: AT+CGATT=0
V (43236024) cellular: Stopping PPP
I (43236024) gsm-ppp: Shutting down (hard)...
I (43236024) gsm-ppp: PPP is shutdown
I (43236024) netmanager: Set DNS#1 0.0.0.0
I (43236024) netmanager: Set DNS#2 0.0.0.0
OVMS# D (43246024) cellular: State timeout NetLoss => NetWait
I (43246024) cellular: State: Enter NetWait state
OVMS# I (43248024) gsm-ppp: StatusCallBack: User Interrupt
OVMS# D (43250024) cellular: State transition NetWait => NetStart
I (43250024) cellular: State: Enter NetStart state
OVMS# D (43251024) cellular: Netstart
D (43251064) cellular: mux-rx-line #2: CONNECT 115200
I (43251064) cellular: PPP Connection is ready to start
OVMS# D (43252024) cellular: State transition NetStart => NetMode
I (43252024) cellular: State: Enter NetMode state
V (43252024) cellular: Starting PPP
I (43252024) gsm-ppp: Initialising...
D (43252104) cellular: mux-rx-line #3: NO CARRIER
D (43252104) cellular: mux-rx-line #4: NO CARRIER
D (43252114) cellular: mux-rx-line #3: +PPPD: DISCONNECTED
