[Ovmsdev] 3.2.018 release
Tue Nov 23 10:43:17 HKT 2021
From the logs, it seems the GSM link is established, but PPP could not be connected.
Could this be a merging coverage area (although the CSQ of 13 seems fine), or some other problem with data connection?
The error messages 'NO CARRIER’ and '+PPPD: DISCONNECTED’ are from the modem itself.
> On 22 Nov 2021, at 2:53 PM, Craig Leres <leres at xse.com> wrote:
> On 11/21/21 16:25, Mark Webb-Johnson wrote:
>> The ‘user interrupt’ is just the error code that comes back from the PPP driver when the cellular link goes down.
>> We’d really need a log file to see what the issue is.
> I figured. I used:
> log monitor
> log level verbose cellular
> Is the attached sufficient? Looks like it wraps around the axle suspiciously close to 12 hours after boot.
> Craig
> D (197024) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
> D (197034) cellular: mux-rx-line #3: +CPSI: LTE,Online,310-410,0x8B44,169982479,257,EUTRAN-BAND12,5110,3,3,-103,-931,-655,14
> D (197044) cellular: mux-rx-line #3: +CREG: 1,5
> D (197044) cellular: mux-rx-line #3: +CCLK: "21/11/21,10:22:48-32"
> D (197044) cellular: mux-rx-line #3: +CSQ: 23,99
> D (197044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
> D (43127044) cellular: mux-rx-line #3: +CPSI: LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-125,-1207,-883,12
> D (43127044) cellular: mux-rx-line #3: +CREG: 1,5
> D (43127044) cellular: mux-rx-line #3: +CCLK: "21/11/21,22:18:18-32"
> D (43127044) cellular: mux-rx-line #3: +CSQ: 13,99
> D (43127044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
> OVMS# D (43157024) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
> D (43157044) cellular: mux-rx-line #3: +CPSI: LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-138,-1210,-876,12
> D (43157044) cellular: mux-rx-line #3: +CREG: 1,5
> D (43157044) cellular: mux-rx-line #3: +CCLK: "21/11/21,22:18:48-32"
> D (43157044) cellular: mux-rx-line #3: +CSQ: 13,99
> D (43157044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
> OVMS# D (43187024) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
> D (43187034) cellular: mux-rx-line #3: +CPSI: LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-129,-1206,-877,12
> D (43187044) cellular: mux-rx-line #3: +CREG: 1,5
> D (43187044) cellular: mux-rx-line #3: +CCLK: "21/11/21,22:19:18-32"
> D (43187044) cellular: mux-rx-line #3: +CSQ: 13,99
> D (43187044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
> OVMS# I (43201024) housekeeping: 2021-11-21 22:19:33 PST (RAM: 8b=86580-87608 32b=30544)
> OVMS# D (43217024) cellular: mux-tx #3: AT+CREG?;+CCLK?;+CSQ;+CPSI?;+COPS?
> D (43217044) cellular: mux-rx-line #3: +CPSI: LTE,Online,310-410,0x8B44,169982472,7,EUTRAN-BAND2,800,5,5,-136,-1212,-879,11
> D (43217044) cellular: mux-rx-line #3: +CREG: 1,5
> D (43217044) cellular: mux-rx-line #3: +CCLK: "21/11/21,22:19:48-32"
> D (43217044) cellular: mux-rx-line #3: +CSQ: 13,99
> D (43217044) cellular: mux-rx-line #3: +COPS: 0,0,"AT&T Hologram",7
> OVMS# D (43218664) cellular: mux-rx-line #3: NO CARRIER
> D (43218664) cellular: mux-rx-line #4: NO CARRIER
> D (43218674) cellular: mux-rx-line #3: +PPPD: DISCONNECTED
> I (43218674) cellular: PPP Connection disconnected
> D (43218674) cellular: mux-rx-line #4: +PPPD: DISCONNECTED
> OVMS# W (43219024) cellular: Lost network connection (+PPP disconnect in NetMode)
> D (43219024) cellular: State transition NetMode => NetLoss
> I (43219024) cellular: State: Enter NetLoss state
> D (43219024) cellular: mux-tx #3: AT+CGATT=0
> V (43219024) cellular: Stopping PPP
> I (43219024) gsm-ppp: Shutting down (hard)...
> I (43219024) gsm-ppp: PPP is shutdown
> I (43219024) netmanager: Set DNS#1 0.0.0.0
> I (43219024) netmanager: Set DNS#2 0.0.0.0
> I (43219024) netmanager: MODEM down (with WIFI client up): staying with WIFI client priority
> OVMS# I (43224644) gsm-ppp: StatusCallBack: User Interrupt
> OVMS# D (43229024) cellular: State timeout NetLoss => NetWait
> I (43229024) cellular: State: Enter NetWait state
> OVMS# D (43233024) cellular: State transition NetWait => NetStart
> I (43233024) cellular: State: Enter NetStart state
> OVMS# D (43233834) cellular: mux-rx-line #2: +CSQ: 10,99
> I (43233834) cellular: Signal Quality is: 10 (-93 dBm)
> D (43233834) cellular: mux-rx-line #3: +CSQ: 10,99
> D (43233834) cellular: mux-rx-line #4: +CSQ: 10,99
> D (43233834) cellular: mux-rx-line #2: +CREG: 5
> D (43233834) cellular: mux-rx-line #3: +CREG: 5
> D (43233834) cellular: mux-rx-line #4: +CREG: 5
> D (43234024) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
> D (43234064) cellular: mux-rx-line #2: CONNECT 115200
> I (43234064) cellular: PPP Connection is ready to start
> OVMS# D (43235024) cellular: State transition NetStart => NetMode
> I (43235024) cellular: State: Enter NetMode state
> V (43235024) cellular: Starting PPP
> I (43235024) gsm-ppp: Initialising...
> D (43235114) cellular: mux-rx-line #3: NO CARRIER
> D (43235114) cellular: mux-rx-line #4: NO CARRIER
> D (43235124) cellular: mux-rx-line #3: +PPPD: DISCONNECTED
> I (43235124) cellular: PPP Connection disconnected
> D (43235124) cellular: mux-rx-line #4: +PPPD: DISCONNECTED
> OVMS# W (43236024) cellular: Lost network connection (+PPP disconnect in NetMode)
> D (43236024) cellular: State transition NetMode => NetLoss
> I (43236024) cellular: State: Enter NetLoss state
> D (43236024) cellular: mux-tx #3: AT+CGATT=0
> V (43236024) cellular: Stopping PPP
> I (43236024) gsm-ppp: Shutting down (hard)...
> I (43236024) gsm-ppp: PPP is shutdown
> I (43236024) netmanager: Set DNS#1 0.0.0.0
> I (43236024) netmanager: Set DNS#2 0.0.0.0
> OVMS# D (43246024) cellular: State timeout NetLoss => NetWait
> I (43246024) cellular: State: Enter NetWait state
> OVMS# I (43248024) gsm-ppp: StatusCallBack: User Interrupt
> OVMS# D (43250024) cellular: State transition NetWait => NetStart
> I (43250024) cellular: State: Enter NetStart state
> OVMS# D (43251024) cellular: Netstart AT+CGDCONT=1,"IP","hologram";+CGDATA="PPP",1
> D (43251064) cellular: mux-rx-line #2: CONNECT 115200
> I (43251064) cellular: PPP Connection is ready to start
> OVMS# D (43252024) cellular: State transition NetStart => NetMode
> I (43252024) cellular: State: Enter NetMode state
> V (43252024) cellular: Starting PPP
> I (43252024) gsm-ppp: Initialising...
> D (43252104) cellular: mux-rx-line #3: NO CARRIER
> D (43252104) cellular: mux-rx-line #4: NO CARRIER
> D (43252114) cellular: mux-rx-line #3: +PPPD: DISCONNECTED
