[Ovmsdev] ssl cert
Wed Mar 31 20:04:40 HKT 2021
Shane,
found it: you've broken it by your pull request #596, and I've broken it
by not recognizing this when reviewing your PR.
You added a revert of the mongoose submodule checkout point to your PR:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/596/files#diff-5ab2a552f205c6fe33b157a2dc27590aa7258070eb926a8fc3719657dbcc2fd4
I've pushed the fix & published a new build to edge.
Am 31.03.21 um 13:21 schrieb Shane at Kilve-Engineering.co.uk:
> It’s using time from gps as that’s ticked
> Only started last few days but is ok on an older bin file
> Regards
> Shane Hunns
> Kilve Engineering Ltd.
> 0792 0729 316
>> On 31 Mar 2021, at 12:13, Michael Balzer <dexter at expeedo.de> wrote:
>>  Strange. No issues here, no reports from other users… the cert
>> hasn't changed in a while and is valid for another month. The CA cert
>> is valid until september.
>> Does your module have the right system date?
>> Am 31.03.21 um 12:54 schrieb Shane @ Kilve Engineering:
>>> Have you broke something?
>>> E (2710323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> <http://ovms.dexters-web.de:6870>) failed: Invalid SSL CA cert
>>> E (2710323) ovms-server-v2: Status: Error: Connection failed
>>> I (2770323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> <http://ovms.dexters-web.de:6870> maxushunnsnet
>>> I (2770323) ovms-server-v2: Status: Connecting...
>>> E (2770333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (2770333) ovms-server-v2: Status: Error: Connection failed
>>> I (2830323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (2830323) ovms-server-v2: Status: Connecting...
>>> E (2830353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (2830353) ovms-server-v2: Status: Error: Connection failed
>>> I (2890323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (2890323) ovms-server-v2: Status: Connecting...
>>> E (2890323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (2890323) ovms-server-v2: Status: Error: Connection failed
>>> I (2950323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (2950323) ovms-server-v2: Status: Connecting...
>>> E (2950323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (2950323) ovms-server-v2: Status: Error: Connection failed
>>> I (3001323) housekeeping: 2021-03-31 10:07:14 BST (RAM:
>>> 8b=72312-80768 32b=10360)
>>> I (3010323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (3010323) ovms-server-v2: Status: Connecting...
>>> E (3010323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (3010323) ovms-server-v2: Status: Error: Connection failed
>>> I (3070323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (3070323) ovms-server-v2: Status: Connecting...
>>> E (3070323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (3070323) ovms-server-v2: Status: Error: Connection failed
>>> I (3130323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (3130323) ovms-server-v2: Status: Connecting...
>>> E (3130353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (3130353) ovms-server-v2: Status: Error: Connection failed
>>> I (3190323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (3190323) ovms-server-v2: Status: Connecting...
>>> E (3190323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (3190323) ovms-server-v2: Status: Error: Connection failed
>>> I (3250323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (3250323) ovms-server-v2: Status: Connecting...
>>> E (3250323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (3250333) ovms-server-v2: Status: Error: Connection failed
>>> I (3301323) housekeeping: 2021-03-31 10:12:14 BST (RAM:
>>> I (3310323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (3310323) ovms-server-v2: Status: Connecting...
>>> E (3310333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> E (3310333) ovms-server-v2: Status: Error: Connection failed
>>> W (3717913) websocket: WebSocketHandler[0x3f84d2d0]: job queue
>>> overflow resolved, 1948 drops
>>> I (3730323) ovms-server-v2: Connection is ovms.dexters-web.de:6870
>>> I (3730323) ovms-server-v2: Status: Connecting...
>>> E (3730353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870
>>> Regards
>>> Shane Hunns
>>> 0792 0729 316
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210331/39f2f0f8/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210331/39f2f0f8/attachment.sig>
