[Ovmsdev] 4G Simcom board
    Fri May  7 18:52:36 HKT 2021
You can desolder the SIM5360 and replace it with a SIM7xxx, as we’ve designed the board to support both. But the issue is the firmware. The commands are different.
I’ve been working on it for months already, fighting with weird network crashes unrelated to the driver itself. Pretty random and hard to repeat.
Still trying…
> On 7 May 2021, at 6:36 PM, Derek Caudwell <d.caudwell at gmail.com> wrote:
> Hi,
> To connect to 4G can anyone foresee an issue connecting up a SimCom 7000g such as this to the OVMS mainboard:
> https://a.aliexpress.com/_mNyRKTn <https://a.aliexpress.com/_mNyRKTn>
> I assume it may need the level shifter added (TXS0104EPWR) if not already on the board.
> Are all the SimCom commands generic or require modifying?
> Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210507/1dcf7a85/attachment.htm>
