[Ovmsdev] ssl cert
Shane@Kilve-Engineering.co.uk
shane at kilve-engineering.co.uk
Wed Mar 31 19:21:57 HKT 2021
It’s using time from gps as that’s ticked
Only started last few days but is ok on an older bin file
Regards
Shane Hunns
Kilve Engineering Ltd.
0792 0729 316
> On 31 Mar 2021, at 12:13, Michael Balzer <dexter at expeedo.de> wrote:
> Strange. No issues here, no reports from other users… the cert hasn't changed in a while and is valid for another month. The CA cert is valid until september.
> Does your module have the right system date?
> Am 31.03.21 um 12:54 schrieb Shane @ Kilve Engineering:
>> Have you broke something?
>> E (2710323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (2710323) ovms-server-v2: Status: Error: Connection failed
>> I (2770323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (2770323) ovms-server-v2: Status: Connecting...
>> E (2770333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (2770333) ovms-server-v2: Status: Error: Connection failed
>> I (2830323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (2830323) ovms-server-v2: Status: Connecting...
>> E (2830353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (2830353) ovms-server-v2: Status: Error: Connection failed
>> I (2890323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (2890323) ovms-server-v2: Status: Connecting...
>> E (2890323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (2890323) ovms-server-v2: Status: Error: Connection failed
>> I (2950323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (2950323) ovms-server-v2: Status: Connecting...
>> E (2950323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (2950323) ovms-server-v2: Status: Error: Connection failed
>> I (3001323) housekeeping: 2021-03-31 10:07:14 BST (RAM: 8b=72312-80768 32b=10360)
>> I (3010323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (3010323) ovms-server-v2: Status: Connecting...
>> E (3010323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (3010323) ovms-server-v2: Status: Error: Connection failed
>> I (3070323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (3070323) ovms-server-v2: Status: Connecting...
>> E (3070323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (3070323) ovms-server-v2: Status: Error: Connection failed
>> I (3130323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (3130323) ovms-server-v2: Status: Connecting...
>> E (3130353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (3130353) ovms-server-v2: Status: Error: Connection failed
>> I (3190323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (3190323) ovms-server-v2: Status: Connecting...
>> E (3190323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (3190323) ovms-server-v2: Status: Error: Connection failed
>> I (3250323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (3250323) ovms-server-v2: Status: Connecting...
>> E (3250323) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (3250333) ovms-server-v2: Status: Error: Connection failed
>> I (3301323) housekeeping: 2021-03-31 10:12:14 BST (RAM: 8b=72312-80768 32b=10360)
>> I (3310323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (3310323) ovms-server-v2: Status: Connecting...
>> E (3310333) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> E (3310333) ovms-server-v2: Status: Error: Connection failed
>> W (3717913) websocket: WebSocketHandler[0x3f84d2d0]: job queue overflow resolved, 1948 drops
>> I (3730323) ovms-server-v2: Connection is ovms.dexters-web.de:6870 maxushunnsnet
>> I (3730323) ovms-server-v2: Status: Connecting...
>> E (3730353) ovms-server-v2: mg_connect(ovms.dexters-web.de:6870) failed: Invalid SSL CA cert
>> Regards
>> Shane Hunns
>> 0792 0729 316
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210331/8389cfee/attachment-0001.htm>
Type: application/octet-stream
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20210331/8389cfee/attachment-0001.obj>
