[Ovmsdev] 4G Simcom board
    Craig Leres
    leres at xse.com
    Mon May 10 00:56:55 HKT 2021
On 5/7/21 3:52 AM, Mark Webb-Johnson wrote:
> You can desolder the SIM5360 and replace it with a SIM7xxx, as we’ve
> designed the board to support both. But the issue is the firmware. The
> commands are different.
And if you go this route it's worth mentioning that the sim7600 uses
ANT2 instead of ANT3 so you either have to move the u.fl connector or
source a new one.
		Craig
